Protect applications using Trident Protect
You can protect all apps managed by Trident Protect by taking snapshots and backups using an automated protection policy or on an ad-hoc basis.
Note You can configure Trident Protect to freeze and unfreeze filesystems during data protection operations. Learn more about configuring filesystem freezing with Trident Protect.
Create an on-demand snapshot
You can create an on-demand snapshot at any time.
Note Cluster-scoped resources are included in a backup, snapshot, or clone if they are explicitly referenced in the application definition or if they have references to any of the application namespaces.
Create a snapshot using a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-snapshot-cr.yaml.
  2. In the file you created, configure the following attributes:
    • metadata.name: (Required) The name of this custom resource; choose a unique and sensible name for your environment.
    • spec.applicationRef: The Kubernetes name of the application to snapshot.
    • spec.appVaultRef: (Required) The name of the AppVault where the snapshot contents (metadata) should be stored.
    • spec.reclaimPolicy: (Optional) Defines what happens to the AppArchive of a snapshot when the snapshot CR is deleted. This means that even when set to Retain, the snapshot will be deleted. Valid options:
      • Retain (default)
      • Delete
        apiVersion: protect.trident.netapp.io/v1
        kind: Snapshot
        metadata:
          namespace: my-app-namespace
        spec:
          applicationRef: my-application
          appVaultRef: appvault-name
          reclaimPolicy: Delete
  3. After you populate the trident-protect-snapshot-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-snapshot-cr.yaml
Create a snapshot using the CLI
Steps
  1. Create the snapshot, replacing values in brackets with information from your environment. For example:
    tridentctl-protect create snapshot <my_snapshot_name> --appvault <my_appvault_name> --app <name_of_app_to_snapshot> -n <application_namespace>
Create an on-demand backup
You can back up an app at any time.
Before you begin
Ensure that the AWS session token expiration is sufficient for any long-running s3 backup operations. If the token expires during the backup operation, the operation can fail.
Create a backup using a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-backup-cr.yaml.
    • spec.applicationRef: (Required) The Kubernetes name of the application to back up.
    • spec.appVaultRef: (Required) The name of the AppVault where the backup contents should be stored.
    • spec.dataMover: (Optional) A string indicating which backup tool to use for the backup operation. Possible values (case sensitive):
      • Restic
      • Kopia (default)
    • spec.reclaimPolicy: (Optional) Defines what happens to a backup when released from its claim. Possible values:
      • Delete
      • Retain (default)
    • spec.snapshotRef: (Optional): Name of the snapshot to use as the source of the backup. If not provided, a temporary snapshot will be created and backed up.
      Example YAML:
      kind: Backup
      metadata:
      spec:
        dataMover: Kopia
  3. After you populate the trident-protect-backup-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-backup-cr.yaml
Create a backup using the CLI
Steps
  1. Create the backup, replacing values in brackets with information from your environment. For example:
    tridentctl-protect create backup <my_backup_name> --appvault <my-vault-name> --app <name_of_app_to_back_up> --data-mover <Kopia_or_Restic> -n <application_namespace>
    You can optionally use the --full-backup flag to specify whether a backup should be non-incremental. By default, all backups are incremental. When this flag is used, the backup becomes non-incremental. It is best practice to perform a full backup periodically and then perform incremental backups in between full backups to minimize the risk associated with restores.
Supported backup annotations
The following table describes the annotations you can use when creating a backup CR:
Annotation Type Description Default value
protect.trident.netapp.io/full-backup
string
Specifies whether a backup should be non-incremental. Set to true to create a non-incremental backup. It is best practice to perform a full backup periodically and then perform incremental backups in between full backups to minimize the risk associated with restores.
"false"
protect.trident.netapp.io/snapshot-completion-timeout
string
The maximum time allowed for the overall snapshot operation to complete.
"60m"
protect.trident.netapp.io/volume-snapshots-ready-to-use-timeout
string
The maximum time allowed for volume snapshots to reach the ready-to-use state.
"30m"
protect.trident.netapp.io/volume-snapshots-created-timeout
string
The maximum time allowed for volume snapshots to be created.
"5m"
protect.trident.netapp.io/pvc-bind-timeout-sec
string
Maximum time (in seconds) to wait for any newly created PersistentVolumeClaims (PVCs) to reach the Bound phase before the operations fails.
"1200" (20 minutes)
Create a data protection schedule
A protection policy protects an app by creating snapshots, backups, or both at a defined schedule. You can choose to create snapshots and backups hourly, daily, weekly, and monthly, and you can specify the number of copies to retain. You can schedule a non-incremental full backup by using the full-backup-rule annotation. By default, all backups are incremental. Performing a full backup periodically, along with incremental backups in between, helps reduce the risk associated with restores.
Note
  • You can create schedules for snapshots only by setting backupRetention to zero and snapshotRetention to a value greater than zero. Setting snapshotRetention to zero means any scheduled backups will still create snapshots, but those are temporary and get deleted immediately after the backup is completed.
  • Cluster-scoped resources are included in a backup, snapshot, or clone if they are explicitly referenced in the application definition or if they have references to any of the application namespaces.
Create a schedule using a CR
Steps
  1. Create the custom resource (CR) file and name it trident-protect-schedule-cr.yaml.
      • Restic
      • Kopia (default)
    • spec.applicationRef: The Kubernetes name of the application to back up.
    • spec.backupRetention: (Required) The number of backups to retain. Zero indicates that no backups should be created (snapshots only).
    • spec.backupReclaimPolicy: (Optional) Determines what happens to a backup if the backup CR is deleted during its retention period. After the retention period, backups are always deleted. Possible values (case sensitive):
      • Retain (default)
      • Delete
    • spec.snapshotRetention: (Required) The number of snapshots to retain. Zero indicates that no snapshots should be created.
    • spec.snapshotReclaimPolicy: (Optional) Determines what happens to a snapshot if the snapshot CR is deleted during its retention period. After the retention period, snapshots are always deleted. Possible values (case sensitive):
      • Retain
      • Delete (default)
    • spec.granularity: The frequency at which the schedule should run. Possible values, along with required associated fields:
      • Hourly (requires that you specify spec.minute)
      • Daily (requires that you specify spec.minute and spec.hour)
      • Weekly (requires that you specify spec.minute, spec.hour, and spec.dayOfWeek)
      • Monthly (requires that you specify spec.minute, spec.hour, and spec.dayOfMonth)
      • Custom
    • spec.dayOfMonth: (Optional) The day of the month (1 - 31) that the schedule should run. This field is required if the granularity is set to Monthly. The value must be provided as a string.
    • spec.dayOfWeek: (Optional) The day of the week (0 - 7) that the schedule should run. Values of 0 or 7 indicate Sunday. This field is required if the granularity is set to Weekly. The value must be provided as a string.
    • spec.hour: (Optional) The hour of the day (0 - 23) that the schedule should run. This field is required if the granularity is set to Daily, Weekly, or Monthly. The value must be provided as a string.
    • spec.minute: (Optional) The minute of the hour (0 - 59) that the schedule should run. This field is required if the granularity is set to Hourly, Daily, Weekly, or Monthly. The value must be provided as a string.
      Example YAML for backup and snapshot schedule:
      kind: Schedule
      metadata:
      spec:
        dataMover: Kopia
        backupRetention: "15"
        snapshotRetention: "15"
        granularity: Daily
        hour: "0"
        minute: "0"
      Example YAML for snapshot-only schedule:
      kind: Schedule
      metadata:
      spec:
        backupRetention: "0"
        granularity: Daily
        hour: "2"
        minute: "0"
  3. After you populate the trident-protect-schedule-cr.yaml file with the correct values, apply the CR:
    kubectl apply -f trident-protect-schedule-cr.yaml
Create a schedule using the CLI
Steps
  1. Create the protection schedule, replacing values in brackets with information from your environment. For example:
    Note You can use tridentctl-protect create schedule --help to view detailed help information for this command.
    tridentctl-protect create schedule <my_schedule_name> \
      --appvault <my_appvault_name> \
      --app <name_of_app_to_snapshot> \
      --backup-retention <how_many_backups_to_retain> \
      --backup-reclaim-policy <Retain|Delete (default Retain)> \
      --data-mover <Kopia_or_Restic> \
      --day-of-month <day_of_month_to_run_schedule> \
      --day-of-week <day_of_week_to_run_schedule> \
      --granularity <frequency_to_run> \
      --hour <hour_of_day_to_run> \
      --minute <minute_of_hour_to_run> \
      --recurrence-rule <recurrence> \
      --snapshot-retention <how_many_snapshots_to_retain> \
      --snapshot-reclaim-policy <Retain|Delete (default Delete)> \
      --full-backup-rule <string> \
      --run-immediately <true|false> \
    The following flags provide additional control over your schedule:
    • Full backup scheduling: Use the --full-backup-rule flag to schedule non-incremental full backups. This flag only works with --granularity Daily. Possible values:
      • Always: Create a full backup every day.
      • Specific weekdays: Specify one or more days separated by commas (for example, "Monday,Thursday"). Valid values: Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, Sunday.
        Note The --full-backup-rule flag does not work with Hourly, Weekly, or Monthly granularity.
    • Snapshot-only schedules: Set --backup-retention 0 and specify a value greater than zero for --snapshot-retention.
Supported schedule annotations
The following table describes the annotations you can use when creating a schedule CR:
protect.trident.netapp.io/full-backup-rule
string
Specifies the rule for scheduling full backups. You can set it to Always for constant full backup or customize it based on your requirements. For example, if you choose daily granularity, you can specify the weekdays on which full backup should occur (for example, "Monday,Thursday"). Valid weekday values are: Monday, Tuesday, Wednesday, Thursday, Friday, Saturday, Sunday. Note that this annotation can only be used with schedules that have granularity set to Daily.
Not set (all backups are incremental)
string
"60m"
string
"30m"
string
"5m"
string
"1200" (20 minutes)
Delete a snapshot
Delete the scheduled or on-demand snapshots that you no longer need.
Steps
  1. Remove the snapshot CR associated with the snapshot:
    kubectl delete snapshot <snapshot_name> -n my-app-namespace
Delete a backup
Delete the scheduled or on-demand backups that you no longer need.
Note Ensure the reclaim policy is set to Delete to remove all backup data from object storage. The default setting of the policy is Retain to avoid accidental data loss. If the policy is not changed to Delete, the backup data will remain in object storage and will require manual deletion.
Steps
  1. Remove the backup CR associated with the backup:
    kubectl delete backup <backup_name> -n my-app-namespace
Check the status of a backup operation
You can use the command line to check the status of a backup operation that is in progress, has completed, or has failed.
Steps
  1. Use the following command to retrieve status of the backup operation, replacing values in brackes with information from your environment:
    kubectl get backup -n <namespace_name> <my_backup_cr_name> -o jsonpath='{.status}'
Enable backup and restore for azure-netapp-files (ANF) operations
If you have installed Trident Protect, you can enable space-efficient backup and restore functionality for storage backends that use the azure-netapp-files storage class and were created prior to Trident 24.06. This funtionality works with NFSv4 volumes and does not consume additional space from the capacity pool.
Before you begin
Ensure the following:
  • You have installed Trident Protect.
  • You have defined an application in Trident Protect. This application will have limited protection functionality until you complete this procedure.
  • You have azure-netapp-files selected as the default storage class for your storage backend.
Expand for configuration steps
  1. Do the following in Trident if the ANF volume was created prior to upgrading to Trident 24.10:
    1. Enable the snapshot directory for each PV that is azure-netapp-files based and associated with the application:
      tridentctl update volume <pv name> --snapshot-dir=true -n trident
    2. Confirm that the snapshot directory has been enabled for each associated PV:
      tridentctl get volume <pv name> -n trident -o yaml | grep snapshotDir
      Response:
      snapshotDirectory: "true"
      When the snapshot directory is not enabled, Trident Protect chooses the regular backup functionality, which temporarily consumes space in the capacity pool during the backup process. In this case, ensure that sufficient space is available in the capacity pool to create a temporary volume of the size of the volume being backed up.
Result
The application is ready for backup and restore using Trident Protect. Each PVC is also available to be used by other applications for backups and restores.
