Prepare to configure a Google Cloud NetApp Volumes backend
Before you can configure your Google Cloud NetApp Volumes backend, you need to ensure the following requirements are met.
Prerequisites for NFS or SMB volumes
If you are using Google Cloud NetApp Volumes for the first time or in a new location, some initial configuration is required to set up Google Cloud NetApp Volumes and create an NFS or SMB volume. Refer to Before you begin.
Ensure that you have the following before configuring Google Cloud NetApp Volumes backend:
A Google Cloud account configured with Google Cloud NetApp Volumes service. Refer to Google Cloud NetApp Volumes.
Project number of your Google Cloud account. Refer to Identifying projects.
A Google Cloud service account with the NetApp Volumes Admin (
roles/netapp.admin) role. Refer to Identity and Access Management roles and permissions. -
API key file for your GCNV account. Refer to Create a service account key
A storage pool. Refer to Storage pools overview .
For more information about how to set up access to Google Cloud NetApp Volumes, refer to Set up access to Google Cloud NetApp Volumes.
