Create an IAM role and an AWS Secrets Manager secret
You can configure Kubernetes pods to access AWS resources by authenticating as an AWS IAM role instead of by providing explicit AWS credentials.
To authenticate using an AWS IAM role, you must have a Kubernetes cluster deployed using Amazon EKS or Red Hat OpenShift. |
Create an AWS Secrets Manager secret
Trident needs credentials to manage storage on the FSx for ONTAP SVM. Store the vsadmin credentials in an AWS Secrets Manager secret.
This example creates an AWS Secrets Manager secret to store Trident CSI credentials:
aws secretsmanager create-secret --name trident-secret --description "Trident CSI credentials" \
--secret-string "{\"username\":\"vsadmin\",\"password\":\"<svm_password>\"}"
Create an IAM policy
Trident also needs AWS permissions to run correctly. Therefore, you need to create a policy that gives Trident the permissions it needs.
The following example creates an IAM policy using the AWS CLI:
aws iam create-policy --policy-name AmazonFSxNCSIDriverPolicy --policy-document file://policy.json \
--description "This policy grants Trident CSI access to FSx for ONTAP and AWS Secrets Manager" \
--query Policy.Arn --output text
The command returns the policy ARN. Use it in the following commands.
Policy JSON example:
"Statement": [
"Action": [
"fsx:DescribeFileSystems",
"fsx:DescribeVolumes",
"fsx:CreateVolume",
"fsx:RestoreVolumeFromSnapshot",
"fsx:DescribeStorageVirtualMachines",
"fsx:UntagResource",
"fsx:UpdateVolume",
"fsx:TagResource",
"fsx:DeleteVolume"
"Effect": "Allow",
"Resource": "*"
"Action": "secretsmanager:GetSecretValue",
"Effect": "Allow",
"Resource": "arn:aws:secretsmanager:<aws-region>:<aws-account-id>:secret:<aws-secret-manager-name>*"
"Version": "2012-10-17"
Create an IAM role for Pod Identity or an IAM role for a service account (IRSA)
You can configure a Kubernetes service account to assume an AWS Identity and Access Management (IAM) role with EKS Pod Identity or IAM roles for service accounts (IRSA). Pods configured to use the service account can then access AWS services that the role is permitted to access.
Amazon EKS Pod Identity associations provide the ability to manage credentials for your applications, similar to the way that Amazon EC2 instance profiles provide credentials to Amazon EC2 instances.
Install Pod Identity on your EKS cluster:
You can create Pod identity via the AWS console or using the following AWS CLI command:
aws eks create-addon --cluster-name <EKS_CLUSTER_NAME> --addon-name eks-pod-identity-agent
For more information, refer to Set up the Amazon EKS Pod Identity Agent.
Create trust-relationship.json:
Create trust-relationship.json to enable EKS Service Principal to assume this role for Pod Identity. Then create a role with this trust policy:
aws iam create-role \ --role-name fsxn-csi-role --assume-role-policy-document file://trust-relationship.json \ --description "fsxn csi pod identity role"
trust-relationship.json file:
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Principal": {
"Service": "pods.eks.amazonaws.com"
"Action": [
"sts:AssumeRole",
"sts:TagSession"
Attach the role policy to the IAM role:
Attach the role policy from the previous step to the IAM role that was created:
aws iam attach-role-policy \ --policy-arn arn:aws:iam::aws:111122223333:policy/fsxn-csi-policy \ --role-name fsxn-csi-role
Create a pod identity association:
Create a pod identity association between the IAM role and the Trident service account (trident-controller).
aws eks create-pod-identity-association \ --cluster-name <EKS_CLUSTER_NAME> \ --role-arn arn:aws:iam::111122223333:role/fsxn-csi-role \ --namespace trident --service-account trident-controller
Using the AWS CLI:
aws iam create-role --role-name AmazonEKS_FSxN_CSI_DriverRole \ --assume-role-policy-document file://trust-relationship.json
"Statement": [
"Effect": "Allow",
"Principal": {
"Federated": "arn:aws:iam::<account_id>:oidc-provider/<oidc_provider>"
"Action": "sts:AssumeRoleWithWebIdentity",
"Condition": {
"StringEquals": {
"<oidc_provider>:aud": "sts.amazonaws.com",
"<oidc_provider>:sub": "system:serviceaccount:trident:trident-controller"
Update the following values in the trust-relationship.json file:
<account_id> - Your AWS account ID
<oidc_provider> - The OIDC provider URL for your EKS cluster. You can obtain it by running:
aws eks describe-cluster --name my-cluster --query "cluster.identity.oidc.issuer" \ --output text | sed -e "s/^https:\/\///"
Attach the IAM policy to the IAM role:
Once the role has been created, attach the policy (that was created in the step above) to the role using this command:
aws iam attach-role-policy --role-name my-role --policy-arn <IAM policy ARN>
Verify the OIDC provider association:
Verify that your OIDC provider is associated with your cluster by running this command:
aws iam list-open-id-connect-providers | grep $oidc_id | cut -d "/" -f4
If the output is empty, use the following command to associate IAM OIDC to your cluster:
eksctl utils associate-iam-oidc-provider --cluster $cluster_name --approve
If you are using eksctl, use the following example to create an IAM role for a service account in EKS:
eksctl create iamserviceaccount --name trident-controller --namespace trident \
--cluster <my-cluster> --role-name AmazonEKS_FSxN_CSI_DriverRole --role-only \
--attach-policy-arn <IAM-Policy ARN> --approve
The self-managed OpenShift deployment creates IAM roles and attaches them to the cluster nodes. Attach the Trident IAM policy to the role assigned to each node.
To find the instance IDs of the nodes in your cluster, run the following command:
oc get nodes -o jsonpath='{range .items[*]}{.spec.providerID}{"\n"}{end}'
To find the IAM role associated with each instance, run the following command for each instance:
aws ec2 describe-instances --instance-ids <instance-id> --query 'Reservations[*].Instances[*].IamInstanceProfile.Arn' --output text
Attach the IAM policy to each role by running the following command:
aws iam attach-role-policy --role-name <role-name> --policy-arn <IAM policy ARN>
