Azure NetApp Files backend configuration options and examples
Contributors netapp-aruldeepa
Learn about NFS and SMB backend configuration options for Azure NetApp Files and review configuration examples.
Backend configuration options
Trident uses your backend configuration (subnet, virtual network, service level, and location), to create Azure NetApp Files volumes on capacity pools that are available in the requested location and match the requested service level and subnet.
Note * Beginning with NetApp Trident 25.06 release, manual QoS capacity pools are supported as a tech preview.*
Azure NetApp Files backends provide these configuration options.
Parameter Description Default
version
Always 1
storageDriverName
Name of the storage driver
"azure-netapp-files"
backendName
Custom name or the storage backend
Driver name + "_" + random characters
subscriptionID
The subscription ID from your Azure subscription
Optional when managed identities is enabled on an AKS cluster.
tenantID
The tenant ID from an App Registration
Optional when managed identities or cloud identity is used on an AKS cluster.
clientID
The client ID from an App Registration
clientSecret
The client secret from an App Registration
serviceLevel
One of Standard, Premium, or Ultra
"" (random)
location
Name of the Azure location where the new volumes will be created
resourceGroups
List of resource groups for filtering discovered resources
"[]" (no filter)
netappAccounts
List of NetApp accounts for filtering discovered resources
"[]" (no filter)
capacityPools
List of capacity pools for filtering discovered resources
"[]" (no filter, random)
virtualNetwork
Name of a virtual network with a delegated subnet
subnet
Name of a subnet delegated to Microsoft.Netapp/volumes
networkFeatures
Set of VNet features for a volume, may be Basic or Standard.
Network Features is not available in all regions and might have to be enabled in a subscription. Specifying networkFeatures when the functionality is not enabled causes volume provisioning to fail.
nfsMountOptions
Fine-grained control of NFS mount options.
Ignored for SMB volumes.
To mount volumes using NFS version 4.1, include nfsvers=4 in the comma-delimited mount options list to choose NFS v4.1.
Mount options set in a storage class definition override mount options set in backend configuration.
"nfsvers=3"
limitVolumeSize
Fail provisioning if the requested volume size is above this value
"" (not enforced by default)
debugTraceFlags
Debug flags to use when troubleshooting. Example, \{"api": false, "method": true, "discovery": true}. Do not use this unless you are troubleshooting and require a detailed log dump.
null
nasType
Configure NFS or SMB volumes creation.
Options are nfs, smb or null. Setting to null defaults to NFS volumes.
nfs
supportedTopologies
Represents a list of regions and zones that are supported by this backend.
For more information, refer to Use CSI Topology.
qosType
Represents the QoS type: Auto or Manual.
Tech preview for Trident 25.06
Auto
maxThroughput
Sets the maximum throughput allowed in MiB/sec.
Supported only for manual QoS capacity pools.
4 MiB/sec
Note For more information on Network Features, refer to Configure network features for an Azure NetApp Files volume.
Required permissions and resources
If you receive a "No capacity pools found" error when creating a PVC, it is likely your app registration doesn't have the required permissions and resources (subnet, virtual network, capacity pool) associated. If debug is enabled, Trident will log the Azure resources discovered when the backend is created. Verify an appropriate role is being used.
The values for resourceGroups, netappAccounts, capacityPools, virtualNetwork, and subnet can be specified using short or fully-qualified names. Fully-qualified names are recommended in most situations as short names can match multiple resources with the same name.
The resourceGroups, netappAccounts, and capacityPools values are filters that restrict the set of discovered resources to those available to this storage backend and may be specified in any combination. Fully-qualified names follow this format:
Type Format
Resource group
<resource group>
NetApp account
<resource group>/<netapp account>
Capacity pool
<resource group>/<netapp account>/<capacity pool>
Virtual network
<resource group>/<virtual network>
Subnet
<resource group>/<virtual network>/<subnet>
Volume provisioning
You can control default volume provisioning by specifying the following options in a special section of the configuration file. Refer to Example configurations for details.
exportRule
Export rules for new volumes.
exportRule must be a comma-separated list of any combination of IPv4 addresses or IPv4 subnets in CIDR notation.
"0.0.0.0/0"
snapshotDir
Controls visibility of the .snapshot directory
"true" for NFSv4
"false" for NFSv3
size
The default size of new volumes
"100G"
unixPermissions
The unix permissions of new volumes (4 octal digits).
"" (preview feature, requires whitelisting in subscription)
The following examples show basic configurations that leave most parameters to default. This is the easiest way to define a backend.
Minimal configuration
This is the absolute minimum backend configuration. With this configuration, Trident discovers all of your NetApp accounts, capacity pools, and subnets delegated to Azure NetApp Files in the configured location, and places new volumes on one of those pools and subnets randomly. Because nasType is omitted, the nfs default applies and the backend will provision for NFS volumes.
This configuration is ideal when you are just getting started with Azure NetApp Files and trying things out, but in practice you are going to want to provide additional scoping for the volumes you provision.
kind: TridentBackendConfig
metadata:
  namespace: trident
spec:
  version: 1
  storageDriverName: azure-netapp-files
  subscriptionID: 9f87c765-4774-fake-ae98-a721add45451
  tenantID: 68e4f836-edc1-fake-bff9-b2d865ee56cf
  clientID: dd043f63-bf8e-fake-8076-8de91e5713aa
  clientSecret: SECRET
Managed identities for AKS
This backend configuration omits subscriptionID, tenantID, clientID, and clientSecret, which are optional when using managed identities.
metadata:
  namespace: trident
spec:
  version: 1
  capacityPools:
    - ultra-pool
  resourceGroups:
    - aks-ami-eastus-rg
  netappAccounts:
    - smb-na
  virtualNetwork: eastus-prod-vnet
  subnet: eastus-anf-subnet
Cloud identity for AKS
This backend configuration omits tenantID, clientID, and clientSecret, which are optional when using a cloud identity.
metadata:
  namespace: trident
spec:
  version: 1
  capacityPools:
    - ultra-pool
  resourceGroups:
    - aks-ami-eastus-rg
  netappAccounts:
    - smb-na
Specific service level configuration with capacity pool filters
This backend configuration places volumes in Azure's eastus location in an Ultra capacity pool. Trident automatically discovers all of the subnets delegated to Azure NetApp Files in that location and places a new volume on one of them randomly.
version: 1
serviceLevel: Ultra
capacityPools:
  - application-group-1/account-1/ultra-1
  - application-group-1/account-1/ultra-2
Backend example with manual QoS capacity pools
This backend configuration places volumes in Azure's eastus location with manual QoS capacity pools.
Tech preview in NetApp Trident 25.06.
version: 1
backendName: anf1
labels:
  clusterName: test-cluster-1
  cloud: anf
  nasType: nfs
defaults:
  qosType: Manual
storage:
  - serviceLevel: Ultra
    labels:
      performance: gold
    defaults:
      maxThroughput: 10
  - serviceLevel: Premium
    labels:
      performance: silver
    defaults:
      maxThroughput: 5
  - serviceLevel: Standard
    labels:
      performance: bronze
    defaults:
      maxThroughput: 3
Advanced configuration
This backend configuration further reduces the scope of volume placement to a single subnet, and also modifies some volume provisioning defaults.
version: 1
serviceLevel: Ultra
capacityPools:
virtualNetwork: my-virtual-network
subnet: my-subnet
networkFeatures: Standard
nfsMountOptions: vers=3,proto=tcp,timeo=600
limitVolumeSize: 500Gi
defaults:
  exportRule: 10.0.0.0/24,10.0.1.0/24,10.0.2.100
  snapshotDir: "true"
  unixPermissions: "0777"
Virtual pool configuration
This backend configuration defines multiple storage pools in a single file. This is useful when you have multiple capacity pools supporting different service levels and you want to create storage classes in Kubernetes that represent those. Virtual pool labels were used to differentiate the pools based on performance.
version: 1
resourceGroups:
networkFeatures: Basic
labels:
  cloud: azure
storage:
  - labels:
      performance: gold
    serviceLevel: Ultra
    capacityPools:
      - ultra-1
      - ultra-2
  - labels:
      performance: silver
    capacityPools:
      - premium-1
  - labels:
      performance: bronze
    capacityPools:
      - standard-1
      - standard-2
Supported topologies configuration
Trident facilitates provisioning of volumes for workloads based on regions and availability zones. The supportedTopologies block in this backend configuration is used to provide a list of regions and zones per backend. The region and zone values specified here must match the region and zone values from the labels on each Kubernetes cluster node. These regions and zones represent the list of permissible values that can be provided in a storage class. For storage classes that contain a subset of the regions and zones provided in a backend, Trident creates volumes in the mentioned region and zone.
version: 1
serviceLevel: Ultra
capacityPools:
supportedTopologies:
  - topology.kubernetes.io/region: eastus
    topology.kubernetes.io/zone: eastus-1
    topology.kubernetes.io/zone: eastus-2
Storage class definitions
The following StorageClass definitions refer to the storage pools above.
Example definitions using parameter.selector field
Using parameter.selector you can specify for each StorageClass the virtual pool that is used to host a volume. The volume will have the aspects defined in the chosen pool.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  selector: performance=gold
allowVolumeExpansion: true
kind: StorageClass
metadata:
parameters:
  selector: performance=silver
kind: StorageClass
metadata:
parameters:
  selector: performance=bronze
Example definitions for SMB volumes
Using nasType, node-stage-secret-name, and node-stage-secret-namespace, you can specify an SMB volume and provide the required Active Directory credentials.
Basic configuration on default namespace
kind: StorageClass
metadata:
parameters:
  backendType: "azure-netapp-files"
  trident.netapp.io/nasType: "smb"
  csi.storage.k8s.io/node-stage-secret-name: "smbcreds"
  csi.storage.k8s.io/node-stage-secret-namespace: "default"
Using different secrets per namespace
kind: StorageClass
metadata:
parameters:
  csi.storage.k8s.io/node-stage-secret-namespace: ${pvc.namespace}
Using different secrets per volume
kind: StorageClass
metadata:
parameters:
  csi.storage.k8s.io/node-stage-secret-name: ${pvc.name}
Note nasType: smb filters for pools which support SMB volumes. nasType: nfs or nasType: null filters for NFS pools.
Create the backend
After you create the backend configuration file, run the following command:
tridentctl create backend -f <backend-file>
If the backend creation fails, something is wrong with the backend configuration. You can view the logs to determine the cause by running the following command:
tridentctl logs
After you identify and correct the problem with the configuration file, you can run the create command again.
