Driver-specific volume options
Each storage driver has a different set of options, which you can specify at volume creation time to customize the outcome. See below for options that apply to your configured storage system.
Using these options during the volume create operation is simple. Provide the option and the value using the -o operator during the CLI operation. These override any equivalent values from the JSON configuration file.
ONTAP volume options
Volume create options for both NFS, iSCSI, and FC include the following:
| Option | Description |
The size of the volume, defaults to 1 GiB. |
Thin or thick provision the volume, defaults to thin. Valid values are |
This will set the snapshot policy to the desired value. The default is |
This will set the snapshot reserve to the desired percentage. The default is no value, meaning ONTAP will select the snapshotReserve (usually 5%) if you have selected a snapshotPolicy, or 0% if the snapshotPolicy is none. You can set the default snapshotReserve value in the config file for all ONTAP backends, and you can use it as a volume creation option for all ONTAP backends except ontap-nas-economy. |
When cloning a volume, this will cause ONTAP to immediately split the clone from its parent. The default is |
Enable NetApp Volume Encryption (NVE) on the new volume; defaults to If NAE is enabled on the backend, any volume provisioned in Trident will be NAE enabled. For more information, refer to: How Trident works with NVE and NAE. |
Sets the tiering policy to be used for the volume. This decides whether data is moved to the cloud tier when it becomes inactive (cold). |
The following additional options are for NFS only:
This controls the permission set for the volume itself. By default the permissions will be set to |
Setting this to |
Sets the export policy to be used for the volume. The default is |
Sets the security style to be used for access to the volume. The default is |
The following additional options are for iSCSI only:
Sets the file system used to format iSCSI volumes. The default is |
Setting this to |
See the examples below:
Create a 10 GiB volume:
docker volume create -d netapp --name demo -o size=10G -o encryption=true
Create a 100 GiB volume with snapshots:
docker volume create -d netapp --name demo -o size=100G -o snapshotPolicy=default -o snapshotReserve=10
Create a volume which has the setUID bit enabled:
docker volume create -d netapp --name demo -o unixPermissions=4755
The minimum volume size is 20 MiB.
If the snapshot reserve is not specified and the snapshot policy is none, Trident use a snapshot reserve of 0%.
Create a volume with no snapshot policy and no snapshot reserve:
docker volume create -d netapp --name my_vol --opt snapshotPolicy=none
Create a volume with no snapshot policy and a custom snapshot reserve of 10%:
docker volume create -d netapp --name my_vol --opt snapshotPolicy=none --opt snapshotReserve=10
Create a volume with a snapshot policy and a custom snapshot reserve of 10%:
docker volume create -d netapp --name my_vol --opt snapshotPolicy=myPolicy --opt snapshotReserve=10
Create a volume with a snapshot policy, and accept the ONTAP's default snapshot reserve (usually 5%):
Element software volume options
The Element software options expose the size and quality of service (QoS) policies associated with the volume. When the volume is created, the QoS policy associated with it is specified using the -o type=service_level nomenclature.
The first step to defining a QoS service level with the Element driver is to create at least one type and specify the minimum, maximum, and burst IOPS associated with a name in the configuration file.
Other Element software volume create options include the following:
The size of the volume, defaults to 1 GiB or config entry … "defaults": {"size": "5G"}. |
Use either 512 or 4096, defaults to 512 or config entry DefaultBlockSize. |
Example
See the following sample configuration file with QoS definitions:
"Types": [
"Type": "Bronze",
"Qos": {
"minIOPS": 1000,
"maxIOPS": 2000,
"burstIOPS": 4000
"Type": "Silver",
"Qos": {
"minIOPS": 4000,
"maxIOPS": 6000,
"burstIOPS": 8000
"Type": "Gold",
"Qos": {
"minIOPS": 6000,
"maxIOPS": 8000,
"burstIOPS": 10000
In the above configuration, we have three policy definitions: Bronze, Silver, and Gold. These names are arbitrary.
Create a 10 GiB Gold volume:
docker volume create -d solidfire --name sfGold -o type=Gold -o size=10G
Create a 100 GiB Bronze volume:
docker volume create -d solidfire --name sfBronze -o type=Bronze -o size=100G
