Create a storage class
Contributors netapp-aruldeepa
Configure a Kubernetes StorageClass object and create the storage class to instruct Trident how to provision volumes.
The Kubernetes StorageClass object identifies Trident as the provisioner that is used for that class and instructs Trident how to provision a volume. For example:
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
mountOptions:
  - nfsvers=3
  - nolock
parameters:
  backendType: "ontap-nas"
  media: "ssd"
allowVolumeExpansion: true
volumeBindingMode: Immediate
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Trident provisions volumes.
After you create the StorageClass object, you can create the storage class. Storage class samples provides some basic samples you can use or modify.
Steps
  1. This is a Kubernetes object, so use kubectl to create it in Kubernetes.
    kubectl create -f sample-input/storage-class-basic-csi.yaml
  2. You should now see a basic-csi storage class in both Kubernetes and Trident, and Trident should have discovered the pools on the backend.
    kubectl get sc basic-csi
NAME         PROVISIONER             AGE
basic-csi    csi.trident.netapp.io   15h
./tridentctl -n trident get storageclass basic-csi -o json
  "items": [
      "Config": {
        "version": "1",
        "name": "basic-csi",
        "attributes": {
          "backendType": "ontap-nas"
        "storagePools": null,
        "additionalStoragePools": null
      "storage": {
        "ontapnas_10.0.0.1": [
          "aggr1",
          "aggr2",
          "aggr3",
          "aggr4"
Alternatively, you can edit sample-input/storage-class-csi.yaml.templ file that comes with the installer and replace BACKEND_TYPE with the storage driver name.
./tridentctl -n trident get backend
|    NAME     | STORAGE DRIVER |                 UUID                 | STATE  | VOLUMES |
| nas-backend | ontap-nas      | 98e19b74-aec7-4a3d-8dcf-128e5033b214 | online |       0 |
cp sample-input/storage-class-csi.yaml.templ sample-input/storage-class-basic-csi.yaml
# Modify __BACKEND_TYPE__ with the storage driver field above (e.g., ontap-nas)
vi sample-input/storage-class-basic-csi.yaml
