Configure the Storage Backend
Contributors netapp-aruldeepa kcantrel joan-ing netapp-mwallis
Overview
Before you can provision volumes using Trident, you need to integrate your storage backend with Trident by creating a Trident Backend Configuration (TBC). The TBC defines how Trident connects to the storage backend and provides the necessary information for Trident to manage the storage resources.
Create a Trident Backend Configuration (TBC) for FSx for ONTAP
There are two ways to configure the Trident backend to use an FSx for ONTAP file system:
* Create a StorageClass that leverages the Automatic Backend feature.
* Create the backend and StorageClass separately.
The steps in this section cover how to create the backend separately. For information on how to use the Automatic Backend feature, refer to the Configure StorageClass and PVC section for more information.
To create a storage backend, you need to create a configuration file in either JSON or YAML format. The file needs to specify the type of storage you want (NAS or SAN), the file system, and SVM to get it from and how to authenticate with it. The following example shows how to define NAS-based storage and using an AWS secret to store the credentials to the SVM you want to use:
YAML
kind: TridentBackendConfig
metadata:
  namespace: trident
spec:
  version: 1
  storageDriverName: ontap-nas
  backendName: tbc-ontap-nas
  svm: svm-name
  aws:
    fsxFilesystemID: fs-xxxxxxxxxx
  credentials:
    type: awsarn
JSON
  "apiVersion": "trident.netapp.io/v1",
  "kind": "TridentBackendConfig",
  "metadata": {
    "name": "backend-tbc-ontap-nas"
    "namespace": "trident"
  "spec": {
    "version": 1,
    "storageDriverName": "ontap-nas",
    "backendName": "tbc-ontap-nas",
    "svm": "svm-name",
    "aws": {
      "fsxFilesystemID": "fs-xxxxxxxxxx"
    "managementLIF": null,
    "credentials": {
      "name": "arn:aws:secretsmanager:us-west-2:xxxxxxxx:secret:secret-name",
      "type": "awsarn"
Run the following commands to create and validate the Trident Backend Configuration (TBC):
  • Create trident backend configuration (TBC) from yaml file and run the following command:
    kubectl create -f backendconfig.yaml -n trident
    tridentbackendconfig.trident.netapp.io/backend-tbc-ontap-nas created
  • Validate the trident backend configuration (TBC) was created successfully:
    Kubectl get tbc -n trident
    NAME                         BACKEND NAME         BACKEND UUID                           PHASE   STATUS
    backend-tbc-ontap-nas        tbc-ontap-nas        933e0071-66ce-4324-b9ff-f96d916ac5e9   Bound   Success
FSx for ONTAP driver details
You can integrate Trident with Amazon FSx for NetApp ONTAP using the following drivers:
  • ontap-san: Each PV provisioned is a LUN within its own Amazon FSx for NetApp ONTAP volume. Recommended for block storage.
  • ontap-nas: Each PV provisioned is a full Amazon FSx for NetApp ONTAP volume. Recommended for NFS and SMB.
  • ontap-san-economy: Each PV provisioned is a LUN with a configurable number of LUNs per Amazon FSx for NetApp ONTAP volume.
  • ontap-nas-economy: Each PV provisioned is a qtree, with a configurable number of qtrees per Amazon FSx for NetApp ONTAP volume.
  • ontap-nas-flexgroup: Each PV provisioned is a full Amazon FSx for NetApp ONTAP FlexGroup volume.
For driver details, refer to NAS drivers and SAN drivers.
Once the configuration file has been created, run this command to create it within your EKS:
kubectl create -f configuration_file
To verify the status, run this command:
kubectl get tbc -n trident
backend-fsx-ontap-nas   backend-fsx-ontap-nas   7a551921-997c-4c37-a1d1-f2f4c87fa629   Bound   Success
Backend advanced configuration and examples
See the following table for the backend configuration options:
Parameter Description Example
version
Always 1
storageDriverName
Name of the storage driver.
Cannot be modified after creation. To update this parameter, you must create a new backend.
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, ontap-san-economy
backendName
Custom name or the storage backend
Driver name + "_" + dataLIF
managementLIF
IP address of a cluster or SVM management LIF
A fully-qualified domain name (FQDN) can be specified.
Can be set to use IPv6 addresses if Trident was installed using the IPv6 flag. IPv6 addresses must be defined in square brackets, such as [28e8:d9fb:a825:b7bf:69a8:d02f:9e7b:3555].
If you provide the fsxFilesystemID under the aws field, you need not to provide the managementLIF because Trident retrieves the SVM managementLIF information from AWS. So, you must provide credentials for a user under the SVM (For example: vsadmin) and the user must have the vsadmin role.
"10.0.0.1", "[2001:1234:abcd::fefe]"
dataLIF
IP address of protocol LIF.
ONTAP NAS drivers: NetApp recommends specifying dataLIF. If not provided, Trident fetches dataLIFs from the SVM. You can specify a fully-qualified domain name (FQDN) to be used for the NFS mount operations, allowing you to create a round-robin DNS to load-balance across multiple dataLIFs. Can be changed after initial setting. Refer to Update dataLIF after initial configuration.
ONTAP SAN drivers: Do not specify for iSCSI. Trident uses ONTAP Selective LUN Map to discover the iSCI LIFs needed to establish a multi path session. A warning is generated if dataLIF is explicitly defined.
autoExportPolicy
Enable automatic export policy creation and updating [Boolean].
Using the autoExportPolicy and autoExportCIDRs options, Trident can manage export policies automatically.
false
autoExportCIDRs
List of CIDRs to filter Kubernetes' node IPs against when autoExportPolicy is enabled.
"["0.0.0.0/0", "::/0"]"
labels
Set of arbitrary JSON-formatted labels to apply on volumes
clientCertificate
Base64-encoded value of client certificate. Used for certificate-based auth
clientPrivateKey
Base64-encoded value of client private key. Used for certificate-based auth
trustedCACertificate
Base64-encoded value of trusted CA certificate. Optional. Used for certificate-based authentication.
username
Username to connect to the cluster or SVM. Used for credential-based authentication. For example, vsadmin.
password
Password to connect to the cluster or SVM. Used for credential-based authentication.
svm
Storage virtual machine to use
Derived if an SVM managementLIF is specified.
storagePrefix
Prefix used when provisioning new volumes in the SVM.
Cannot be modified after creation. To update this parameter, you will need to create a new backend.
trident
NOTE: Backend configuration parameters that affect backend identity and volume naming, such as storageDriverName and storagePrefix, cannot be changed after creation. To update them, you must create a new backend.
limitAggregateUsage
Do not specify for Amazon FSx for NetApp ONTAP.
The provided fsxadmin and vsadmin do not contain the permissions required to retrieve aggregate usage and limit it using Trident.
Do not use.
limitVolumeSize
Fail provisioning if requested volume size is above this value.
Also restricts the maximum size of the volumes it manages for qtrees and LUNs, and the qtreesPerFlexvol option allows customizing the maximum number of qtrees per FlexVol volume
"" (not enforced by default)
lunsPerFlexvol
Maximum LUNs per Flexvol volume, must be in range [50, 200].
SAN only.
“100”
debugTraceFlags
Debug flags to use when troubleshooting. Example, {"api":false, "method":true}
Do not use debugTraceFlags unless you are troubleshooting and require a detailed log dump.
null
nfsMountOptions
Comma-separated list of NFS mount options.
The mount options for Kubernetes-persistent volumes are normally specified in storage classes, but if no mount options are specified in a storage class, Trident will fall back to using the mount options specified in the storage backend's configuration file.
If no mount options are specified in the storage class or the configuration file, Trident will not set any mount options on an associated persistent volume.
nasType
Configure NFS or SMB volumes creation.
Options are nfs, smb, or null.
Must set to smb for SMB volumes. Setting to null defaults to NFS volumes.
nfs
qtreesPerFlexvol
Maximum Qtrees per FlexVol volume, must be in range [50, 300]
"200"
smbShare
You can specify one of the following: the name of an SMB share created using the Microsoft Management Console or ONTAP CLI or a name to allow Trident to create the SMB share.
This parameter is required for Amazon FSx for ONTAP backends.
smb-share
useREST
Boolean parameter to use ONTAP REST APIs.
When set to true, Trident will use ONTAP REST APIs to communicate with the backend.
This feature requires ONTAP 9.11.1 and later. In addition, the ONTAP login role used must have access to the ontap application. This is satisfied by the pre-defined vsadmin and cluster-admin roles.
false
aws
You can specify the following in the configuration file for AWS FSx for ONTAP:
- fsxFilesystemID: Specify the ID of the AWS FSx file system.
- apiRegion: AWS API region name.
- apikey: AWS API key.
- secretKey: AWS secret key.
credentials
Specify the FSx SVM credentials to store in AWS Secrets Manager.
- name: Amazon Resource Name (ARN) of the secret, which contains the credentials of SVM.
- type: Set to awsarn.
Refer to Create an AWS Secrets Manager secret for more information.
Backend configuration options for provisioning volumes
You can control default provisioning using these options in the defaults section of the configuration. For an example, see the configuration examples below.
Parameter Description Default
spaceAllocation
Space-allocation for LUNs
true
spaceReserve
Space reservation mode; "none" (thin) or "volume" (thick)
none
snapshotPolicy
Snapshot policy to use
none
qosPolicy
QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool or backend.
Using QoS policy groups with Trident requires ONTAP 9.8 or later.
You should use a non-shared QoS policy group and ensuring the policy group is applied to each constituent individually. A shared QoS policy group enforces the ceiling for the total throughput of all workloads.
adaptiveQosPolicy
Adaptive QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool or backend.
Not supported by ontap-nas-economy.
snapshotReserve
Percentage of volume reserved for snapshots "0"
If snapshotPolicy is none, else ""
splitOnClone
Split a clone from its parent upon creation
false
encryption
Enable NetApp Volume Encryption (NVE) on the new volume; defaults to false. NVE must be licensed and enabled on the cluster to use this option.
If NAE is enabled on the backend, any volume provisioned in Trident will be NAE enabled.
For more information, refer to: How Trident works with NVE and NAE.
false
luksEncryption
Enable LUKS encryption. Refer to Use Linux Unified Key Setup (LUKS).
SAN only.
tieringPolicy
Tiering policy to use none
unixPermissions
Mode for new volumes.
Leave empty for SMB volumes.
securityStyle
Security style for new volumes.
NFS supports mixed and unix security styles.
SMB supports mixed and ntfs security styles.
NFS default is unix.
SMB default is ntfs.
Provision SMB volumes
You can provision SMB volumes using the ontap-nas driver.
Before you complete ONTAP SAN and NAS driver integration complete these steps: Prepare to provision SMB volumes.
