Uninstall Trident Protect
You might need to remove Trident Protect components if you are upgrading from a trial to a full version of the product.
To remove Trident Protect, perform the following steps.
Steps
Remove the Trident Protect CR files:
This step is not required for version 25.06 and later. helm uninstall -n trident-protect trident-protect-crds -
Remove Trident Protect:
helm uninstall -n trident-protect trident-protect -
Remove the Trident Protect namespace:
kubectl delete ns trident-protect
