Deploy Trident operator using Helm (Standard mode)
You can deploy the Trident operator and install Trident using Helm. This process applies to installations where the container images required by Trident are not stored in a private registry. If you do have a private image registry, use the process for offline deployment.
Critical information about Trident 25.10
You must read the following critical information about Trident.
Kubernetes 1.35 is now supported in Trident. Upgrade Trident prior to upgrading Kubernetes.
Trident strictly enforces the use of multipathing configuration in SAN environments, with a recommended value of
find_multipaths: noin multipath.conf file.Use of non-multipathing configuration or use of
find_multipaths: yesorfind_multipaths: smartvalue in multipath.conf file will result in mount failures. Trident has recommended the use offind_multipaths: nosince the 21.07 release.
Deploy the Trident operator and install Trident using Helm
Using the Trident Helm Chart you can deploy the Trident operator and install Trident in one step.
Review the installation overview to ensure you've met installation prerequisites and selected the correct installation option for your environment.
In addition to the deployment prerequisites you need Helm version 3.
Add the Trident Helm repository:
helm repo add netapp-trident https://netapp.github.io/trident-helm-chart
Use
helm installand specify a name for your deployment as in the following example where100..0is the version of Trident you are installing.helm install <name> netapp-trident/trident-operator --version 100.2602.0 --create-namespace --namespace <trident-namespace>
If you already created a namespace for Trident, the --create-namespaceparameter will not create an additional namespace.
You can use helm list to review installation details such as name, namespace, chart, status, app version, and revision number.
Pass configuration data during install
There are two ways to pass configuration data during the install:
| Option | Description |
Specify a YAML file with overrides. This can be specified multiple times and the rightmost file will take precedence. |
Specify overrides on the command line. |
For example, to change the default value of debug, run the following command where 100.2602.0 is the version of Trident you are installing:
helm install <name> netapp-trident/trident-operator --version 100.2602.0 --create-namespace --namespace trident --set tridentDebug=true
Configuration options
This table and the values.yaml file, which is part of the Helm chart, provide the list of keys and their default values.
| Option | Description | Default | ||||
Node labels for pod assignment |
Pod annotations |
Deployment annotations |
Tolerations for pod assignment |
Affinity for pod assignment |
affinity:
nodeAffinity:
requiredDuringSchedulingIgnoredDuringExecution:
nodeSelectorTerms:
- matchExpressions:
- key: kubernetes.io/arch
operator: In
values:
- arm64
- amd64
- key: kubernetes.io/os
operator: In
values:
- linux
Additional node selectors for pods. Refer to Understanding controller pods and node pods for details. |
Overrides Kubernetes tolerations for pods. Refer to Understanding controller pods and node pods for details. |
Identifies the registry for the |
Sets the image pull policy for the |
Sets the image pull secrets for the |
Allows overriding the host location of kubelet's internal state. |
Allows the log level of the Trident operator to be set to: |
Allows the log level of the Trident operator to be set to debug. |
Allows the complete override of the image for |
Allows overriding the tag of the |
Allows enabling Trident to work in IPv6 clusters. |
Overrides the default 30-second timeout for most Kubernetes API operations (if non-zero, in seconds). |
Overrides the default 90-second timeout for the HTTP requests, with |
Allows disabling Trident periodic AutoSupport reporting. |
Allows overriding the tag of the image for Trident AutoSupport container. |
Enables Trident AutoSupport container to phone home via an HTTP proxy. |
Sets the Trident logging format ( |
Disables Trident audit logger. |
Allows the log level of Trident to be set to: |
Allows the log level of Trident to be set to |
Allows specific Trident workflows to be enabled for trace logging or log suppression. |
Allows specific Trident layers to be enabled for trace logging or log suppression. |
Allows the complete override of the image for Trident. |
Allows overriding the tag of the image for Trident. |
Allows overriding the default port used for Kubernetes liveness/readiness probes. |
Enables Trident to be installed on Windows worker node. |
Allows enabling the force detach feature. |
Excludes the operator pod security policy from creation. |
Set to |
Set to workload identity ("azure.workload.identity/client-id: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx") when using cloud identity on an AKS cluster. Set to AWS IAM role ("'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/trident-role'") when using cloud identity on an EKS cluster. |
The interval at which the iSCSI self-healing is invoked. |
The duration after which iSCSI self-healing initiates an attempt to resolve a stale session by performing a logout and subsequent login. |
Enables Trident to prepare the nodes of the Kubernetes cluster to manage volumes using the specified data storage protocol. |
Enables concurrent Trident controller operations for improved throughput.
false |
The queries per second (QPS) limit used by the controller while communicating with the Kubernetes API server. The Burst value is set automatically based on the QPS value. |
Sets Kubernetes resource limits and requests for the Trident controller, node, and operator pods. You can configure CPU and memory for each container and sidecar to manage resource allocation in Kubernetes. For more information about configuring resource requests and limits, refer to Resource Management for Pods and Containers.
Enable HTTPS for Prometheus metrics endpoint. |
false |
Enables host networking for the Trident controller. This is useful when you want to separate the frontend and backend traffic in a multi-home network. |
false |
Trident runs as a single controller pod, plus a node pod on each worker node in the cluster. The node pod must be running on any host where you want to potentially mount a Trident volume.
Kubernetes node selectors and tolerations and taints are used to constrain a pod to run on a specific or preferred node. Using the`ControllerPlugin` and NodePlugin, you can specify constraints and overrides.
The controller plugin handles volume provisioning and management, such as snapshots and resizing.
The node plugin handles attaching the storage to the node.
