Trident Protect requirements
Contributors netapp-asubhas
Get started by verifying the readiness of your operational environment, application clusters, applications, and licenses. Ensure that your environment meets these requirements to deploy and operate Trident Protect.
Trident Protect Kubernetes cluster compatibility
Trident Protect is compatible with a wide range of fully managed and self-managed Kubernetes offerings, including:
  • Amazon Elastic Kubernetes Service (EKS)
  • Google Kubernetes Engine (GKE)
  • Microsoft Azure Kubernetes Service (AKS)
  • Red Hat OpenShift
  • SUSE Rancher
  • VMware Tanzu Portfolio
  • Upstream Kubernetes
Note
  • Trident Protect backups are supported on Linux compute nodes only. Windows compute nodes are not supported for backup operations.
  • Ensure that the cluster on which you install Trident Protect is configured with a running snapshot controller and the related CRDs. To install a snapshot controller, refer to these instructions.
  • Ensure that at least one VolumeSnapshotClass exists. For more information, refer to VolumeSnapshotClass.
  • Helm 4.x or later is required to install Trident Protect.
Trident Protect storage backend compatibility
Trident Protect supports the following storage backends:
  • Amazon FSx for NetApp ONTAP
  • Cloud Volumes ONTAP
  • ONTAP storage arrays
  • Google Cloud NetApp Volumes
  • Azure NetApp Files
Ensure that your storage backend meets the following requirements:
  • Ensure that NetApp storage connected to the cluster is using Trident 24.02 or newer (Trident 24.10 is recommended).
  • Ensure that you have a NetApp ONTAP storage backend.
  • Ensure that you have configured an object storage bucket for storing backups.
  • Create any application namespaces that you plan to use for applications or application data management operations. Trident Protect does not create these namespaces for you; if you specify a nonexistent namespace in a custom resource, the operation will fail.
Requirements for nas-economy volumes
Trident Protect supports backup and restore operations to nas-economy volumes. Snapshots, clones, and SnapMirror replication to nas-economy volumes are not currently supported. You need to enable a snapshot directory for each nas-economy volume you plan to use with Trident Protect.
Note
Some applications are not compatible with volumes that use a snapshot directory. For these applications, you need to hide the snapshot directory by running the following command on the ONTAP storage system:
nfs modify -vserver <svm> -v3-hide-snapshot enabled
You can enable the snapshot directory by running the following command for each nas-economy volume, replacing <volume-UUID> with the UUID of the volume you want to change:
tridentctl update volume <volume-UUID> --snapshot-dir=true --pool-level=true -n trident
Note You can enable snapshot directories by default for new volumes by setting the Trident backend configuration option snapshotDir to true. Existing volumes are not affected.
Protecting data with KubeVirt VMs
Trident Protect provides filesystem freeze and unfreeze capabilities for KubeVirt virtual machines during data protection operations to ensure data consistency. The configuration method and default behavior for VM freeze operations varies across Trident Protect versions, with newer releases offering simplified configuration through Helm chart parameters.
Note During restore operations, any VirtualMachineSnapshots created for a virtual machine (VM) are not restored.
Trident Protect 25.10 and newer
Trident Protect automatically freezes and unfreezes KubeVirt filesystems during data protection operations to ensure consistency. Beginning with Trident Protect 25.10, you can disable this behavior using the vm.freeze parameter during Helm chart installation. The parameter is enabled by default.
helm install ... --set vm.freeze=false ...
Trident Protect 24.10.1 to 25.06
Beginning with Trident Protect 24.10.1, Trident Protect automatically freezes and unfreezes KubeVirt filesystems during data protection operations. Optionally, you can disable this automatic behavior using the following command:
kubectl set env deployment/trident-protect-controller-manager NEPTUNE_VM_FREEZE=false -n trident-protect
Trident Protect 24.10 does not automatically ensure a consistent state for KubeVirt VM filesystems during data protection operations. If you want to protect your KubeVirt VM data using Trident Protect 24.10, you need to manually enable the freeze/unfreeze functionality for the filesystems before the data protection operation. This ensures that the filesystems are in a consistent state.
You can configure Trident Protect 24.10 to manage the freezing and unfreezing of the VM filesystem during data protection operations by configuring virtualization and then using the following command:
kubectl set env deployment/trident-protect-controller-manager NEPTUNE_VM_FREEZE=true -n trident-protect
Requirements for SnapMirror replication
NetApp SnapMirror replication is available for use with Trident Protect for the following ONTAP solutions:
  • On-premises NetApp FAS, AFF, and ASA systems. SnapMirror replication with Trident protect is not currently supported for ASA r2 systems.
  • NetApp ONTAP Select
  • NetApp Cloud Volumes ONTAP
ONTAP cluster requirements for SnapMirror replication
Ensure your ONTAP cluster meets the following requirements if you plan to use SnapMirror replication:
  • NetApp Trident: NetApp Trident must exist on both the source and destination Kubernetes clusters that utilize ONTAP as a backend. Trident Protect supports replication with NetApp SnapMirror technology using storage classes backed by the following drivers:
    • ontap-nas: NFS
    • ontap-san: iSCSI
    • ontap-san: FC
    • ontap-san: NVMe/TCP (requires minimum ONTAP version 9.15.1)
  • Licenses: ONTAP SnapMirror asynchronous licenses using the Data Protection bundle must be enabled on both the source and destination ONTAP clusters. Refer to SnapMirror licensing overview in ONTAP for more information.
    Beginning with ONTAP 9.10.1, all licenses are delivered as a NetApp license file (NLF), which is a single file that enables multiple features. Refer to Licenses included with ONTAP One for more information.
    Note Only SnapMirror asynchronous protection is supported.
Peering considerations for SnapMirror replication
Ensure your environment meets the following requirements if you plan to use storage backend peering:
  • Cluster and SVM: The ONTAP storage backends must be peered. Refer to Cluster and SVM peering overview for more information.
    Note Ensure that the SVM names used in the replication relationship between two ONTAP clusters are unique.
  • NetApp Trident and SVM: The peered remote SVMs must be available to NetApp Trident on the destination cluster.
  • Managed backends: You need to add and manage ONTAP storage backends in Trident Protect to create a replication relationship.
Trident / ONTAP configuration for SnapMirror replication
Trident Protect requires that you configure at least one storage backend that supports replication for both the source and destination clusters. If the source and destination clusters are the same, the destination application should use a different storage backend than the source application for the best resiliency.
Kubernetes cluster requirements for SnapMirror replication
Ensure your Kubernetes clusters meet the following requirements:
  • AppVault accessibility: Both source and destination clusters must have network access to read from and write to the AppVault for application object replication.
  • Network connectivity: Configure firewall rules, bucket permissions, and IP allowlists to enable communication between both clusters and the AppVault across WANs.
Note Many enterprise environments implement strict firewall policies across WAN connections. Verify these network requirements with your infrastructure team before configuring replication.
