Configure a storage class and PVC
Contributors netapp-aruldeepa
Configure a Kubernetes StorageClass object and create the storage class to instruct Trident how to provision volumes. Create a PersistentVolumeClaim (PVC) that uses the configured Kubernetes StorageClass to request access to the PV. You can then mount the PV to a pod.
Create a storage class
The Kubernetes StorageClass object object identifies Trident as the provisioner that is used for that class and instructs Trident how to provision a volume. Use this example to setup Storageclass for volumes using NFS (Refer to Trident Attribute section below for the full list of attributes):
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-nas"
  provisioningType: "thin"
  snapshots: "true"
Use this example to setup Storageclass for volumes using iSCSI:
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-san"
  snapshots: "true"
To provision NFSv3 volumes on AWS Bottlerocket, add the required mountOptions to the storage class:
kind: StorageClass
metadata:
parameters:
  media: "ssd"
  snapshots: "true"
mountOptions:
  - nfsvers=3
  - nolock
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Trident provisions volumes.
Steps
  1. This is a Kubernetes object, so use kubectl to create it in Kubernetes.
    kubectl create -f storage-class-ontapnas.yaml
  2. You should now see a basic-csi storage class in both Kubernetes and Trident, and Trident should have discovered the pools on the backend.
    kubectl get sc basic-csi
NAME         PROVISIONER             AGE
basic-csi    csi.trident.netapp.io   15h
Create the PVC
A PersistentVolumeClaim (PVC) is a request for access to the PersistentVolume on the cluster.
The PVC can be configured to request storage of a certain size or access mode. Using the associated StorageClass, the cluster administrator can control more than PersistentVolume size and access mode—​such as performance or service level.
After you create the PVC, you can mount the volume in a pod.
Sample manifests
PersistentVolumeClaim sample manifests
These examples show basic PVC configuration options.
PVC with RWX access
This example shows a basic PVC with RWX access that is associated with a StorageClass named basic-csi.
kind: PersistentVolumeClaim
apiVersion: v1
metadata:
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: 1Gi
  storageClassName: ontap-gold
PVC using iSCSI example
This example shows a basic PVC for iSCSI with RWO access that is associated with a StorageClass named protection-gold.
apiVersion: v1
metadata:
spec:
accessModes:
  - ReadWriteOnce
resources:
  requests:
    storage: 1Gi
storageClassName: protection-gold
Create PVC
Steps
  1. Create the PVC.
    kubectl create -f pvc.yaml
  2. Verify the PVC status.
    kubectl get pvc
NAME        STATUS VOLUME     CAPACITY ACCESS MODES STORAGECLASS AGE
pvc-storage Bound  pv-name 2Gi      RWO                       5m
Trident attributes
These parameters determine which Trident-managed storage pools should be utilized to provision volumes of a given type.
Attribute Type Values Offer Request Supported by
media1
string
hdd, hybrid, ssd
Pool contains media of this type; hybrid means both
Media type specified
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, solidfire-san
provisioningType
string
thin, thick
Pool supports this provisioning method
Provisioning method specified
thick: all ontap; thin: all ontap & solidfire-san
backendType
string
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, solidfire-san, gcp-cvs, azure-netapp-files, ontap-san-economy
Pool belongs to this type of backend
Backend specified
All drivers
snapshots
bool
true, false
Pool supports volumes with snapshots
Volume with snapshots enabled
ontap-nas, ontap-san, solidfire-san, gcp-cvs
clones
bool
true, false
Pool supports cloning volumes
Volume with clones enabled
encryption
bool
true, false
Pool supports encrypted volumes
Volume with encryption enabled
ontap-nas, ontap-nas-economy, ontap-nas-flexgroups, ontap-san
IOPS
int
positive integer
Pool is capable of guaranteeing IOPS in this range
Volume guaranteed these IOPS
solidfire-san
1: Not supported by ONTAP Select systems
