Deploy Trident operator using Helm (Offline mode)
Contributors netapp-aruldeepa juliantap joan-ing netapp-mwallis
You can deploy the Trident operator and install Trident using Helm. This process applies to installations where the container images required by Trident are stored in a private registry. If you do not have a private image registry, use the process for standard deployment.
Critical information about Trident 26.02
You must read the following critical information about Trident.
  • Kubernetes 1.35 is now supported in Trident. Upgrade Trident prior to upgrading Kubernetes.
  • Trident strictly enforces the use of multipathing configuration in SAN environments, with a recommended value of find_multipaths: no in multipath.conf file.
    Use of non-multipathing configuration or use of find_multipaths: yes or find_multipaths: smart value in multipath.conf file will result in mount failures. Trident has recommended the use of find_multipaths: no since the 21.07 release.
Deploy the Trident operator and install Trident using Helm
Using the Trident Helm Chart you can deploy the Trident operator and install Trident in one step.
Review the installation overview to ensure you've met installation prerequisites and selected the correct installation option for your environment.
Before you begin
In addition to the deployment prerequisites you need Helm version 3.
Important When installing Trident in a private repository, if you are using the imageRegistry switch to specify the repository location, do not use /netapp/ in the repository path.
Steps
  1. Add the Trident Helm repository:
    helm repo add netapp-trident https://netapp.github.io/trident-helm-chart
  2. Use helm install and specify a name for your deployment and image registry location. Your Trident and CSI images can be located in one registry or different registries, but all CSI images must be located in the same registry. In the examples, 100.2602.0 is the version of Trident you are installing.
    Images in one registry
    helm install <name> netapp-trident/trident-operator --version 100.2602.0 --set imageRegistry=<your-registry> --create-namespace --namespace <trident-namespace> --set nodePrep={iscsi}
    Images in different registries
    helm install <name> netapp-trident/trident-operator --version 100.2602.0 --set imageRegistry=<your-registry> --set operatorImage=<your-registry>/trident-operator:26.02.0 --set tridentAutosupportImage=<your-registry>/trident-autosupport:26.02 --set tridentImage=<your-registry>/trident:26.02.0 --create-namespace --namespace <trident-namespace> --set nodePrep={iscsi}
    Note If you already created a namespace for Trident, the --create-namespace parameter will not create an additional namespace.
You can use helm list to review installation details such as name, namespace, chart, status, app version, and revision number.
Pass configuration data during install
There are two ways to pass configuration data during the install:
Option Description
--values (or -f)
Specify a YAML file with overrides. This can be specified multiple times and the rightmost file will take precedence.
--set
Specify overrides on the command line.
For example, to change the default value of debug, run the following command where 100.2602.0 is the version of Trident you are installing:
helm install <name> netapp-trident/trident-operator --version 100.2602.0  --create-namespace --namespace trident --set tridentDebug=true
To add the nodePrep value, run the following command:
helm install <name> netapp-trident/trident-operator --version 100.2602.0  --create-namespace --namespace trident --set nodePrep={iscsi}
Configuration options
This table and the values.yaml file, which is part of the Helm chart, provide the list of keys and their default values.
Warning Do not remove the default affinity from the values.yaml file. When you want to provide a custom affinity, extend the default affinity.
Option Description Default
nodeSelector
Node labels for pod assignment
podAnnotations
Pod annotations
deploymentAnnotations
Deployment annotations
tolerations
Tolerations for pod assignment
affinity
Affinity for pod assignment
affinity:
  nodeAffinity:
    requiredDuringSchedulingIgnoredDuringExecution:
      nodeSelectorTerms:
        - matchExpressions:
            - key: kubernetes.io/arch
              operator: In
              values:
              - arm64
              - amd64
            - key: kubernetes.io/os
              operator: In
              values:
              - linux
tridentControllerPluginNodeSelector
Additional node selectors for pods. Refer to Understanding controller pods and node pods for details.
tridentControllerPluginTolerations
Overrides Kubernetes tolerations for pods. Refer to Understanding controller pods and node pods for details.
tridentNodePluginNodeSelector
tridentNodePluginTolerations
imageRegistry
Identifies the registry for the trident-operator, trident, and other images. Leave empty to accept the default.
IMPORTANT: When installing Trident in a private repository, if you are using the imageRegistry switch to specify the repository location, do not use /netapp/ in the repository path.
imagePullPolicy
Sets the image pull policy for the trident-operator.
IfNotPresent
imagePullSecrets
Sets the image pull secrets for the trident-operator, trident, and other images.
kubeletDir
Allows overriding the host location of kubelet's internal state.
"/var/lib/kubelet"
operatorLogLevel
Allows the log level of the Trident operator to be set to: trace, debug, info, warn, error, or fatal.
"info"
operatorDebug
Allows the log level of the Trident operator to be set to debug.
true
operatorImage
Allows the complete override of the image for trident-operator.
operatorImageTag
Allows overriding the tag of the trident-operator image.
tridentIPv6
Allows enabling Trident to work in IPv6 clusters.
false
tridentK8sTimeout
Overrides the default 180-second timeout for most Kubernetes API operations (if non-zero, in seconds).
Note The tridentK8sTimeout parameter is applicable only for Trident installation.
180
tridentHttpRequestTimeout
Overrides the default 90-second timeout for the HTTP requests, with 0s being an infinite duration for the timeout. Negative values are not allowed.
"90s"
tridentSilenceAutosupport
Allows disabling Trident periodic AutoSupport reporting.
false
tridentAutosupportImageTag
Allows overriding the tag of the image for Trident AutoSupport container.
<version>
tridentAutosupportProxy
Enables Trident AutoSupport container to phone home via an HTTP proxy.
tridentLogFormat
Sets the Trident logging format (text or json).
"text"
tridentDisableAuditLog
Disables Trident audit logger.
true
tridentLogLevel
Allows the log level of Trident to be set to: trace, debug, info, warn, error, or fatal.
"info"
tridentDebug
Allows the log level of Trident to be set to debug.
false
tridentLogWorkflows
Allows specific Trident workflows to be enabled for trace logging or log suppression.
tridentLogLayers
Allows specific Trident layers to be enabled for trace logging or log suppression.
tridentImage
Allows the complete override of the image for Trident.
tridentImageTag
Allows overriding the tag of the image for Trident.
tridentProbePort
Allows overriding the default port used for Kubernetes liveness/readiness probes.
windows
Enables Trident to be installed on Windows worker node.
false
enableForceDetach
Allows enabling the force detach feature.
You can automate the force-detach process through integration with node health check (NHC) operator. For information, see Automating the failover of stateful applications with Trident.
false
excludePodSecurityPolicy
Excludes the operator pod security policy from creation.
false
nodePrep
Enables Trident to prepare the nodes of the Kubernetes cluster to manage volumes using the specified data storage protocol.
Currently, iscsi is the only value supported.
Note Beginning with OpenShift 4.19, the minimum Trident version supported for this feature is 25.06.1.
resources
Sets Kubernetes resource limits and requests for the Trident controller, node, and operator pods. You can configure CPU and memory for each container and sidecar to manage resource allocation in Kubernetes.
For more information about configuring resource requests and limits, refer to Resource Management for Pods and Containers.
Warning
  • DO NOT change the names of any containers or fields.
  • DO NOT change the indentation - YAML indentation is critical for proper parsing.
Note
  • No limits are applied by default - only requests have default values.
  • Container names are listed as they appear in the pod specifications.
  • Sidecars are listed under each main container.
  • Check the TORC's status.CurrentInstallationParams field to view the values currently applied.
resources:
  controller:
    trident-main:
      requests:
        cpu: 10m
        memory: 80Mi
      limits:
          cpu:
          memory:
    csi-provisioner:
      requests:
        cpu: 2m
        memory: 20Mi
      limits:
        cpu:
        memory:
    csi-attacher:
      requests:
        cpu: 2m
        memory: 20Mi
      limits:
        cpu:
        memory:
    csi-resizer:
      requests:
        cpu: 3m
        memory: 20Mi
      limits:
        cpu:
        memory:
    csi-snapshotter:
      requests:
        cpu: 2m
        memory: 20Mi
      limits:
        cpu:
        memory:
      requests:
        cpu: 1m
        memory: 30Mi
      limits:
        cpu:
        memory:
  node:
    linux:
      trident-main:
        requests:
          cpu: 10m
          memory: 60Mi
        limits:
          cpu:
          memory:
      node-driver-registrar:
        requests:
          cpu: 1m
          memory: 10Mi
        limits:
          cpu:
          memory:
    windows:
      trident-main:
        requests:
          cpu: 6m
          memory: 40Mi
        limits:
          cpu:
          memory:
        requests:
          cpu: 6m
          memory: 40Mi
        limits:
          cpu:
          memory:
      liveness-probe:
        requests:
          cpu: 2m
          memory: 40Mi
        limits:
          cpu:
          memory:
  operator:
    requests:
      cpu: 10m
      memory: 40Mi
    limits:
      cpu:
      memory:
