Use Trident Protect AppVault objects to manage buckets
Contributors netapp-revathid netapp-aruldeepa
The bucket custom resource (CR) for Trident Protect is known as an AppVault. AppVault objects are the declarative Kubernetes workflow representation of a storage bucket. An AppVault CR contains the configurations necessary for a bucket to be used in protection operations, such as backups, snapshots, restore operations, and SnapMirror replication. Only administrators can create AppVaults.
Key generation and AppVault definition examples
When defining an AppVault CR, you need to include credentials to access the resources hosted by the provider. How you generate the keys for the credentials will differ depending on the provider. The following are command line key generation examples for several providers, followed by example AppVault definitions for each provider.
Key generation examples
You can use the following examples to create keys for the credentials of each cloud provider.
Google Cloud
kubectl create secret generic <secret-name> --from-file=credentials=<mycreds-file.json> -n trident-protect
Amazon S3 (AWS)
kubectl create secret generic <secret-name> --from-literal=accessKeyID=<objectstorage-accesskey> --from-literal=secretAccessKey=<generic-s3-trident-protect-src-bucket-secret> -n trident-protect
Microsoft Azure
kubectl create secret generic <secret-name> --from-literal=accountKey=<secret-name> -n trident-protect
Generic S3
ONTAP S3
StorageGrid S3
AppVault CR examples
You can use the following CR examples to create AppVault objects for each cloud provider.
Google Cloud
apiVersion: protect.trident.netapp.io/v1
kind: AppVault
metadata:
  namespace: trident-protect
spec:
  providerType: GCP
  providerConfig:
    gcp:
      bucketName: trident-protect-src-bucket
      projectID: project-id
  providerCredentials:
    credentials:
      valueFromSecret:
        key: credentials
Amazon S3 (AWS)
kind: AppVault
metadata:
spec:
  providerType: AWS
  providerConfig:
    s3:
      endpoint: s3.example.com
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
        key: secretAccessKey
Microsoft Azure
kind: AppVault
metadata:
spec:
  providerType: Azure
  providerConfig:
    azure:
      accountName: account-name
    accountKey:
      valueFromSecret:
        key: accountKey
Generic S3
kind: AppVault
metadata:
spec:
  providerType: GenericS3
  providerConfig:
    s3:
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
ONTAP S3
kind: AppVault
metadata:
spec:
  providerType: OntapS3
  providerConfig:
    s3:
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
StorageGrid S3
kind: AppVault
metadata:
spec:
  providerType: StorageGridS3
  providerConfig:
    s3:
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
AppVault creation examples using the Trident Protect CLI
You can use the following CLI command examples to create AppVault CRs for each provider.
Google Cloud
tridentctl-protect create vault GCP my-new-vault --bucket mybucket --project my-gcp-project --secret <gcp-creds>/<credentials>
Amazon S3 (AWS)
tridentctl-protect create vault AWS <vault-name> --bucket <bucket-name> --secret  <secret-name>  --endpoint <s3-endpoint>
Microsoft Azure
tridentctl-protect create vault Azure <vault-name> --account <account-name> --bucket <bucket-name> --secret <secret-name>
Generic S3
tridentctl-protect create vault GenericS3 <vault-name> --bucket <bucket-name> --secret  <secret-name>  --endpoint <s3-endpoint>
ONTAP S3
tridentctl-protect create vault OntapS3 <vault-name> --bucket <bucket-name> --secret  <secret-name>  --endpoint <s3-endpoint>
StorageGrid S3
tridentctl-protect create vault StorageGridS3 s3vault --bucket <bucket-name> --secret  <secret-name>  --endpoint <s3-endpoint>
Use the AppVault browser to view AppVault information
You can use the Trident Protect CLI plugin to view information about AppVault objects that have been created on the cluster.
Steps
  1. View the contents of an AppVault object:
    tridentctl-protect get appvaultcontent gcp-vault --show-resources all
    Example output:
    |   CLUSTER   |  APP  |   TYPE   |            NAME             |         TIMESTAMP         |
    |             | mysql | snapshot | mysnap                      | 2024-08-09 21:02:11 (UTC) |
    | production1 | mysql | snapshot | hourly-e7db6-20240815180300 | 2024-08-15 18:03:06 (UTC) |
    | production1 | mysql | snapshot | hourly-e7db6-20240815190300 | 2024-08-15 19:03:06 (UTC) |
    | production1 | mysql | snapshot | hourly-e7db6-20240815200300 | 2024-08-15 20:03:06 (UTC) |
    | production1 | mysql | backup   | hourly-e7db6-20240815180300 | 2024-08-15 18:04:25 (UTC) |
    | production1 | mysql | backup   | hourly-e7db6-20240815190300 | 2024-08-15 19:03:30 (UTC) |
    | production1 | mysql | backup   | hourly-e7db6-20240815200300 | 2024-08-15 20:04:21 (UTC) |
    | production1 | mysql | backup   | mybackup5                   | 2024-08-09 22:25:13 (UTC) |
    |             | mysql | backup   | mybackup                    | 2024-08-09 21:02:52 (UTC) |
  2. Optionally, to see the AppVaultPath for each resource, use the flag --show-paths.
    The cluster name in the first column of the table is only available if a cluster name was specified in the Trident Protect helm installation. For example: --set clusterName=production1.
Remove an AppVault
You can remove an AppVault object at any time.
Note Do not remove the finalizers key in the AppVault CR before deleting the AppVault object. If you do so, it can result in residual data in the AppVault bucket and orphaned resources in the cluster.
Before you begin
Ensure that you have deleted all snapshots and backups stored in the associated bucket.
Remove an AppVault using the Kubernetes CLI
  1. Remove the AppVault object, replacing appvault_name with the name of the AppVault object to remove:
    kubectl delete appvault <appvault_name> -n trident-protect
Remove an AppVault using the Trident Protect CLI
    tridentctl-protect delete appvault <appvault_name> -n trident-protect
