Upgrade with the operator
You can easily upgrade an existing Astra Trident installation using the operator.
To upgrade using the operator, the following conditions should be met:
You must have a CSI-based Astra Trident installation. All releases from 19.07 on are CSI-based. You can examine the pods in your Trident namespace to verify.
Pod naming in versions earlier than 23.01 follows a
trident-csi-*convention. -
Pod naming in 23.01 and later uses:
trident-controller-<generated id>for the controller pod;trident-node-<operating system>-<generated id>for the node pods;trident-operator-<generated id>for the operator pod.
If you have uninstalled CSI Trident and the metadata from the installation persists, you can upgrade by using the operator.
Only one Astra Trident installation should exist across all the namespaces in a given Kubernetes cluster.
You should be using a Kubernetes cluster running a supported Kubernetes version.
If alpha snapshot CRDs are present, you should remove them with
tridentctl obliviate alpha-snapshot-crd. This deletes the CRDs for the alpha snapshot spec. For existing snapshots that should be deleted/migrated, see this blog.
Upgrade a cluster-scoped Trident operator installation
Follow these steps to upgrade a cluster-scoped Trident operator installation. All Astra Trident versions 21.01 and above use a cluster-scoped operator.
Verify your Astra Trident version:
./tridentctl -n trident version
Delete the Trident operator that was used to install the current Astra Trident instance. For example, if you are upgrading from 22.01, run the following command:
kubectl delete -f 22.01/trident-installer/deploy/bundle.yaml -n trident
If you customized your initial installation using
TridentOrchestratorattributes, you can edit theTridentOrchestratorobject to modify the installation parameters. This might include changes made to specify mirrored Trident and CSI image registries for offline mode, enable debug logs, or specify image pull secrets. -
Install Astra Trident using the correct bundle YAML file for your environment and Astra Trident version. For example, if you are installing Astra Trident 23.01 for Kubernetes 1.26, run the following command:
kubectl create -f 23.01.1/trident-installer/deploy/bundle_post_1_25.yaml -n trident
Trident provides a bundle file that can be used to install the operator and create associated objects for your Kubernetes version.
For clusters running Kubernetes 1.24 or lower, use bundle_pre_1_25.yaml.
For clusters running Kubernetes 1.25 or higher, use bundle_post_1_25.yaml.
The Trident operator will identify an existing Astra Trident installation and upgrade it to the same version as the operator.
Upgrade a namespace-scoped operator installation
Follow these steps to upgrade from an instance of Astra Trident installed using the namespace-scoped operator (versions 20.07 through 20.10).
Verify the status of the existing Trident installation. To do this, check the Status of
TridentProvisioner. The status should beInstalled.kubectl describe tprov trident -n trident | grep Message: -A 3 Message: Trident installed Status: Installed Version: v20.10.1
If status shows Updating, ensure you resolve it before proceeding. For a list of possible status values, see here. -
Create the
TridentOrchestratorCRD by using the manifest provided with the Trident installer.# Download the release required [23.01.1] mkdir 23.01.1 cd 23.01.1 wget https://github.com/NetApp/trident/releases/download/v23.01.1/trident-installer-23.01.1.tar.gz tar -xf trident-installer-23.01.1.tar.gz cd trident-installer kubectl create -f deploy/crds/trident.netapp.io_tridentorchestrators_crd_post1.16.yaml
Delete the namespace-scoped operator by using its manifest. To complete this step, you need the bundle YAML file used to deploy the namespace-scoped operator from
https://github.com/NetApp/trident/tree/stable/vXX.XX/deploy/BUNDLE.YAMLwherevXX.XXis the version number andBUNDLE.YAMLis the bundle YAML file name.You should make the necessary changes to the Trident install parameters (for example, changing the values for tridentImage,autosupportImage, private image repository, and providingimagePullSecrets) after deleting the namespace-scoped operator and before installing the cluster-scoped operator. For a complete list of parameters that can be updated, refer to the configuration options.#Ensure you are in the right directory pwd /root/20.10.1/trident-installer #Delete the namespace-scoped operator kubectl delete -f deploy/<BUNDLE.YAML> -n trident serviceaccount "trident-operator" deleted clusterrole.rbac.authorization.k8s.io "trident-operator" deleted clusterrolebinding.rbac.authorization.k8s.io "trident-operator" deleted deployment.apps "trident-operator" deleted podsecuritypolicy.policy "tridentoperatorpods" deleted #Confirm the Trident operator was removed kubectl get all -n trident NAME READY STATUS RESTARTS AGE pod/trident-csi-68d979fb85-dsrmn 6/6 Running 12 99d pod/trident-csi-8jfhf 2/2 Running 6 105d pod/trident-csi-jtnjz 2/2 Running 6 105d pod/trident-csi-lcxvh 2/2 Running 8 105d NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE service/trident-csi ClusterIP 10.108.174.125 <none> 34571/TCP,9220/TCP 105d NAME DESIRED CURRENT READY UP-TO-DATE AVAILABLE NODE SELECTOR AGE daemonset.apps/trident-csi 3 3 3 3 3 kubernetes.io/arch=amd64,kubernetes.io/os=linux 105d NAME READY UP-TO-DATE AVAILABLE AGE deployment.apps/trident-csi 1/1 1 1 105d NAME DESIRED CURRENT READY AGE replicaset.apps/trident-csi-68d979fb85 1 1 1 105d
At this stage, the
trident-operator-xxxxxxxxxx-xxxxxpod is deleted. -
(Optional) If the install parameters need to be modified, update the
TridentProvisionerspec. These could be changes such as modifying the private image registry to pull container images from, enabling debug logs, or specifying image pull secrets.kubectl patch tprov <trident-provisioner-name> -n <trident-namespace> --type=merge -p '{"spec":{"debug":true}}' -
Install the Trident operator.
Installing the cluster-scoped operator initiates the migration of TridentProvisionerobjects toTridentOrchestratorobjects, deletesTridentProvisionerobjects and thetridentprovisionerCRD, and upgrades Astra Trident to the version of the cluster-scoped operator being used. In the example that follows, Trident is upgraded to 23.01.1.Upgrading Astra Trident using the Trident operator results in the migration of tridentProvisionerto atridentOrchestratorobject with the same name. This is automatically handled by the operator. The upgrade will also have Astra Trident installed in the same namespace as before.#Ensure you are in the correct directory pwd /root/23.01.1/trident-installer #Install the cluster-scoped operator in the **same namespace** kubectl create -f deploy/<BUNDLE.YAML> serviceaccount/trident-operator created clusterrole.rbac.authorization.k8s.io/trident-operator created clusterrolebinding.rbac.authorization.k8s.io/trident-operator created deployment.apps/trident-operator created podsecuritypolicy.policy/tridentoperatorpods created #All tridentProvisioners will be removed, including the CRD itself kubectl get tprov -n trident Error from server (NotFound): Unable to list "trident.netapp.io/v1, Resource=tridentprovisioners": the server could not find the requested resource (get tridentprovisioners.trident.netapp.io) #tridentProvisioners are replaced by tridentOrchestrator kubectl get torc NAME AGE trident 13s #Examine Trident pods in the namespace kubectl get pods -n trident NAME READY STATUS RESTARTS AGE trident-controller-79df798bdc-m79dc 6/6 Running 0 1m41s trident-node-linux-xrst8 2/2 Running 0 1m41s trident-operator-5574dbbc68-nthjv 1/1 Running 0 1m52s #Confirm Trident has been updated to the desired version kubectl describe torc trident | grep Message -A 3 Message: Trident installed Namespace: trident Status: Installed Version: v23.01.1
The trident-controllerand pod names reflect the naming convention introduced in 23.01.
Upgrade a Helm-based operator installation
Perform the following steps to upgrade a Helm-based operator installation.
When upgrading a Kubernetes cluster from 1.24 to 1.25 or later that has Astra Trident installed, you must update values.yaml to set excludePodSecurityPolicy to true or add --set excludePodSecurityPolicy=true to the helm upgrade command before you can upgrade the cluster.
Download the latest Astra Trident release.
Use the
helm upgradecommand wheretrident-operator-23.01.1.tgzreflects the version that you want to upgrade to.helm upgrade <name> trident-operator-23.01.1.tgz
If you set any non-default options during the initial installation (such as specifying private, mirrored registries for Trident and CSI images), use
--setto ensure those options are included in the upgrade command, otherwise the values will reset to default.For example, to change the default value of
tridentDebug, run the following command:helm upgrade <name> trident-operator-23.01.1-custom.tgz --set tridentDebug=true
Run
helm listto verify that the chart and app version have both been upgraded. Runtridentctl logsto review any debug messages.
Upgrade from a non-operator installation
You can upgrade to the latest release of the Trident operator from a tridentctl installation.
# Download the release required [23.01.1] mkdir 23.01.1 cd 23.01.1 wget https://github.com/NetApp/trident/releases/download/v22.01.1/trident-installer-23.01.1.tar.gz tar -xf trident-installer-23.01.1.tar.gz cd trident-installer
Create the
tridentorchestratorCRD from the manifest.kubectl create -f deploy/crds/trident.netapp.io_tridentorchestrators_crd_post1.16.yaml
Deploy the operator.
#Install the cluster-scoped operator in the **same namespace** kubectl create -f deploy/<BUNDLE.YAML> serviceaccount/trident-operator created clusterrole.rbac.authorization.k8s.io/trident-operator created clusterrolebinding.rbac.authorization.k8s.io/trident-operator created deployment.apps/trident-operator created podsecuritypolicy.policy/tridentoperatorpods created #Examine the pods in the Trident namespace NAME READY STATUS RESTARTS AGE trident-controller-79df798bdc-m79dc 6/6 Running 0 150d trident-node-linux-xrst8 2/2 Running 0 150d trident-operator-5574dbbc68-nthjv 1/1 Running 0 1m30s
Create a
TridentOrchestratorCR for installing Astra Trident.#Create a tridentOrchestrator to initiate a Trident install cat deploy/crds/tridentorchestrator_cr.yaml apiVersion: trident.netapp.io/v1 kind: TridentOrchestrator metadata: name: trident spec: debug: true namespace: trident kubectl create -f deploy/crds/tridentorchestrator_cr.yaml #Examine the pods in the Trident namespace NAME READY STATUS RESTARTS AGE trident-csi-79df798bdc-m79dc 6/6 Running 0 1m trident-csi-xrst8 2/2 Running 0 1m trident-operator-5574dbbc68-nthjv 1/1 Running 0 5m41s #Confirm Trident was upgraded to the desired version kubectl describe torc trident | grep Message -A 3 Message: Trident installed Namespace: trident Status: Installed Version: v23.01.1
The existing backends and PVCs are automatically available.
