Azure NetApp Files backend configuration options and examples
Learn about NFS and SMB backend configuration options for Azure NetApp Files and review configuration examples.
Backend configuration options
Trident uses your backend configuration (subnet, virtual network, service level, and location) to create Azure NetApp Files volumes on capacity pools that are available in the requested location and match the requested service level and subnet.
Azure NetApp Files backends provide these configuration options.
| Parameter | Description | Default |
Backend configuration version. |
Always 1 |
Name of the storage driver |
"azure-netapp-files" |
Custom name for the storage backend |
Driver name + "_" + random characters |
The subscription ID from your Azure subscription |
The tenant ID from an App Registration |
The client ID from an App Registration |
The client secret from an App Registration |
One of |
"" (random) |
Name of the Azure location where the new volumes will be created |
Identifies the Azure cloud environment for the backend. Set to |
List of resource groups for filtering discovered resources |
"[]" (no filter) |
List of NetApp accounts for filtering discovered resources |
"[]" (no filter) |
List of capacity pools for filtering discovered resources |
"[]" (no filter, random) |
Name of a virtual network with a delegated subnet |
Name of a subnet delegated to |
Set of VNet features for a volume, may be |
Fine-grained control of NFS mount options. |
"nfsvers=3" |
Fail provisioning if the requested volume size is above this value |
"" (not enforced by default) |
Debug flags to use when troubleshooting. Example, |
null |
Configure NFS or SMB volumes creation. |
Represents a list of regions and zones that are supported by this backend. |
Represents the QoS type: Auto or Manual. |
Auto |
Sets the maximum throughput allowed in MiB/sec. |
For more information on Network Features, refer to Configure network features for an Azure NetApp Files volume. |
Consider Azure cloud environments (26.06)
Starting with the 26.06 release, Trident supports creating and managing Azure NetApp Files backends in multiple Azure cloud environments.
Supported Azure clouds include:
Azure Commercial
Azure Government (Azure Government / MAG)
Azure China
When you deploy Trident or create an Azure NetApp Files backend, ensure that Azure Resource Manager and authentication endpoints match your Azure cloud environment.
If the endpoints do not match, tridentctl cannot authenticate and backend creation fails.
For an Azure Government backend, set cloudConfiguration.cloudName in the backend configuration:
cloudConfiguration:
cloudName: AzureGovernment
Required permissions and resources
If you receive a "No capacity pools found" error when creating a PVC, it is likely your app registration doesn't have the required permissions and resources (subnet, virtual network, capacity pool) associated.
If debug is enabled, Trident logs the Azure resources discovered when the backend is created.
Verify an appropriate role is being used.
The values for resourceGroups, netappAccounts, capacityPools, virtualNetwork, and subnet can be specified using short or fully-qualified names.
Fully-qualified names are recommended in most situations as short names can match multiple resources with the same name.
If the vNet is located in a different resource group from the Azure NetApp Files (ANF) storage account, specify the resource group for the virtual network while configuring the resourceGroups list for the backend. |
The resourceGroups, netappAccounts, and capacityPools values are filters that restrict the set of discovered resources to those available to this storage backend and may be specified in any combination.
Fully-qualified names follow this format:
| Type | Format |
Resource group |
<resource group> |
NetApp account |
<resource group>/<netapp account> |
Capacity pool |
<resource group>/<netapp account>/<capacity pool> |
Virtual network |
<resource group>/<virtual network> |
Subnet |
<resource group>/<virtual network>/<subnet> |
Volume provisioning
You can control default volume provisioning by specifying the following options in a special section of the configuration file.
Refer to Example configurations for details.
Export rules for new volumes. |
"0.0.0.0/0" |
Access to the |
The default size of new volumes |
"100G" |
The unix permissions of new volumes (4 octal digits). |
"" (preview feature, requires whitelisting in subscription) |
The following examples show basic configurations that leave most parameters to default.
This is the easiest way to define a backend.
Minimal configuration
This is the absolute minimum backend configuration.
With this configuration, Trident discovers all of your NetApp accounts, capacity pools, and subnets delegated to Azure NetApp Files in the configured location, and places new volumes on one of those pools and subnets randomly.
Because nasType is omitted, the nfs default applies and the backend will provision for NFS volumes.
This configuration is ideal when you are just getting started with Azure NetApp Files and trying things out, but in practice you are going to want to provide additional scoping for the volumes you provision.
kind: TridentBackendConfig
metadata:
namespace: trident
spec:
version: 1
storageDriverName: azure-netapp-files
subscriptionID: 9f87c765-4774-fake-ae98-a721add45451
tenantID: 68e4f836-edc1-fake-bff9-b2d865ee56cf
clientID: dd043f63-bf8e-fake-8076-8de91e5713aa
clientSecret: SECRET
Managed identities for AKS
This backend configuration omits subscriptionID, tenantID, clientID, and clientSecret, which are optional when using managed identities.
metadata:
namespace: trident
spec:
version: 1
capacityPools:
- resource-group-1/netapp-account-1/ultra-pool
resourceGroups:
- resource-group-1
netappAccounts:
virtualNetwork: resource-group-1/eastus-prod-vnet
subnet: resource-group-1/eastus-prod-vnet/eastus-anf-subnet
Cloud identity for AKS
This backend configuration omits tenantID, clientID, and clientSecret, which are optional when using a cloud identity.
metadata:
namespace: trident
spec:
version: 1
capacityPools:
- ultra-pool
resourceGroups:
- aks-ami-eastus-rg
netappAccounts:
- smb-na
virtualNetwork: eastus-prod-vnet
subnet: eastus-anf-subnet
Specific service level configuration with capacity pool filters
This backend configuration places volumes in Azure's eastus location in an Ultra capacity pool.
Trident automatically discovers all of the subnets delegated to Azure NetApp Files in that location and places a new volume on one of them randomly.
version: 1
serviceLevel: Ultra
capacityPools:
- application-group-1/account-1/ultra-1
- application-group-1/account-1/ultra-2
Backend example with manual QoS capacity pools
This backend configuration places volumes in Azure's eastus location with manual QoS capacity pools.
version: 1
backendName: anf1
labels:
clusterName: test-cluster-1
cloud: anf
nasType: nfs
defaults:
qosType: Manual
storage:
- serviceLevel: Ultra
labels:
performance: gold
defaults:
maxThroughput: 10
- serviceLevel: Premium
labels:
performance: silver
defaults:
maxThroughput: 5
- serviceLevel: Standard
labels:
performance: bronze
defaults:
maxThroughput: 3
Advanced configuration
This backend configuration further reduces the scope of volume placement to a single subnet, and also modifies some volume provisioning defaults.
version: 1
serviceLevel: Ultra
capacityPools:
virtualNetwork: application-group-1/eastus-prod-vnet
subnet: application-group-1/eastus-prod-vnet/my-subnet
networkFeatures: Standard
nfsMountOptions: vers=3,proto=tcp,timeo=600
limitVolumeSize: 500Gi
defaults:
exportRule: 10.0.0.0/24,10.0.1.0/24,10.0.2.100
snapshotDir: "true"
unixPermissions: "0777"
Virtual pool configuration
This backend configuration defines multiple storage pools in a single file.
This is useful when you have multiple capacity pools supporting different service levels and you want to create storage classes in Kubernetes that represent those.
Virtual pool labels were used to differentiate the pools based on performance.
version: 1
resourceGroups:
networkFeatures: Basic
labels:
cloud: azure
storage:
- labels:
performance: gold
serviceLevel: Ultra
capacityPools:
- application-group-1/netapp-account-1/ultra-1
- application-group-1/netapp-account-1/ultra-2
- labels:
performance: silver
capacityPools:
- application-group-1/netapp-account-1/premium-1
- labels:
performance: bronze
capacityPools:
- application-group-1/netapp-account-1/standard-1
- application-group-1/netapp-account-1/standard-2
Supported topologies configuration
Trident facilitates provisioning of volumes for workloads based on regions and availability zones.
The supportedTopologies block in this backend configuration is used to provide a list of regions and zones per backend.
The region and zone values specified here must match the region and zone values from the labels on each Kubernetes cluster node.
These regions and zones represent the list of permissible values that can be provided in a storage class.
For storage classes that contain a subset of the regions and zones provided in a backend, Trident creates volumes in the mentioned region and zone.
For more information, refer to Use CSI Topology.
version: 1
serviceLevel: Ultra
capacityPools:
supportedTopologies:
- topology.kubernetes.io/region: eastus
topology.kubernetes.io/zone: eastus-1
topology.kubernetes.io/zone: eastus-2
Storage class definitions
The following StorageClass definitions refer to the storage pools above.
Example definitions using parameter.selector field
Using parameter.selector you can specify for each StorageClass the virtual pool that is used to host a volume.
The volume will have the aspects defined in the chosen pool.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
selector: performance=gold
allowVolumeExpansion: true
kind: StorageClass
metadata:
parameters:
selector: performance=silver
kind: StorageClass
metadata:
parameters:
selector: performance=bronze
Example definitions for SMB volumes
Using nasType, node-stage-secret-name, and node-stage-secret-namespace, you can specify an SMB volume and provide the required Active Directory credentials.
Basic configuration on default namespace
kind: StorageClass
metadata:
parameters:
backendType: "azure-netapp-files"
trident.netapp.io/nasType: "smb"
csi.storage.k8s.io/node-stage-secret-name: "smbcreds"
csi.storage.k8s.io/node-stage-secret-namespace: "default"
Using different secrets per namespace
kind: StorageClass
metadata:
parameters:
csi.storage.k8s.io/node-stage-secret-namespace: ${pvc.namespace}
Using different secrets per volume
kind: StorageClass
metadata:
parameters:
csi.storage.k8s.io/node-stage-secret-name: ${pvc.name}
nasType: smb filters for pools which support SMB volumes.nasType: nfs or nasType: null filters for NFS pools.
Create the backend
After you create the backend configuration file, run the following command:
tridentctl create backend -f <backend-file>
If you use a non-Commercial Azure cloud, ensure that tridentctl is configured to use the Azure Resource Manager and authentication endpoints for your Azure cloud environment.
If the backend creation fails, check your backend configuration and view the logs to determine the cause:
tridentctl logs
After you identify and correct the problem with the configuration file, you can run the create command again.
