Use CSI Topology
Trident can selectively create and attach volumes to nodes present in a Kubernetes cluster by making use of the CSI Topology feature.
Overview
Using the CSI Topology feature, access to volumes can be limited to a subset of nodes, based on regions and availability zones. Cloud providers today enable Kubernetes administrators to spawn nodes that are zone based. Nodes can be located in different availability zones within a region, or across various regions. To facilitate the provisioning of volumes for workloads in a multi-zone architecture, Trident uses CSI Topology.
Tip Learn more about the CSI Topology feature here.
Kubernetes provides two unique volume binding modes:
  • With VolumeBindingMode set to Immediate, Trident creates the volume without any topology awareness. Volume binding and dynamic provisioning are handled when the PVC is created. This is the default VolumeBindingMode and is suited for clusters that do not enforce topology constraints. Persistent Volumes are created without having any dependency on the requesting pod's scheduling requirements.
  • With VolumeBindingMode set to WaitForFirstConsumer, the creation and binding of a Persistent Volume for a PVC is delayed until a pod that uses the PVC is scheduled and created. This way, volumes are created to meet the scheduling constraints that are enforced by topology requirements.
Note The WaitForFirstConsumer binding mode does not require topology labels. This can be used independent of the CSI Topology feature.
What you'll need
To make use of CSI Topology, you need the following:
  • A Kubernetes cluster running a supported Kubernetes version
    kubectl version
    Client Version: version.Info{Major:"1", Minor:"19", GitVersion:"v1.19.3", GitCommit:"1e11e4a2108024935ecfcb2912226cedeafd99df", GitTreeState:"clean", BuildDate:"2020-10-14T12:50:19Z", GoVersion:"go1.15.2", Compiler:"gc", Platform:"linux/amd64"}
    Server Version: version.Info{Major:"1", Minor:"19", GitVersion:"v1.19.3", GitCommit:"1e11e4a2108024935ecfcb2912226cedeafd99df", GitTreeState:"clean", BuildDate:"2020-10-14T12:41:49Z", GoVersion:"go1.15.2", Compiler:"gc", Platform:"linux/amd64"}
  • Nodes in the cluster should have labels that introduce topology awareness (topology.kubernetes.io/region and topology.kubernetes.io/zone). These labels should be present on nodes in the cluster before Trident is installed for Trident to be topology aware.
    kubectl get nodes -o=jsonpath='{range .items[*]}[{.metadata.name}, {.metadata.labels}]{"\n"}{end}' | grep --color "topology.kubernetes.io"
    [node1, {"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux","kubernetes.io/arch":"amd64","kubernetes.io/hostname":"node1","kubernetes.io/os":"linux","node-role.kubernetes.io/master":"","topology.kubernetes.io/region":"us-east1","topology.kubernetes.io/zone":"us-east1-a"}]
    [node2, {"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux","kubernetes.io/arch":"amd64","kubernetes.io/hostname":"node2","kubernetes.io/os":"linux","node-role.kubernetes.io/worker":"","topology.kubernetes.io/region":"us-east1","topology.kubernetes.io/zone":"us-east1-b"}]
    [node3, {"beta.kubernetes.io/arch":"amd64","beta.kubernetes.io/os":"linux","kubernetes.io/arch":"amd64","kubernetes.io/hostname":"node3","kubernetes.io/os":"linux","node-role.kubernetes.io/worker":"","topology.kubernetes.io/region":"us-east1","topology.kubernetes.io/zone":"us-east1-c"}]
Step 1: Create a topology-aware backend
Trident storage backends can be designed to selectively provision volumes based on availability zones. Each backend can carry an optional supportedTopologies block that represents a list of zones and regions that are supported. For StorageClasses that make use of such a backend, a volume would only be created if requested by an application that is scheduled in a supported region/zone.
Here is an example backend definition:
YAML
version: 1
storageDriverName: ontap-san
backendName: san-backend-us-east1
managementLIF: 192.168.27.5
svm: iscsi_svm
username: admin
password: password
supportedTopologies:
  - topology.kubernetes.io/region: us-east1
    topology.kubernetes.io/zone: us-east1-a
    topology.kubernetes.io/zone: us-east1-b
JSON
  "version": 1,
  "storageDriverName": "ontap-san",
  "backendName": "san-backend-us-east1",
  "managementLIF": "192.168.27.5",
  "svm": "iscsi_svm",
  "username": "admin",
  "password": "password",
  "supportedTopologies": [
      "topology.kubernetes.io/region": "us-east1",
      "topology.kubernetes.io/zone": "us-east1-a"
      "topology.kubernetes.io/zone": "us-east1-b"
Note supportedTopologies is used to provide a list of regions and zones per backend. These regions and zones represent the list of permissible values that can be provided in a StorageClass. For StorageClasses that contain a subset of the regions and zones provided in a backend, Trident creates a volume on the backend.
You can define supportedTopologies per storage pool as well. See the following example:
version: 1
storageDriverName: ontap-nas
backendName: nas-backend-us-central1
managementLIF: 172.16.238.5
svm: nfs_svm
username: admin
password: password
  - topology.kubernetes.io/region: us-central1
    topology.kubernetes.io/zone: us-central1-a
    topology.kubernetes.io/zone: us-central1-b
storage:
  - labels:
      workload: production
  - labels:
      workload: dev
In this example, the region and zone labels stand for the location of the storage pool. topology.kubernetes.io/region and topology.kubernetes.io/zone dictate where the storage pools can be consumed from.
Step 2: Define StorageClasses that are topology aware
Based on the topology labels that are provided to the nodes in the cluster, StorageClasses can be defined to contain topology information. This will determine the storage pools that serve as candidates for PVC requests made, and the subset of nodes that can make use of the volumes provisioned by Trident.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
volumeBindingMode: WaitForFirstConsumer
allowedTopologies:
  - matchLabelExpressions:
    - key: topology.kubernetes.io/zone
      values:
        - us-east1-a
        - us-east1-b
    - key: topology.kubernetes.io/region
      values:
        - us-east1
parameters:
  fsType: ext4
In the StorageClass definition provided above, volumeBindingMode is set to WaitForFirstConsumer. PVCs that are requested with this StorageClass will not be acted upon until they are referenced in a pod. And, allowedTopologies provides the zones and region to be used. The netapp-san-us-east1 StorageClass creates PVCs on the san-backend-us-east1 backend defined above.
Step 3: Create and use a PVC
With the StorageClass created and mapped to a backend, you can now create PVCs.
See the example spec below:
kind: PersistentVolumeClaim
apiVersion: v1
metadata: null
spec: null
accessModes:
  - ReadWriteOnce
resources:
  requests:
    storage: 300Mi
storageClassName: netapp-san-us-east1
Creating a PVC using this manifest would result in the following:
kubectl create -f pvc.yaml
persistentvolumeclaim/pvc-san created
kubectl get pvc
NAME      STATUS    VOLUME   CAPACITY   ACCESS MODES   STORAGECLASS          AGE
pvc-san   Pending                                      netapp-san-us-east1   2s
kubectl describe pvc
Namespace:     default
StorageClass:  netapp-san-us-east1
Status:        Pending
Volume:
Labels:        <none>
Annotations:   <none>
Finalizers:    [kubernetes.io/pvc-protection]
Capacity:
Access Modes:
VolumeMode:    Filesystem
Mounted By:    <none>
Events:
  Type    Reason                Age   From                         Message
  Normal  WaitForFirstConsumer  6s    persistentvolume-controller  waiting for first consumer to be created before binding
For Trident to create a volume and bind it to the PVC, use the PVC in a pod. See the following example:
apiVersion: v1
kind: Pod
metadata:
spec:
  affinity:
    nodeAffinity:
      requiredDuringSchedulingIgnoredDuringExecution:
        nodeSelectorTerms:
        - matchExpressions:
            operator: In
            values:
            - us-east1
      preferredDuringSchedulingIgnoredDuringExecution:
      - weight: 1
        preference:
          matchExpressions:
            operator: In
            values:
            - us-east1-a
            - us-east1-b
  securityContext:
    runAsUser: 1000
    runAsGroup: 3000
    fsGroup: 2000
  volumes:
  - name: vol1
    persistentVolumeClaim:
      claimName: pvc-san
  containers:
  - name: sec-ctx-demo
    image: busybox
    command: [ "sh", "-c", "sleep 1h" ]
    volumeMounts:
    - name: vol1
      mountPath: /data/demo
    securityContext:
      allowPrivilegeEscalation: false
This podSpec instructs Kubernetes to schedule the pod on nodes that are present in the us-east1 region, and choose from any node that is present in the us-east1-a or us-east1-b zones.
See the following output:
kubectl get pods -o wide
NAME        READY   STATUS    RESTARTS   AGE   IP               NODE              NOMINATED NODE   READINESS GATES
app-pod-1   1/1     Running   0          19s   192.168.25.131   node2             <none>           <none>
kubectl get pvc -o wide
NAME      STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS          AGE   VOLUMEMODE
pvc-san   Bound    pvc-ecb1e1a0-840c-463b-8b65-b3d033e2e62b   300Mi      RWO            netapp-san-us-east1   48s   Filesystem
Update backends to include supportedTopologies
Pre-existing backends can be updated to include a list of supportedTopologies using tridentctl backend update. This will not affect volumes that have already been provisioned, and will only be used for subsequent PVCs.
