Uninstall Trident Protect
You might need to remove Trident Protect components if you are upgrading from a trial to a full version of the product.
To remove Trident Protect, perform the following steps.
Steps
  1. Remove the Trident Protect CR files:
    Note This step is not required for version 25.06 and later.
    helm uninstall -n trident-protect trident-protect-crds
  2. Remove Trident Protect:
  3. Remove the Trident Protect namespace:
    kubectl delete ns trident-protect
