Upgrade a Trident installation using Trident operator or Helm
Contributors juliantap netapp-aruldeepa joan-ing netapp-shwetav netapp-dbagwell balaramesh netapp-mwallis
You can upgrade Trident using the Trident operator either manually or using Helm. You can upgrade from a Trident operator installation to another Trident operator installation or upgrade from a tridentctl installation to a Trident operator version. Review Select an upgrade method before upgrading a Trident operator installation.
Upgrade a manual installation
You can upgrade from a cluster-scoped Trident operator installation to another cluster-scoped Trident operator installation. All Trident versions use a cluster-scoped operator.
Note To upgrade from Trident that was installed using the namespace-scoped operator (versions 20.07 through 20.10), use the upgrade instructions for your installed version of Trident.
About this task
Trident provides a bundle file you can use to install the operator and create associated objects for your Kubernetes version.
Before you begin
Ensure you are using a Kubernetes cluster running a supported Kubernetes version.
Steps
  1. Verify your Trident version:
    ./tridentctl -n trident version
  2. Update the operator.yaml, tridentorchestrator_cr.yaml, and post_1_25_bundle.yaml with the registry and imagepaths for the version you are upgrading to (e.g.25.06), and the correct secret.
  3. Delete the Trident operator that was used to install the current Trident instance. For example, if you are upgrading from 25.02, run the following command:
    kubectl delete -f 25.02.0/trident-installer/deploy/<bundle.yaml> -n trident
  4. If you customized your initial installation using TridentOrchestrator attributes, you can edit the TridentOrchestrator object to modify the installation parameters. This might include changes made to specify mirrored Trident and CSI image registries for offline mode, enable debug logs, or specify image pull secrets.
  5. Install Trident using the correct bundle YAML file for your environment, where <bundle.yaml> is
    bundle_pre_1_25.yaml or bundle_post_1_25.yaml based on your Kubernetes version. For example, if you are installing Trident 25.06.0, run the following command:
    kubectl create -f 25.06.0/trident-installer/deploy/<bundle.yaml> -n trident
  6. Edit the trident torc to include the image 25.06.0.
Upgrade a Helm installation
You can upgrade a Trident Helm installation.
Warning When upgrading a Kubernetes cluster from 1.24 to 1.25 or later that has Trident installed, you must update values.yaml to set excludePodSecurityPolicy to true or add --set excludePodSecurityPolicy=true to the helm upgrade command before you can upgrade the cluster.
If you have already upgraded your Kubernetes cluster from 1.24 to 1.25 without upgrading the Trident helm, the helm upgrade fails. For the helm upgrade to go through, perform these steps as pre-requisites:
  1. Install the helm-mapkubeapis plugin from https://github.com/helm/helm-mapkubeapis.
  2. Perform a dry run for the Trident release in the namespace where Trident is installed. This lists out the resources, which will be cleaned up.
    helm mapkubeapis --dry-run trident  --namespace trident
  3. Perform a full run with helm to do the cleanup.
    helm mapkubeapis trident  --namespace trident
Steps
  1. If you installed Trident using Helm, you can use helm upgrade trident netapp-trident/trident-operator --version 100.2610.0 to upgrade in one step. If you did not add the Helm repo or cannot use it to upgrade:
    1. Download the latest Trident release from the Assets section on GitHub.
    2. Use the helm upgrade command where trident-operator-26.10.1.tgz reflects the version that you want to upgrade to.
      helm upgrade <name> trident-operator-26.10.1.tgz
      Note If you set custom options during the initial installation (such as specifying private, mirrored registries for Trident and CSI images), append the helm upgrade command using --set to ensure those options are included in the upgrade command, otherwise the values will reset to default.
  2. Run helm list to verify that the chart and app version have both been upgraded. Run tridentctl logs to review any debug messages.
Upgrade from a tridentctl installation to Trident operator
You can upgrade to the latest release of the Trident operator from a tridentctl installation. The existing backends and PVCs will automatically be available.
Note Before switching between installation methods, review Moving between installation methods.
Steps
  1. Download the latest Trident release.
    # Download the release required [26.10.1]
    mkdir 26.10.1
    cd 26.10.1
    wget https://github.com/NetApp/trident/releases/download/v26.10.1/trident-installer-26.10.1.tar.gz
    tar -xf trident-installer-26.10.1.tar.gz
    cd trident-installer
  2. Create the tridentorchestrator CRD from the manifest.
    kubectl create -f deploy/crds/trident.netapp.io_tridentorchestrators_crd_post1.16.yaml
  3. Deploy the cluster-scoped operator in the same namespace.
    kubectl create -f deploy/<bundle-name.yaml>
    serviceaccount/trident-operator created
    clusterrole.rbac.authorization.k8s.io/trident-operator created
    clusterrolebinding.rbac.authorization.k8s.io/trident-operator created
    deployment.apps/trident-operator created
    podsecuritypolicy.policy/tridentoperatorpods created
    #Examine the pods in the Trident namespace
    NAME                                  READY   STATUS    RESTARTS   AGE
    trident-controller-79df798bdc-m79dc   6/6     Running   0          150d
    trident-node-linux-xrst8              2/2     Running   0          150d
    trident-operator-5574dbbc68-nthjv     1/1     Running   0          1m30s
  4. Create a TridentOrchestrator CR for installing Trident.
    cat deploy/crds/tridentorchestrator_cr.yaml
    kind: TridentOrchestrator
    metadata:
    spec:
      debug: true
      namespace: trident
    kubectl create -f deploy/crds/tridentorchestrator_cr.yaml
    trident-csi-79df798bdc-m79dc        6/6     Running   0          1m
    trident-csi-xrst8                   2/2     Running   0          1m
    trident-operator-5574dbbc68-nthjv   1/1     Running   0          5m41s
  5. Confirm Trident was upgraded to the intended version.
    kubectl describe torc trident | grep Message -A 3
    Message:                Trident installed
    Namespace:              trident
    Status:                 Installed
    Version:                v26.10.0
