Configure a storage class
Contributors netapp-aruldeepa kcantrel joan-ing
The Kubernetes StorageClass object identifies a provisioner and instructs the provisioner how to provision volumes. This section shows you how to configure a Kubernetes StorageClass object that specifies Trident as the provisioner.
Create a StorageClass Object
When you create a StorageClass for FSx for ONTAP, Trident can automatically create the backend configuration.
To configure the storage backend manually, see Create a Kubernetes StorageClass without automatic backend configuration for instructions on creating the Trident backend and StorageClass separately.
Note On OpenShift, you must create the Trident backend and StorageClass separately.
Understand how automatic backend configuration works
Trident derives backend configuration from the StorageClass definition. When you apply the StorageClass, Trident validates the required parameters, creates the backend, and annotates the StorageClass with status.
Trident creates the VolumeSnapshotClass only once. Trident reuses the same VolumeSnapshotClass for subsequent StorageClasses.
Specify required StorageClass parameters
The following three parameters need to be defined when creating a StorageClass:
Parameter Required Type Description
fsxFilesystemID
Yes
string
FSx for NetApp ONTAP filesystem ID
storageDriverName
Yes
string
Trident storage driver (for example, ontap-nas or ontap-san)
credentialsName
Yes
string
Name of the Kubernetes Secret or AWS Secrets Manager secret ARN that contains FSx for ONTAP credentials
Specify optional parameters
You can pass optional backend parameters through the StorageClass. Define all optional values as strings in the StorageClass parameters section. For a complete list of backend parameters, see: FSx for NetApp ONTAP backend configuration.
Example StorageClass configuration files.
The following example shows a StorageClass that triggers automatic backend configuration.
YAML
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
  annotations:
    description: "Demo StorageClass for FSx for NetApp ONTAP"
parameters:
  fsxFilesystemID: "fs-0abc123"
  storageDriverName: "ontap-nas"
  credentialsName: trident-fsx-credentials
allowVolumeExpansion: true
reclaimPolicy: Delete
volumeBindingMode: Immediate
JSON
  "apiVersion": "storage.k8s.io/v1",
  "kind": "StorageClass",
  "metadata": {
    "name": "ontap-fsx-demo",
    "annotations": {
      "description": "Demo StorageClass for FSx for NetApp ONTAP"
  "provisioner": "csi.trident.netapp.io",
  "parameters": {
    "fsxFilesystemID": "fs-0abc123",
    "storageDriverName": "ontap-nas",
    "credentialsName": "trident-fsx-credentials"
  "allowVolumeExpansion": true,
  "reclaimPolicy": "Delete",
  "volumeBindingMode": "Immediate"
Create the StorageClass
Once you have created you configuration file, run the following command to create the storage class.
kubectl create -f storage-class-ontapnas.yaml
You should now see a basic-csi storage class in both Kubernetes and Trident, and Trident should have discovered the pools on the backend.
kubectl get sc basic-csi
NAME         PROVISIONER             AGE
basic-csi    csi.trident.netapp.io   15h
After you apply the StorageClass, Trident creates the backend automatically. You can then create PersistentVolumeClaims that reference this StorageClass.
Verify backend configuration status
Trident records the result of backend creation in StorageClass annotations.
Annotation Description
trident.netapp.io/configuratorStatus
Configuration result (Success or Failure)
trident.netapp.io/configuratorMessage
Detailed status or error message
trident.netapp.io/configuratorName
Name of the internal configurator resource
trident.netapp.io/managed
Indicates the StorageClass is managed by Trident
trident.netapp.io/additionalStoragePools
Storage pools created for this backend
To verify status, run:
kubectl get storageclass ontap-fsx-demo -o yaml
Confirm that trident.netapp.io/configuratorStatus is set to Success. If the value is Failure, review trident.netapp.io/configuratorMessage for the error.
Add additional FSxN file systems
If you need additional storage capacity while continuing to use the same StorageClass, add additional FSxN file system IDs.
Edit the StorageClass and add the following annotation:
metadata:
  annotations:
    trident.netapp.io/additionalFsxNFileSystemID: '["fs-xxxxxxxxxxxxxxxxxx"]'
After you apply the change, Trident updates the backend configuration and updates the StorageClass annotations.
Operational considerations and limitations
  • Deleting a StorageClass that as the automatic backend configuration usually deletes the associated Trident backend. This can disrupt storage connectivity and break running workloads. Validate the impact before you delete a managed StorageClass.
  • Automatic backend configuration is supported only for AWS FSx for NetApp ONTAP.
If you want to create the Trident backend and StorageClass separately then follow these steps.
Create the Trident backend
To create a Trident backend, you need to create a configuration file in either JSON or YAML format. The file needs to specify the type of storage you want (NAS or SAN), the file system, and SVM to get it from and how to authenticate with it. The following example shows how to define NAS-based storage and using an AWS secret to store the credentials to the SVM you want to use:
YAML
kind: TridentBackendConfig
metadata:
  namespace: trident
spec:
  version: 1
  defaults:
    skipRecoveryQueue: "true"
  storageDriverName: ontap-nas
  backendName: tbc-ontap-nas
  svm: svm-name
  aws:
    fsxFilesystemID: fs-xxxxxxxxxx
    apiRegion: us-west-2
  credentials:
    type: awsarn
JSON
  "apiVersion": "trident.netapp.io/v1",
  "kind": "TridentBackendConfig",
  "metadata": {
    "name": "backend-tbc-ontap-nas"
    "namespace": "trident"
  "spec": {
    "version": 1,
    "defaults": {
      "skipRecoveryQueue": "true"
    "backendName": "tbc-ontap-nas",
    "svm": "svm-name",
    "aws": {
      "fsxFilesystemID": "fs-xxxxxxxxxx",
      "apiRegion": "us-west-2"
    "credentials": {
      "name": "arn:aws:secretsmanager:us-west-2:xxxxxxxx:secret:secret-name",
      "type": "awsarn"
FSx for ONTAP driver details
You can integrate Trident with Amazon FSx for NetApp ONTAP using the following drivers:
Driver Name Description
ontap-san
Each PV provisioned is a LUN within its own Amazon FSx for NetApp ONTAP volume. Recommended for block storage.
ontap-nas
Each PV provisioned is a full Amazon FSx for NetApp ONTAP volume. Recommended for NFS and SMB.
ontap-san-economy
Each PV provisioned is a LUN with a configurable number of LUNs per Amazon FSx for NetApp ONTAP volume.
ontap-nas-economy
Each PV provisioned is a qtree, with a configurable number of qtrees per Amazon FSx for NetApp ONTAP volume.
ontap-nas-flexgroup
Each PV provisioned is a full Amazon FSx for NetApp ONTAP FlexGroup volume.
For driver details, refer to NAS drivers and SAN drivers.
Create the backend
After creating the configuration file run the following commands to create and validate the Trident Backend Configuration (TBC):
  • Create trident backend configuration (TBC) from yaml file and run the following command:
    kubectl create -f backendconfig.yaml -n trident
    tridentbackendconfig.trident.netapp.io/backend-tbc-ontap-nas created
  • Validate the trident backend configuration (TBC) was created successfully:
    Kubectl get tbc -n trident
    NAME                         BACKEND NAME         BACKEND UUID                           PHASE   STATUS
    backend-tbc-ontap-nas        tbc-ontap-nas        933e0071-66ce-4324-b9ff-f96d916ac5e9   Bound   Success
For more information on other configuration options, see the Backend-advanced-configuration-and-examples section below.
Configure a Storage Class without automatic backend configuration
The following are examples of Storage Class configurations for use with Trident and FSx for ONTAP.
Storage Class for NFS
You can use this example to setup StorageClass for volumes using NFS (Refer to Trident Attribute section below for the full list of attributes):
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-nas"
  provisioningType: "thin"
  snapshots: "true"
Storage Class for iSCSI
Use this example to setup StorageClass for volumes using iSCSI:
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-san"
  snapshots: "true"
Storage Class using NFSv3 and AWS Bottlerocket
To provision NFSv3 volumes on AWS Bottlerocket, add the required mountOptions to the storage class:
kind: StorageClass
metadata:
parameters:
  media: "ssd"
  snapshots: "true"
mountOptions:
  - nfsvers=3
  - nolock
Trident StorageClass attributes
These parameters determine which Trident-managed storage pools should be utilized to provision volumes of a given type.
Attribute Type Values Offer Request Supported by
media1
string
hdd, hybrid, ssd
Pool contains media of this type; hybrid means both
Media type specified
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, solidfire-san
provisioningType
string
thin, thick
Pool supports this provisioning method
Provisioning method specified
thick: all ontap; thin: all ontap & solidfire-san
backendType
string
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, solidfire-san, azure-netapp-files, ontap-san-economy
Pool belongs to this type of backend
Backend specified
All drivers
snapshots
bool
true, false
Pool supports volumes with snapshots
Volume with snapshots enabled
ontap-nas, ontap-san, solidfire-san
clones
bool
true, false
Pool supports cloning volumes
Volume with clones enabled
encryption
bool
true, false
Pool supports encrypted volumes
Volume with encryption enabled
ontap-nas, ontap-nas-economy, ontap-nas-flexgroups, ontap-san
IOPS
int
positive integer
Pool is capable of guaranteeing IOPS in this range
Volume guaranteed these IOPS
solidfire-san
1: Not supported by ONTAP Select or FSx for ONTAP systems
Refer to Kubernetes and Trident objects for details on how storage classes interact with the PersistentVolumeClaim and parameters for controlling how Trident provisions volumes.
Create the storage class
Once you have configured the StorageClass, you can create it in Kubernetes.
Steps
  1. This is a Kubernetes object, so use kubectl to create it in Kubernetes.
  2. You should now see a basic-csi storage class in both Kubernetes and Trident, and Trident should have discovered the pools on the backend.
Provision SMB volumes
You can provision SMB volumes using the ontap-nas driver.
However, to do so you must complete these steps: Prepare to provision SMB volumes.
Backend advanced configuration and examples
See the following table for the backend configuration options:
Parameter Description Example
version
Always 1
storageDriverName
Name of the storage driver
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, ontap-san-economy
backendName
Custom name or the storage backend
Driver name + "_" + dataLIF
managementLIF
IP address of a cluster or SVM management LIF
A fully-qualified domain name (FQDN) can be specified.
Can be set to use IPv6 addresses if Trident was installed using the IPv6 flag. IPv6 addresses must be defined in square brackets, such as [28e8:d9fb:a825:b7bf:69a8:d02f:9e7b:3555].
If you provide the fsxFilesystemID under the aws field, you need not to provide the managementLIF because Trident retrieves the SVM managementLIF information from AWS. So, you must provide credentials for a user under the SVM (For example: vsadmin) and the user must have the vsadmin role.
"10.0.0.1", "[2001:1234:abcd::fefe]"
dataLIF
IP address of protocol LIF.
ONTAP NAS drivers: NetApp recommends specifying dataLIF. If not provided, Trident fetches dataLIFs from the SVM. You can specify a fully-qualified domain name (FQDN) to be used for the NFS mount operations, allowing you to create a round-robin DNS to load-balance across multiple dataLIFs. Can be changed after initial setting.
ONTAP SAN drivers: Do not specify for iSCSI. Trident uses ONTAP Selective LUN Map to discover the iSCI LIFs needed to establish a multi path session. A warning is generated if dataLIF is explicitly defined.
autoExportPolicy
Enable automatic export policy creation and updating [Boolean].
Using the autoExportPolicy and autoExportCIDRs options, Trident can manage export policies automatically.
false
autoExportCIDRs
List of CIDRs to filter Kubernetes' node IPs against when autoExportPolicy is enabled.
"["0.0.0.0/0", "::/0"]"
labels
Set of arbitrary JSON-formatted labels to apply on volumes
clientCertificate
Base64-encoded value of client certificate. Used for certificate-based auth
clientPrivateKey
Base64-encoded value of client private key. Used for certificate-based auth
trustedCACertificate
Base64-encoded value of trusted CA certificate. Optional. Used for certificate-based authentication.
username
Username to connect to the cluster or SVM. Used for credential-based authentication. For example, vsadmin.
password
Password to connect to the cluster or SVM. Used for credential-based authentication.
svm
Storage virtual machine to use
Derived if an SVM managementLIF is specified.
storagePrefix
Prefix used when provisioning new volumes in the SVM.
Cannot be modified after creation. To update this parameter, you will need to create a new backend.
trident
limitAggregateUsage
Do not specify for Amazon FSx for NetApp ONTAP.
The provided fsxadmin and vsadmin do not contain the permissions required to retrieve aggregate usage and limit it using Trident.
Do not use.
limitVolumeSize
Fail provisioning if requested volume size is above this value.
Also restricts the maximum size of the volumes it manages for qtrees and LUNs, and the qtreesPerFlexvol option allows customizing the maximum number of qtrees per FlexVol volume
"" (not enforced by default)
lunsPerFlexvol
Maximum LUNs per Flexvol volume, must be in range [50, 200].
SAN only.
“100”
debugTraceFlags
Debug flags to use when troubleshooting. Example, {"api":false, "method":true}
Do not use debugTraceFlags unless you are troubleshooting and require a detailed log dump.
null
nfsMountOptions
Comma-separated list of NFS mount options.
The mount options for Kubernetes-persistent volumes are normally specified in storage classes, but if no mount options are specified in a storage class, Trident will fall back to using the mount options specified in the storage backend's configuration file.
If no mount options are specified in the storage class or the configuration file, Trident will not set any mount options on an associated persistent volume.
nasType
Configure NFS or SMB volumes creation.
Options are nfs, smb, or null.
Must set to smb for SMB volumes. Setting to null defaults to NFS volumes.
nfs
qtreesPerFlexvol
Maximum Qtrees per FlexVol volume, must be in range [50, 300]
"200"
smbShare
You can specify one of the following: the name of an SMB share created using the Microsoft Management Console or ONTAP CLI or a name to allow Trident to create the SMB share.
This parameter is required for Amazon FSx for ONTAP backends.
smb-share
useREST
Boolean parameter to use ONTAP REST APIs.
When set to true, Trident will use ONTAP REST APIs to communicate with the backend.
This feature requires ONTAP 9.11.1 and later. In addition, the ONTAP login role used must have access to the ontap application. This is satisfied by the pre-defined vsadmin and cluster-admin roles.
false
aws
You can specify the following in the configuration file for AWS FSx for ONTAP:
- fsxFilesystemID: Specify the ID of the AWS FSx file system.
- apiRegion: AWS API region name.
- apikey: AWS API key.
- secretKey: AWS secret key.
credentials
Specify the FSx SVM credentials to store in AWS Secrets Manager.
- name: Amazon Resource Name (ARN) of the secret, which contains the credentials of SVM.
- type: Set to awsarn.
Refer to Create an AWS Secrets Manager secret for more information.
Backend configuration options for provisioning volumes
You can control default provisioning using these options in the defaults section of the configuration. For an example, see the configuration examples below.
Parameter Description Default
spaceAllocation
Space-allocation for LUNs
true
spaceReserve
Space reservation mode; "none" (thin) or "volume" (thick)
none
snapshotPolicy
Snapshot policy to use
none
qosPolicy
QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool or backend.
Using QoS policy groups with Trident requires ONTAP 9.8 or later.
You should use a non-shared QoS policy group and ensuring the policy group is applied to each constituent individually. A shared QoS policy group enforces the ceiling for the total throughput of all workloads.
adaptiveQosPolicy
Adaptive QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool or backend.
Not supported by ontap-nas-economy.
snapshotReserve
Percentage of volume reserved for snapshots "0"
If snapshotPolicy is none, else ""
splitOnClone
Split a clone from its parent upon creation
false
encryption
Enable NetApp Volume Encryption (NVE) on the new volume; defaults to false. NVE must be licensed and enabled on the cluster to use this option.
If NAE is enabled on the backend, any volume provisioned in Trident will be NAE enabled.
For more information, refer to: How Trident works with NVE and NAE.
false
luksEncryption
Enable LUKS encryption. Refer to Use Linux Unified Key Setup (LUKS).
SAN only.
tieringPolicy
Tiering policy to use none
unixPermissions
Mode for new volumes.
Leave empty for SMB volumes.
securityStyle
Security style for new volumes.
NFS supports mixed and unix security styles.
SMB supports mixed and ntfs security styles.
NFS default is unix.
SMB default is ntfs.
