Use Trident Protect AppVault objects to manage buckets
Contributors netapp-revathid netapp-aruldeepa
The bucket custom resource (CR) for Trident Protect is known as an AppVault. AppVault objects are the declarative Kubernetes workflow representation of a storage bucket. An AppVault CR contains the configurations necessary for a bucket to be used in protection operations, such as backups, snapshots, restore operations, and SnapMirror replication. Only administrators can create AppVaults.
You need to create an AppVault CR either manually or using the command line when you perform data protection operations on an application, and the AppVault CR needs to reside on the cluster where Trident Protect is installed. The AppVault CR is specific to your environment; you can use the examples on this page as a guide when creating AppVault CRs.
Configure AppVault authentication and passwords
Before you create an AppVault CR, you need to ensure the AppVault and the data mover you choose can authenticate with the provider and any related resources.
Data mover repository passwords
When you create AppVault objects using CRs or the Trident Protect CLI plugin, you can optionally instruct Trident Protect to use a Kubernetes secret that contains custom passwords for the Restic and Kopia repository encryption. If you don't specify a secret, Trident Protect uses a default password.
  • When manually creating AppVault CRs, use the spec.dataMoverPasswordSecretRef field to specify the secret.
  • When creating AppVault objects using the Trident Protect CLI, use the --data-mover-password-secret-ref argument to specify the secret.
Create a data mover repository password secret
Use the following examples to create the password secret. When you create AppVault objects, you can instruct Trident Protect to use this secret to authenticate with the data mover repository.
Note Depending on which data mover you are using, you only need to include the corresponding password for that data mover. For example, if you are using Restic and do not plan to use Kopia in the future, you can include only the Restic password when you create the secret.
Use a CR
apiVersion: v1
data:
  KOPIA_PASSWORD: <base64-encoded-password>
  RESTIC_PASSWORD: <base64-encoded-password>
kind: Secret
metadata:
  namespace: trident-protect
type: Opaque
Use the CLI
kubectl create secret generic my-optional-data-mover-secret \
--from-literal=KOPIA_PASSWORD=<plain-text-password> \
--from-literal=RESTIC_PASSWORD=<plain-text-password> \
-n trident-protect
S3-compatible storage IAM permissions
When you access S3-compatible storage such as Amazon S3, Generic S3, StorageGrid S3, or ONTAP S3 using Trident Protect, you need to ensure that the user credentials you provide have the necessary permissions to access the bucket. The following is an example of a policy that grants the minimum required permissions for access with Trident Protect. You can apply this policy to the user that manages S3-compatible bucket policies.
  "Version": "2012-10-17",
  "Statement": [
      "Effect": "Allow",
      "Action": [
        "s3:PutObject",
        "s3:GetObject",
        "s3:ListBucket",
        "s3:DeleteObject"
      "Resource": "*"
For more information about Amazon S3 policies, refer to to the examples in the Amazon S3 documentation.
AppVault key generation examples for cloud providers
When defining an AppVault CR, you need to include credentials to access the resources hosted by the provider. How you generate the keys for the credentials will differ depending on the provider. The following are command line key generation examples for several providers. You can use the following examples to create keys for the credentials of each cloud provider.
Google Cloud
kubectl create secret generic <secret-name> \
--from-file=credentials=<mycreds-file.json> \
-n trident-protect
Amazon S3 (AWS)
--from-literal=accessKeyID=<objectstorage-accesskey> \
--from-literal=secretAccessKey=<amazon-s3-trident-protect-src-bucket-secret> \
-n trident-protect
Microsoft Azure
--from-literal=accountKey=<secret-name> \
-n trident-protect
Generic S3
--from-literal=secretAccessKey=<generic-s3-trident-protect-src-bucket-secret> \
-n trident-protect
ONTAP S3
--from-literal=secretAccessKey=<ontap-s3-trident-protect-src-bucket-secret> \
-n trident-protect
StorageGrid S3
--from-literal=secretAccessKey=<storagegrid-s3-trident-protect-src-bucket-secret> \
-n trident-protect
AppVault creation examples
The following are example AppVault definitions for each provider.
AppVault CR examples
You can use the following CR examples to create AppVault objects for each cloud provider.
Note
  • You can optionally specify a Kubernetes secret that contains custom passwords for the Restic and Kopia repository encryption. Refer to Data mover repository passwords for more information.
  • For Amazon S3 (AWS) AppVault objects, you can optionally specify a sessionToken, which is useful if you are using single sign-on (SSO) for authentication. This token is created when you generate keys for the provider in AppVault key generation examples for cloud providers.
  • For S3 AppVault objects, you can optionally specify an egress proxy URL for outbound S3 traffic using the spec.providerConfig.S3.proxyURL key.
Google Cloud
apiVersion: protect.trident.netapp.io/v1
kind: AppVault
metadata:
spec:
  dataMoverPasswordSecretRef: my-optional-data-mover-secret
  providerType: GCP
  providerConfig:
    gcp:
      bucketName: trident-protect-src-bucket
      projectID: project-id
  providerCredentials:
    credentials:
      valueFromSecret:
        key: credentials
Amazon S3 (AWS)
kind: AppVault
metadata:
spec:
  providerType: AWS
  providerConfig:
    s3:
      endpoint: s3.example.com
      proxyURL: http://10.1.1.1:3128
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
        key: secretAccessKey
    sessionToken:
      valueFromSecret:
        key: sessionToken
Microsoft Azure
kind: AppVault
metadata:
spec:
  providerType: Azure
  providerConfig:
    azure:
      accountName: account-name
    accountKey:
      valueFromSecret:
        key: accountKey
Generic S3
kind: AppVault
metadata:
spec:
  providerType: GenericS3
  providerConfig:
    s3:
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
ONTAP S3
kind: AppVault
metadata:
spec:
  providerType: OntapS3
  providerConfig:
    s3:
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
StorageGrid S3
kind: AppVault
metadata:
spec:
  providerType: StorageGridS3
  providerConfig:
    s3:
    accessKeyID:
      valueFromSecret:
        key: accessKeyID
    secretAccessKey:
      valueFromSecret:
AppVault creation examples using the Trident Protect CLI
You can use the following CLI command examples to create AppVault CRs for each provider.
Note
  • For S3 AppVault objects, you can optionally specify an egress proxy URL for outbound S3 traffic using the --proxy-url <ip_address:port> argument.
Google Cloud
tridentctl-protect create vault GCP <vault-name> \
--bucket <mybucket> \
--project <my-gcp-project> \
--secret <secret-name>/credentials \
--data-mover-password-secret-ref <my-optional-data-mover-secret> \
-n trident-protect
Amazon S3 (AWS)
tridentctl-protect create vault AWS <vault-name> \
--bucket <bucket-name> \
--secret  <secret-name>  \
--endpoint <s3-endpoint> \
-n trident-protect
Microsoft Azure
tridentctl-protect create vault Azure <vault-name> \
--account <account-name> \
-n trident-protect
Generic S3
tridentctl-protect create vault GenericS3 <vault-name> \
-n trident-protect
ONTAP S3
tridentctl-protect create vault OntapS3 <vault-name> \
-n trident-protect
StorageGrid S3
tridentctl-protect create vault StorageGridS3 <vault-name> \
-n trident-protect
View AppVault information
You can use the Trident Protect CLI plugin to view information about AppVault objects that you have created on the cluster.
Steps
  1. View the contents of an AppVault object:
    tridentctl-protect get appvaultcontent gcp-vault \
    --show-resources all \
    -n trident-protect
    Example output:
    |   CLUSTER   |  APP  |   TYPE   |            NAME             |         TIMESTAMP         |
    |             | mysql | snapshot | mysnap                      | 2024-08-09 21:02:11 (UTC) |
    | production1 | mysql | snapshot | hourly-e7db6-20240815180300 | 2024-08-15 18:03:06 (UTC) |
    | production1 | mysql | snapshot | hourly-e7db6-20240815190300 | 2024-08-15 19:03:06 (UTC) |
    | production1 | mysql | snapshot | hourly-e7db6-20240815200300 | 2024-08-15 20:03:06 (UTC) |
    | production1 | mysql | backup   | hourly-e7db6-20240815180300 | 2024-08-15 18:04:25 (UTC) |
    | production1 | mysql | backup   | hourly-e7db6-20240815190300 | 2024-08-15 19:03:30 (UTC) |
    | production1 | mysql | backup   | hourly-e7db6-20240815200300 | 2024-08-15 20:04:21 (UTC) |
    | production1 | mysql | backup   | mybackup5                   | 2024-08-09 22:25:13 (UTC) |
    |             | mysql | backup   | mybackup                    | 2024-08-09 21:02:52 (UTC) |
  2. Optionally, to see the AppVaultPath for each resource, use the flag --show-paths.
    The cluster name in the first column of the table is only available if a cluster name was specified in the Trident Protect helm installation. For example: --set clusterName=production1.
Remove an AppVault
You can remove an AppVault object at any time.
Note Do not remove the finalizers key in the AppVault CR before deleting the AppVault object. If you do so, it can result in residual data in the AppVault bucket and orphaned resources in the cluster.
Before you begin
Ensure that you have deleted all snapshot and backup CRs being used by the AppVault you want to delete.
Remove an AppVault using the Kubernetes CLI
  1. Remove the AppVault object, replacing appvault-name with the name of the AppVault object to remove:
    kubectl delete appvault <appvault-name> \
    -n trident-protect
Remove an AppVault using the Trident Protect CLI
    tridentctl-protect delete appvault <appvault-name> \
    -n trident-protect
