Storage configuration options
Contributors netapp-aruldeepa juliantap joan-ing netapp-mwallis
See the configuration options available for your Trident configurations.
Global configuration options
These configuration options apply to all Trident configurations, regardless of the storage platform being used.
Option Description Example
version
Config file version number
1
storageDriverName
Name of storage driver
ontap-nas, ontap-san, ontap-nas-economy,
ontap-nas-flexgroup, solidfire-san
storagePrefix
Optional prefix for volume names. Default: netappdvp_.
staging_
limitVolumeSize
Optional restriction on volume sizes. Default: "" (not enforced)
10g
Tip Do not use storagePrefix (including the default) for Element backends. By default, the solidfire-san driver will ignore this setting and not use a prefix. NetApp recommends using either a specific tenantID for Docker volume mapping or using the attribute data which is populated with the Docker version, driver info, and raw name from Docker in cases where any name munging may have been used.
Default options are available to avoid having to specify them on every volume you create. The size option is available for all the controller types. See the ONTAP configuration section for an example of how to set the default volume size.
size
Optional default size for new volumes. Default: 1G
10G
ONTAP configuration
In addition to the global configuration values above, when using ONTAP, the following top-level options are available.
managementLIF
IP address of ONTAP management LIF. You can specify a fully-qualified domain name (FQDN).
10.0.0.1
dataLIF
IP address of protocol LIF.
ONTAP NAS drivers: NetApp recommends specifying dataLIF. If not provided, Trident fetches dataLIFs from the SVM. You can specify a fully-qualified domain name (FQDN) to be used for the NFS mount operations, allowing you to create a round-robin DNS to load-balance across multiple dataLIFs.
ONTAP SAN drivers: Do not specify for iSCSI or FC. Trident uses ONTAP Selective LUN Map to discover the iSCSI or FC LIFs needed to establish a multi path session. A warning is generated if dataLIF is explicitly defined.
10.0.0.2
svm
Storage virtual machine to use (required, if management LIF is a cluster LIF)
svm_nfs
username
Username to connect to the storage device
vsadmin
password
Password to connect to the storage device
secret
aggregate
Aggregate for provisioning (optional; if set, must be assigned to the SVM). For the ontap-nas-flexgroup driver, this option is ignored. All aggregates assigned to the SVM are used to provision a FlexGroup volume.
aggr1
limitAggregateUsage
Optional, fail provisioning if usage is above this percentage
75%
nfsMountOptions
Fine grained control of NFS mount options; defaults to "-o nfsvers=3". Available only for the ontap-nas and ontap-nas-economy drivers. See NFS host configuration information here.
-o nfsvers=4
igroupName
Trident creates and manages per-node igroups as netappdvp.
This value cannot be changed or omitted.
Available only for the ontap-san driver.
netappdvp
limitVolumeSize
Maximum requestable volume size.
300g
qtreesPerFlexvol
Maximum qtrees per FlexVol, must be in range [50, 300], default is 200.
For the ontap-nas-economy driver, this option allows customizing the maximum number of qtrees per FlexVol.
300
sanType
Supported for ontap-san driver only.
Use to select iscsi for iSCSI, nvme for NVMe/TCP or fcp for SCSI over Fibre Channel (FC).
iscsi if blank
limitVolumePoolSize
Supported for ontap-san-economy and ontap-san-economy drivers only.
Limits FlexVol sizes in ONTAP ontap-nas-economy and ontap-SAN-economy drivers.
300g
Default options are available to avoid having to specify them on every volume you create:
spaceReserve
Space reservation mode; none (thin provisioned) or volume (thick)
none
snapshotPolicy
Snapshot policy to use, default is none
none
snapshotReserve
Snapshot reserve percentage, default is "" to accept the ONTAP default
10
splitOnClone
Split a clone from its parent upon creation, defaults to false
false
encryption
Enables NetApp Volume Encryption (NVE) on the new volume; defaults to false. NVE must be licensed and enabled on the cluster to use this option.
If NAE is enabled on the backend, any volume provisioned in Trident will be NAE enabled.
For more information, refer to: How Trident works with NVE and NAE.
true
unixPermissions
NAS option for provisioned NFS volumes, defaults to 777
777
snapshotDir
NAS option for access to the .snapshot directory.
Enables or disables access to the .snapshot directory.
Valid values: true, false.
Default behavior might vary by ONTAP and Trident version. Set explicitly to ensure consistent behavior.
exportPolicy
NAS option for the NFS export policy to use, defaults to default
default
securityStyle
NAS option for access to the provisioned NFS volume.
NFS supports mixed and unix security styles. The default is unix.
unix
fileSystemType
SAN option to select the file system type, defaults to ext4
xfs
tieringPolicy
Tiering policy to use, default is none.
none
skipRecoveryQueue
During volume deletion, bypass the recovery queue in storage and delete the volume immediately.
Scaling options
The ontap-nas and ontap-san drivers create an ONTAP FlexVol for each Docker volume. ONTAP supports up to 1000 FlexVols per cluster node with a cluster maximum of 12,000 FlexVol volumes If your Docker volume requirements fit within that limitation, the ontap-nas driver is the preferred NAS solution due to the additional features offered by FlexVols, such as Docker-volume-granular snapshots and cloning.
If you need more Docker volumes than can be accommodated by the FlexVol limits, choose the ontap-nas-economy or the ontap-san-economy driver.
The ontap-nas-economy driver creates Docker volumes as ONTAP Qtrees within a pool of automatically managed FlexVol volumes. Qtrees offer far greater scaling, up to 100,000 per cluster node and 2,400,000 per cluster, at the expense of some features. The ontap-nas-economy driver does not support Docker-volume-granular snapshots or cloning.
Note The ontap-nas-economy driver is not currently supported in Docker Swarm, because Docker Swarm does not orchestrate volume creation across multiple nodes.
The ontap-san-economy driver creates Docker volumes as ONTAP LUNs within a shared pool of automatically managed FlexVol volumes. This way, each FlexVol is not restricted to only one LUN and it offers better scalability for SAN workloads. Depending on the storage array, ONTAP supports up to 16384 LUNs per cluster. Because the volumes are LUNs underneath, this driver supports Docker-volume-granular snapshots and cloning.
Choose the ontap-nas-flexgroup driver to increase parallelism to a single volume that can grow into the petabyte range with billions of files. Some ideal use cases for FlexGroups include AI/ML/DL, big data and analytics, software builds, streaming, file repositories, and so on. Trident uses all aggregates assigned to an SVM when provisioning a FlexGroup volume. FlexGroup support in Trident also has the following considerations:
  • Requires ONTAP version 9.2 or greater.
  • As of this writing, FlexGroups only support NFS v3.
  • Recommended to enable the 64-bit NFSv3 identifiers for the SVM.
  • The minimum recommended FlexGroup member/volume size is 100 GiB.
  • Cloning is not supported for FlexGroup volumes.
For information about FlexGroups and workloads that are appropriate for FlexGroups refer to the NetApp FlexGroup volume Best Practices and Implementation Guide.
To get advanced features and large scale in the same environment, you can run multiple instances of the Docker Volume Plugin, with one using ontap-nas and another using ontap-nas-economy.
Custom ONTAP role for Trident
You can create an ONTAP cluster role with minimum privileges so that you do not have to use the ONTAP admin role to perform operations in Trident. When you include the username in a Trident backend configuration, Trident uses the ONTAP cluster role you created to perform the operations.
Refer to Trident custom-role generator for more information about creating Trident custom roles.
Using ONTAP CLI
  1. Create a new role using the following command:
    security login role create <role_name\> -cmddirname "command" -access all -vserver <svm_name\>
  2. Create a usename for the Trident user:
    security login create -username <user_name\> -application ontapi -authmethod password -role <name_of_role_in_step_1\> -vserver <svm_name\> -comment "user_description"
    security login create -username <user_name\> -application http -authmethod password -role <name_of_role_in_step_1\> -vserver <svm_name\> -comment "user_description"
  3. Map the role to the user:
    security login modify username <user_name\> -vserver <svm_name\> -role <role_name\> -application ontapi -application console -authmethod <password\>
Using System Manager
Perform the following steps in ONTAP System Manager:
  1. Create a custom role:
    1. To create a custom role at the cluster-level, select Cluster > Settings.
      (Or) To create a custom role at the SVM level, select Storage > Storage VMs > required SVM> Settings > Users and Roles.
    2. Select the arrow icon (→) next to Users and Roles.
    3. Select +Add under Roles.
    4. Define the rules for the role and click Save.
  2. Map the role to the Trident user:
    + Perform the following steps on the Users and Roles page:
    1. Select Add icon + under Users.
    2. Select the required username, and select a role in the drop-down menu for Role.
    3. Click Save.
Refer to the following pages for more information:
Example ONTAP configuration files
NFS example for ontap-nas driver
  "version": 1,
  "storageDriverName": "ontap-nas",
  "managementLIF": "10.0.0.1",
  "dataLIF": "10.0.0.2",
  "svm": "svm_nfs",
  "username": "vsadmin",
  "password": "password",
  "aggregate": "aggr1",
  "defaults": {
    "size": "10G",
    "spaceReserve": "none",
    "exportPolicy": "default"
NFS example for ontap-nas-flexgroup driver
  "version": 1,
  "storageDriverName": "ontap-nas-flexgroup",
  "svm": "svm_nfs",
  "defaults": {
    "size": "100G",
NFS example for ontap-nas-economy driver
  "version": 1,
  "storageDriverName": "ontap-nas-economy",
  "svm": "svm_nfs",
iSCSI example for ontap-san driver
  "version": 1,
  "storageDriverName": "ontap-san",
  "dataLIF": "10.0.0.3",
  "svm": "svm_iscsi",
  "igroupName": "netappdvp"
NFS example for ontap-san-economy driver
  "version": 1,
  "storageDriverName": "ontap-san-economy",
  "svm": "svm_iscsi_eco",
NVMe/TCP example for ontap-san driver
  "version": 1,
  "backendName": "NVMeBackend",
  "svm": "svm_nvme",
  "sanType": "nvme",
  "useREST": true
SCSI over FC example for ontap-san driver
  "version": 1,
  "backendName": "ontap-san-backend",
  "sanType": "fcp",
  "svm": "trident_svm",
  "useREST": true
Element software configuration
In addition to the global configuration values, when using Element software (NetApp HCI/SolidFire), these options are available.
Endpoint
https://<login>:<password>@<mvip>/json-rpc/<element-version>
https://admin:admin@192.168.160.3/json-rpc/8.0
SVIP
iSCSI IP address and port
10.0.0.7:3260
TenantName
SolidFireF Tenant to use (created if not found)
docker
InitiatorIFace
Specify interface when restricting iSCSI traffic to non-default interface
default
Types
QoS specifications
See example below
LegacyNamePrefix
Prefix for upgraded Trident installs. If you used a version of Trident prior to 1.3.2 and perform an upgrade with existing volumes, you'll need to set this value to access your old volumes that were mapped via the volume-name method.
netappdvp-
The solidfire-san driver does not support Docker Swarm.
Example Element software configuration file
  "version": 1,
  "storageDriverName": "solidfire-san",
  "Endpoint": "https://admin:admin@192.168.160.3/json-rpc/8.0",
  "SVIP": "10.0.0.7:3260",
  "TenantName": "docker",
  "InitiatorIFace": "default",
  "Types": [
      "Type": "Bronze",
      "Qos": {
        "minIOPS": 1000,
        "maxIOPS": 2000,
        "burstIOPS": 4000
      "Type": "Silver",
      "Qos": {
        "minIOPS": 4000,
        "maxIOPS": 6000,
        "burstIOPS": 8000
      "Type": "Gold",
      "Qos": {
        "minIOPS": 6000,
        "maxIOPS": 8000,
        "burstIOPS": 10000
