Generate a Trident Protect support bundle
Contributors netapp-mwallis netapp-shwetav
Trident Protect enables administrators to generate bundles that include information useful to NetApp Support, including logs, metrics, and topology information about the clusters and apps under management. If you are connected to the internet, you can upload support bundles to the NetApp Support Site (NSS) using a custom resource (CR) file.
Create a support bundle using a CR
Steps
  1. Create the custom resource (CR) file and name it (for example, trident-protect-support-bundle.yaml).
  2. Configure the following attributes:
    • metadata.name: (Required) The name of this custom resource; choose a unique and sensible name for your environment.
    • spec.triggerType: (Required) Determines whether the support bundle is generated immediately, or scheduled. Scheduled bundle generation happens at 12AM UTC. Possible values:
      • Scheduled
      • Manual
    • spec.uploadEnabled: (Optional) Controls whether the support bundle should be uploaded to the NetApp Support Site after it is generated. If not specified, defaults to false. Possible values:
      • true
      • false (default)
    • spec.dataWindowStart: (Optional) A date string in RFC 3339 format that specifies the date and time that the window of included data in the support bundle should begin. If not specified, defaults to 24 hours ago. The earliest window date you can specify is 7 days ago.
      Example YAML:
      apiVersion: protect.trident.netapp.io/v1
      kind: AutoSupportBundle
      metadata:
      spec:
        triggerType: Manual
        uploadEnabled: true
        dataWindowStart: 2024-05-05T12:30:00Z
  3. After you populate the trident-protect-support-bundle.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-support-bundle.yaml -n trident-protect
Create a support bundle using the CLI
Steps
  1. Create the support bundle, replacing values in brackets with information from your environment. The trigger-type determines whether the bundle is created immediately or if creation time is dictated by the schedule, and can be Manual or Scheduled. The default setting is Manual.
    For example:
    tridentctl-protect create autosupportbundle <my-bundle-name> --trigger-type <trigger-type> -n trident-protect
Monitor and retrieve the support bundle
After creating a support bundle using either method, you can monitor its generation progress and retrieve it to your local system.
Steps
  1. Wait for the status.generationState to reach Completed state. You can monitor the generation progress with the following command:
    kubectl get autosupportbundle trident-protect-support-bundle -n trident-protect
  2. Retrieve the support bundle to your local system. Get the copy command from the completed AutoSupport bundle:
    kubectl describe autosupportbundle trident-protect-support-bundle -n trident-protect
    Find the kubectl cp command from the output and run it, replacing the destination argument with your preferred local directory.
