Use Trident Protect AppVault objects to manage buckets
The bucket custom resource (CR) for Trident Protect is known as an AppVault. AppVault objects are the declarative Kubernetes workflow representation of a storage bucket. An AppVault CR contains the configurations necessary for a bucket to be used in protection operations, such as backups, snapshots, restore operations, and SnapMirror replication. Only administrators can create AppVaults.
You need to create an AppVault CR manually or from the command line when you perform data protection operations on an application. The AppVault CR is specific to your environment, and you can use the examples on this page as a guide when creating AppVault CRs.
Ensure the AppVault CR is on the cluster where Trident Protect is installed. If the AppVault CR does not exist or you cannot access it, the command line shows an error. |
Configure AppVault authentication and passwords
Before you create an AppVault CR, ensure the AppVault and the data mover you choose can authenticate with the provider and any related resources.
Data mover repository passwords
When you create AppVault objects using CRs or the Trident Protect CLI plugin, you can specify a Kubernetes secret with custom passwords for Restic and Kopia encryption. If you don't specify a secret, Trident Protect uses a default password.
When manually creating AppVault CRs, use the spec.dataMoverPasswordSecretRef field to specify the secret.
When creating AppVault objects using the Trident Protect CLI, use the
--data-mover-password-secret-refargument to specify the secret.
To encrypt snapshot and backup metadata or to change the vault password, use the spec.vaultPasswordSecretRef field. Refer to Encrypt AppVault metadata for Trident Protect snapshots and backups.
Create a data mover repository password secret
Use the following examples to create the password secret. When you create AppVault objects, you can instruct Trident Protect to use this secret to authenticate with the data mover repository.
apiVersion: v1
data:
KOPIA_PASSWORD: <base64-encoded-password>
RESTIC_PASSWORD: <base64-encoded-password>
kind: Secret
metadata:
namespace: trident-protect
type: Opaque
kubectl create secret generic my-optional-data-mover-secret \
--from-literal=KOPIA_PASSWORD=<plain-text-password> \
--from-literal=RESTIC_PASSWORD=<plain-text-password> \
-n trident-protect
S3-compatible storage IAM permissions
When you access S3-compatible storage such as Amazon S3, Generic S3, StorageGrid S3, or ONTAP S3 using Trident Protect, you need to ensure that the user credentials you provide have the necessary permissions to access the bucket. The following is an example of a policy that grants the minimum required permissions for access with Trident Protect. You can apply this policy to the user that manages S3-compatible bucket policies.
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": [
"s3:PutObject",
"s3:GetObject",
"s3:ListBucket",
"s3:DeleteObject"
"Resource": "*"
For more information about Amazon S3 policies, refer to the examples in the Amazon S3 documentation.
EKS Pod Identity for Amazon S3 (AWS) authentication
Trident Protect supports EKS Pod Identity for Kopia data mover operations. This feature enables secure access to S3 buckets without storing AWS credentials in Kubernetes secrets.
Requirements for EKS Pod Identity with Trident Protect
Before using EKS Pod Identity with Trident Protect, ensure the following:
Your EKS cluster has Pod Identity enabled.
You have created an IAM role with the necessary S3 bucket permissions. To learn more, refer to S3-compatible storage IAM permissions.
The IAM role is associated with the following Trident Protect service accounts:
<trident-protect>-controller-manager -
<trident-protect>-resource-backup -
<trident-protect>-resource-restore -
<trident-protect>-resource-delete
For detailed instructions on enabling Pod Identity and associating IAM roles with service accounts, refer to the AWS EKS Pod Identity documentation.
AppVault Configuration
When using EKS Pod Identity, configure your AppVault CR with the useIAM: true flag instead of explicit credentials:
apiVersion: protect.trident.netapp.io/v1
kind: AppVault
metadata:
spec:
providerType: AWS
providerConfig:
s3:
bucketName: trident-protect-aws
endpoint: s3.example.com
useIAM: true
AppVault key generation examples for cloud providers
When defining an AppVault CR, you need to include credentials to access the resources hosted by the provider, unless you are using IAM authentication. How you generate the keys for the credentials will differ depending on the provider. The following are command line key generation examples for several providers. You can use the following examples to create keys for the credentials of each cloud provider.
kubectl create secret generic <secret-name> \
--from-file=credentials=<mycreds-file.json> \
-n trident-protect
--from-literal=accessKeyID=<objectstorage-accesskey> \
--from-literal=secretAccessKey=<amazon-s3-trident-protect-src-bucket-secret> \
-n trident-protect
--from-literal=accountKey=<secret-name> \
-n trident-protect
--from-literal=secretAccessKey=<generic-s3-trident-protect-src-bucket-secret> \
-n trident-protect
--from-literal=secretAccessKey=<ontap-s3-trident-protect-src-bucket-secret> \
-n trident-protect
--from-literal=secretAccessKey=<storagegrid-s3-trident-protect-src-bucket-secret> \
-n trident-protect
AppVault creation examples
The following are example AppVault definitions for each provider.
AppVault CR examples
You can use the following CR examples to create AppVault objects for each cloud provider.
kind: AppVault
metadata:
spec:
dataMoverPasswordSecretRef: my-optional-data-mover-secret
providerType: GCP
providerConfig:
gcp:
bucketName: trident-protect-src-bucket
projectID: project-id
providerCredentials:
credentials:
valueFromSecret:
key: credentials
kind: AppVault
metadata:
spec:
providerType: AWS
providerConfig:
s3:
proxyURL: http://10.1.1.1:3128
accessKeyID:
valueFromSecret:
key: accessKeyID
secretAccessKey:
valueFromSecret:
key: secretAccessKey
sessionToken:
valueFromSecret:
key: sessionToken
For EKS environments using Pod Identity with Kopia data mover, you can remove the providerCredentials section and add useIAM: true under the s3 configuration instead.
kind: AppVault
metadata:
spec:
providerType: Azure
providerConfig:
azure:
accountName: account-name
accountKey:
valueFromSecret:
key: accountKey
kind: AppVault
metadata:
spec:
providerType: GenericS3
providerConfig:
s3:
accessKeyID:
valueFromSecret:
key: accessKeyID
secretAccessKey:
valueFromSecret:
kind: AppVault
metadata:
spec:
providerType: OntapS3
providerConfig:
s3:
accessKeyID:
valueFromSecret:
key: accessKeyID
secretAccessKey:
valueFromSecret:
kind: AppVault
metadata:
spec:
providerType: StorageGridS3
providerConfig:
s3:
accessKeyID:
valueFromSecret:
key: accessKeyID
secretAccessKey:
valueFromSecret:
AppVault creation examples using the Trident Protect CLI
You can use the following CLI command examples to create AppVault CRs for each provider.
tridentctl-protect create vault GCP <vault-name> \
--bucket <mybucket> \
--project <my-gcp-project> \
--secret <secret-name>/credentials \
--data-mover-password-secret-ref <my-optional-data-mover-secret> \
-n trident-protect
tridentctl-protect create vault AWS <vault-name> \
--bucket <bucket-name> \
--secret <secret-name> \
--endpoint <s3-endpoint> \
-n trident-protect
tridentctl-protect create vault Azure <vault-name> \
--account <account-name> \
-n trident-protect
tridentctl-protect create vault GenericS3 <vault-name> \
-n trident-protect
tridentctl-protect create vault OntapS3 <vault-name> \
-n trident-protect
tridentctl-protect create vault StorageGridS3 <vault-name> \
-n trident-protect
Supported providerConfig.s3 configuration options
See the following table for the S3 provider configuration options:
| Parameter | Description | Default | Example |
Disable SSL/TLS certificate verification. |
false |
"true", "false" |
Enable secure HTTPS communication with the S3 endpoint. |
true |
"true", "false" |
Specify the URL of the proxy server used to connect to S3. |
None |
http://proxy.example.com:8080 |
Provide a custom root CA certificate for SSL/TLS verification. |
None |
"CN=MyCustomCA" |
Enable IAM authentication for accessing S3 buckets. Applicable for EKS Pod Identity. |
false |
true, false |
View AppVault information
You can use the Trident Protect CLI plugin to view information about AppVault objects that you have created on the cluster.
View the contents of an AppVault object:
tridentctl-protect get appvaultcontent gcp-vault \ --show-resources all \ -n trident-protectExample output:
+-------------+-------+----------+-----------------------------+---------------------------+ | CLUSTER | APP | TYPE | NAME | TIMESTAMP | +-------------+-------+----------+-----------------------------+---------------------------+ | | mysql | snapshot | mysnap | 2024-08-09 21:02:11 (UTC) | | production1 | mysql | snapshot | hourly-e7db6-20240815180300 | 2024-08-15 18:03:06 (UTC) | | production1 | mysql | snapshot | hourly-e7db6-20240815190300 | 2024-08-15 19:03:06 (UTC) | | production1 | mysql | snapshot | hourly-e7db6-20240815200300 | 2024-08-15 20:03:06 (UTC) | | production1 | mysql | backup | hourly-e7db6-20240815180300 | 2024-08-15 18:04:25 (UTC) | | production1 | mysql | backup | hourly-e7db6-20240815190300 | 2024-08-15 19:03:30 (UTC) | | production1 | mysql | backup | hourly-e7db6-20240815200300 | 2024-08-15 20:04:21 (UTC) | | production1 | mysql | backup | mybackup5 | 2024-08-09 22:25:13 (UTC) | | | mysql | backup | mybackup | 2024-08-09 21:02:52 (UTC) | +-------------+-------+----------+-----------------------------+---------------------------+
Optionally, to see the AppVaultPath for each resource, use the flag
--show-paths.The cluster name in the first column of the table is only available if a cluster name was specified in the Trident Protect helm installation. For example:
--set clusterName=production1.
Remove an AppVault
You can remove an AppVault object at any time.
Do not remove the finalizers key in the AppVault CR before deleting the AppVault object. If you do so, it can result in residual data in the AppVault bucket and orphaned resources in the cluster.
Ensure that you have deleted all snapshot and backup CRs being used by the AppVault you want to delete.
Remove the AppVault object, replacing
appvault-namewith the name of the AppVault object to remove:kubectl delete appvault <appvault-name> \ -n trident-protect
appvault-namewith the name of the AppVault object to remove:tridentctl-protect delete appvault <appvault-name> \ -n trident-protect
