Import Trident volumes
You can import existing storage volumes as a Kubernetes PV using tridentctl import or by creating a Persistent Volume Claim (PVC) with Trident import annotations.
Overview and considerations
You might import a volume into Trident to:
  • Containerize an application and reuse its existing data set
  • Use a clone of a data set for an ephemeral application
  • Rebuild a failed Kubernetes cluster
  • Migrate application data during disaster recovery
Considerations
Before importing a volume, review the following considerations.
  • Trident can import RW (read-write) type ONTAP volumes only. DP (data protection) type volumes are SnapMirror destination volumes. You should break the mirror relationship before importing the volume into Trident.
  • We suggest importing volumes without active connections. To import an actively-used volume, clone the volume and then perform the import.
    Warning This is especially important for block volumes as Kubernetes would be unaware of the previous connection and could easily attach an active volume to a pod. This can result in data corruption.
  • Though StorageClass must be specified on a PVC, Trident does not use this parameter during import. Storage classes are used during volume creation to select from available pools based on storage characteristics. Because the volume already exists, no pool selection is required during import. Therefore, the import will not fail even if the volume exists on a backend or pool that does not match the storage class specified in the PVC.
  • The existing volume size is determined and set in the PVC. After the volume is imported by the storage driver, the PV is created with a ClaimRef to the PVC.
    • The reclaim policy is initially set to retain in the PV. After Kubernetes successfully binds the PVC and PV, the reclaim policy is updated to match the reclaim policy of the Storage Class.
    • If the reclaim policy of the Storage Class is delete, Trident deletes the storage volume when the PV is deleted.
  • By default, Trident manages the PVC and renames the FlexVol volume and the LUN or qtree on the backend. You can pass the --no-manage flag to import an unmanaged volume and the --no-rename flag to retain the volume name.
    • --no-manage - If you use the --no-manage flag, Trident does not perform any additional operations on the PVC or PV for the lifecycle of the objects. The storage volume is not deleted when the PV is deleted and other operations such as volume clone and volume resize are also ignored.
    • --no-rename - If you use the --no-rename flag, Trident retains the existing volume name while importing volumes, and manages the lifecycle of the volumes. This option is supported only for the ontap-nas, ontap-san (including ASA r2 systems), ontap-san-economy, and ontap-nas-economy (qtree import) drivers.
      Tip These options are useful if you want to use Kubernetes for containerized workloads but otherwise want to manage the lifecycle of the storage volume outside of Kubernetes.
  • An annotation is added to the PVC and PV that serves a dual purpose of indicating that the volume was imported and if the PVC and PV are managed. This annotation should not be modified or removed.
Import a volume
You can import a volume using either tridentctl import or by creating a PVC with Trident import annotations.
Note If you use PVC annotations, you don't need to download or use tridentctl to import the volume.
Using tridentctl
Steps
  1. Create a PVC file (for example, pvc.yaml) that will be used to create the PVC. The PVC file should include name, namespace, accessModes, and storageClassName. Optionally, you can specify unixPermissions in your PVC definition.
    The following is an example of a minimum specification:
    kind: PersistentVolumeClaim
    apiVersion: v1
    metadata:
      namespace: my_namespace
    spec:
      accessModes:
        - ReadWriteOnce
      storageClassName: my_storage_class
    Note Include only the required parameters. Additional parameters such as PV name or volume size can cause the import command to fail.
  2. Use the tridentctl import command to specify the name of the Trident backend containing the volume and the name that uniquely identifies the volume on the storage (for example: ONTAP FlexVol, Element Volume). The -f argument is required to specify the path to the PVC file.
    tridentctl import volume <backendName> <volumeName> -f <path-to-pvc-file>
Using PVC annotations
Steps
  1. Create a PVC YAML file (for example, pvc.yaml) with the required Trident import annotations. The PVC file should include:
    • name and namespace in metadata
    • accessModes, resources.requests.storage, and storageClassName in spec
    • Annotations:
      • trident.netapp.io/importOriginalName: Volume name on the backend
      • trident.netapp.io/importBackendUUID: Backend UUID where volume exists
      • trident.netapp.io/notManaged (Optional): Set to "true" for unmanaged volumes. Default is "false".
        The following is an example specification for importing a managed volume:
        apiVersion: v1
        metadata:
          namespace: <namespace>
          annotations:
            trident.netapp.io/importOriginalName: "<volume-name>"
            trident.netapp.io/importBackendUUID: "<backend-uuid>"
        spec:
          accessModes:
            - ReadWriteOnce
          resources:
            requests:
              storage: <size>
          storageClassName: <storage-class-name>
  2. Apply the PVC YAML file to your Kubernetes cluster:
    kubectl apply -f <pvc-file>.yaml
    Trident will automatically import the volume and bind it to the PVC.
Review the following volume import examples for supported drivers.
ONTAP NAS and ONTAP NAS FlexGroup
Trident supports volume import using the ontap-nas and ontap-nas-flexgroup drivers.
Note
  • The ontap-nas-economy driver manages storage at the qtree level, so it does not support importing a FlexVol volume on its own. To import qtrees with the ontap-nas-economy driver, refer to Import qtrees (Tech Preview). When Trident imports a qtree, it also imports the parent FlexVol as a bucket that contains the qtree.
  • The ontap-nas and ontap-nas-flexgroup drivers do not allow duplicate volume names.
Each volume created with the ontap-nas driver is a FlexVol volume on the ONTAP cluster. Importing FlexVol volumes with the ontap-nas driver works the same. A FlexVol volumes that already exists on an ONTAP cluster can be imported as a ontap-nas PVC. Similarly, FlexGroup vols can be imported as ontap-nas-flexgroup PVCs.
ONTAP NAS examples using tridentctl
The following examples show how to import managed and unmanaged volumes using tridentctl.
Managed volume
The following example imports a volume named managed_volume on a backend named ontap_nas:
tridentctl import volume ontap_nas managed_volume -f <path-to-pvc-file>
|                   NAME                   |  SIZE   | STORAGE CLASS | PROTOCOL |             BACKEND UUID             | STATE  | MANAGED |
| pvc-bf5ad463-afbb-11e9-8d9f-5254004dfdb7 | 1.0 GiB | standard      | file     | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | true    |
Unmanaged volume
When using the --no-manage argument, Trident does not rename the volume.
The following example imports unmanaged_volume on the ontap_nas backend:
tridentctl import volume nas_blog unmanaged_volume -f <path-to-pvc-file> --no-manage
| pvc-df07d542-afbc-11e9-8d9f-5254004dfdb7 | 1.0 GiB | standard      | file     | c5a6f6a4-b052-423b-80d4-8fb491a14a22 | online | false   |
ONTAP NAS examples using PVC annotations
The following examples show how to import managed and unmanaged volumes using PVC annotations.
Managed volume
The following example imports a 1GiB ontap-nas volume named ontap_volume1 from backend 81abcb27-ea63-49bb-b606-0a5315ac5f21 with RWO access mode set using PVC annotations:
apiVersion: v1
metadata:
  annotations:
    trident.netapp.io/importOriginalName: "ontap_volume1"
    trident.netapp.io/importBackendUUID: "81abcb27-ea63-49bb-b606-0a5315ac5f21"
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
Unmanaged volume
The following example imports 1Gi ontap-nas volume named ontap-volume2 from backend 34abcb27-ea63-49bb-b606-0a5315ac5f34 with RWO access mode set using PVC annotations:
apiVersion: v1
metadata:
  annotations:
    trident.netapp.io/importOriginalName: "ontap-volume2"
    trident.netapp.io/importBackendUUID: "34abcb27-ea63-49bb-b606-0a5315ac5f34"
    trident.netapp.io/notManaged: "true"
spec:
  accessModes:
    - ReadWriteOnce
  resources:
    requests:
      storage: 1Gi
Import qtrees
Note
Qtree import is a Tech Preview feature in Trident 26.06. Tech Preview features are not supported for production use.
Beginning with Trident 26.06, you can import existing ONTAP qtrees into Trident using the ontap-nas-economy driver. Identify the qtree by its FlexVol volume and qtree names in flexvol/qtree format, along with the UUID of the backend that contains it. The general import considerations in Overview and considerations also apply to qtree import.
Import a qtree using tridentctl
Specify the qtree in flexvol/qtree format as the volume name. The following example imports the qtree qtree1 from the FlexVol volume flexvol1 on the backend ontap_nas_economy:
tridentctl import volume ontap_nas_economy flexvol1/qtree1 -f <path-to-pvc-file>
To import the qtree without renaming it, add the --no-rename flag. To import the qtree without Trident managing its lifecycle, add the --no-manage flag.
Import a qtree using PVC annotations
Create a PVC with the following annotations:
apiVersion: v1
metadata:
  annotations:
    trident.netapp.io/importOriginalName: "flexvol1/qtree1"
spec:
  accessModes:
    - ReadWriteMany
  resources:
    requests:
      storage: <size>
To keep the existing FlexVol volume and qtree names, add the trident.netapp.io/importNoRename: "true" annotation. To import the qtree as unmanaged, add the trident.netapp.io/notManaged: "true" annotation.
Naming and management behavior
Managed import (default)
Trident renames the qtree to match the PVC name and renames the FlexVol volume to the ontap-nas-economy naming convention. The junction path does not change.
--no-rename
Trident keeps the existing FlexVol volume and qtree names. The names must already follow the Trident naming conventions, or Trident cannot manage delete or mount operations for the qtree.
--no-manage
Trident references the qtree but does not manage its lifecycle. The names must follow the Trident naming conventions, and Trident does not use or manage auto export policies for the qtree.
Export policy behavior
If the backend uses auto export policies, the imported qtree uses the per-qtree export policy model, in which each qtree has its own export policy. Trident assigns the qtree an empty export policy at import. At publish time, Trident updates the FlexVol volume to the per-backend export policy if auto export is enabled and the existing FlexVol export policy is default or empty.
Caution
Updating the FlexVol volume export policy can disrupt other qtrees in the same FlexVol volume that are currently mounted. Import qtrees only when the qtrees in the FlexVol volume are unmounted.
Warning
Do not point two Kubernetes clusters at the same active SVM, and do not import a qtree that another cluster still manages. If both clusters manage the same volume, conflicting operations can corrupt or destroy the data.
ONTAP SAN
Trident supports volume import using the ontap-san (iSCSI, NVMe/TCP, and FC) and ontap-san-economy drivers.
Trident can import ONTAP SAN FlexVol volumes that contain a single LUN. This is consistent with the ontap-san driver, which creates a FlexVol volume for each PVC and a LUN within the FlexVol volume. Trident imports the FlexVol volume and associates it with the PVC definition. Trident can import ontap-san-economy volumes that contain multiple LUNs.
The following examples show how to import managed and unmanaged volumes:
Managed volume
For managed volumes, Trident renames the FlexVol volume to the pvc-<uuid> format and the LUN within the FlexVol volume to lun0.
The following example imports the ontap-san-managed FlexVol volume that is present on the ontap_san_default backend:
tridentctl import volume ontapsan_san_default ontap-san-managed -f pvc-basic-import.yaml -n trident -d
| pvc-d6ee4f54-4e40-4454-92fd-d00fc228d74a | 20 MiB | basic         | block    | cd394786-ddd5-4470-adc3-10c5ce4ca757 | online | true    |
Unmanaged volume
The following example imports unmanaged_example_volume on the ontap_san backend:
tridentctl import volume -n trident san_blog unmanaged_example_volume -f pvc-import.yaml --no-manage
| pvc-1fc999c9-ce8c-459c-82e4-ed4380a4b228 | 1.0 GiB | san-blog      | block    | e3275890-7d80-4af6-90cc-c7a0759f555a | online | false   |
Warning
If you have LUNS mapped to igroups that share an IQN with a Kubernetes node IQN, as shown in the following example, you will receive the error: LUN already mapped to initiator(s) in this group. You will need to remove the initiator or unmap the LUN to import the volume.
Image of LUNS mapped to iqn and cluster iqn.
ONTAP SAN-economy examples
The following examples show how to import managed and unmanaged volumes for the ontap-san-economy backend.
Managed volume
When you import a managed volume, Trident takes ownership of the FlexVol and renames it. You must account for this renaming when you import multiple LUNs from the same FlexVol.
The following example imports lun1 from the FlexVol toimport as a managed volume named vol-managed-saneco:
tridentctl import volume vol-managed-saneco toimport/lun1 -f import1.yaml
After importing lun1, Trident renames the FlexVol (for example, to trident_lun_pool_xyz). To import additional LUNs from the same FlexVol, use the new FlexVol name:
tridentctl import volume vol-managed-saneco trident_lun_pool_xyz/lun2 -f import2.yaml
Note The ontap-san-economy backend imports one LUN at a time. You can automate multiple imports using a script.
Unmanaged volume
When you import an unmanaged volume, Trident does not take ownership of the FlexVol. However, the FlexVol and LUN must follow Trident naming conventions.
FlexVol naming format
trident_lun_pool_STORAGEPREFIX_RANDOMSTRING
  • STORAGEPREFIX is the value of storagePrefix in your backend configuration. The default is trident.
  • RANDOMSTRING is any string you choose.
LUN naming requirement
The LUN must be named lun0.
Example
If your storagePrefix is xyz, the full path to the LUN is:
trident_lun_pool_xyz_randomstring/lun0
Element
Trident supports NetApp Element software and NetApp HCI volume import using the solidfire-san driver.
Note The Element driver supports duplicate volume names. However, Trident returns an error if there are duplicate volume names. As a workaround, clone the volume, provide a unique volume name, and import the cloned volume.
The following example imports an element-managed volume on backend element_default.
tridentctl import volume element_default element-managed -f pvc-basic-import.yaml -n trident -d
| pvc-970ce1ca-2096-4ecd-8545-ac7edc24a8fe | 10 GiB | basic-element | block    | d3ba047a-ea0b-43f9-9c42-e38e58301c49 | online | true    |
Azure NetApp Files
Trident supports volume import using the azure-netapp-files driver.
Note To import an Azure NetApp Files volume, identify the volume by its volume path. The volume path is the portion of the volume's export path after the :/. For example, if the mount path is 10.0.0.2:/importvol1, the volume path is importvol1.
The following example imports an azure-netapp-files volume on backend azurenetappfiles_40517 with the volume path importvol1.
tridentctl import volume azurenetappfiles_40517 importvol1 -f <path-to-pvc-file> -n trident
| pvc-0ee95d60-fd5c-448d-b505-b72901b3a4ab | 100 GiB | anf-storage   | file     | 1c01274f-d94b-44a3-98a3-04c953c9a51e | online | true    |
Google Cloud NetApp Volumes
Trident supports volume import using the google-cloud-netapp-volumes driver.
The following example imports a volume on backend backend-tbc-gcnv1 with the volume testvoleasiaeast1.
tridentctl import volume backend-tbc-gcnv1 "testvoleasiaeast1" -f < path-to-pvc> -n trident
| pvc-a69cda19-218c-4ca9-a941-aea05dd13dc0 |  10 GiB | gcnv-nfs-sc-identity | file     | 8c18cdf1-0770-4bc0-bcc5-c6295fe6d837 | online | true    |
The following example imports a google-cloud-netapp-volumes volume when two volumes are present in the same region:
tridentctl import volume backend-tbc-gcnv1 "projects/123456789100/locations/asia-east1-a/volumes/testvoleasiaeast1" -f <path-to-pvc> -n trident
