Customize Trident operator installation
Contributors netapp-aruldeepa joan-ing juliantap netapp-shwetav netapp-mwallis
The Trident operator allows you to customize Trident installation using the attributes in the TridentOrchestrator spec. If you want to customize the installation beyond what TridentOrchestrator arguments allow, consider using tridentctl to generate custom YAML manifests to modify as needed.
Understanding controller pods and node pods
Trident runs as a single controller pod and a node pod on each worker node in the cluster. The node pod must be running on any host where you want to potentially mount a Trident volume.
Kubernetes node selectors and tolerations and taints are used to constrain a pod to run on a specific or preferred node. Using the`ControllerPlugin` and NodePlugin, you can specify constraints and overrides.
  • The controller plugin handles volume provisioning and management, such as snapshots and resizing.
  • The node plugin handles attaching the storage to the node.
Configuration options
Warning spec.namespace is specified in TridentOrchestrator to signify the namespace where Trident is installed. This parameter cannot be updated after Trident is installed. Attempting to do so causes the TridentOrchestrator status to change to Failed. Trident is not intended to be migrated across namespaces.
This table details TridentOrchestrator attributes.
Parameter Description Default
namespace
Namespace to install Trident in
"default"
debug
Enable debugging for Trident
false
enableForceDetach
ontap-san, ontap-san-economy, ontap-nas, and ontap-nas-economy only.
Works with Kubernetes Non-Graceful Node Shutdown (NGNS) to grant cluster administrators ability to safely migrate workloads with mounted volumes to new nodes should a node become unhealthy.
For information, see Automating the failover of stateful applications with Trident.
false
enableDataLIFRefresh
Enables refresh of NVMe data LIFs for published volumes when LIFs are added, removed, or assigned a new address. Applies to ontap-san with sanType: nvme on unified ONTAP and NVMe/TCP on ASA r2. For more information, see Refresh NVMe data LIFs.
false
windows
Setting to true enables installation on Windows worker nodes.
false
cloudProvider
Set to "Azure" when using managed identities or a cloud identity on an AKS cluster.
Set to "AWS" when using a cloud identity on an EKS cluster.
Set to "GCP" when using a cloud identity on a GKE cluster.
cloudIdentity
Set to workload identity ("azure.workload.identity/client-id: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx") when using cloud identity on an AKS cluster.
Set to AWS IAM role ("'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/trident-role'") when using cloud identity on an EKS cluster.
Set to cloud identity ("'iam.gke.io/gcp-service-account: xxxx@mygcpproject.iam.gserviceaccount.com'") when using cloud identity on a GKE cluster.
gcpWIFAudience
Audience for the projected service account token used with Google Cloud Workload Identity Federation on OpenShift. Use the provider's canonical resource name. For more information, see Configure Google Cloud NetApp Volumes with Workload Identity Federation.
IPv6
Install Trident over IPv6
false
k8sTimeout
Timeout for Kubernetes operations.
Note The k8sTimeout parameter is applicable only for Trident installation.
180sec
silenceAutosupport
Don't send autosupport bundles to NetApp
automatically
false
autosupportImage
The container image for Autosupport Telemetry
"netapp/trident-autosupport:26.10"
autosupportProxy
The address/port of a proxy for sending Autosupport
Telemetry
"http://proxy.example.com:8888"
uninstall
A flag used to uninstall Trident
false
logFormat
Trident logging format to be used [text,json]
"text"
tridentImage
Trident image to install
"netapp/trident:26.10.1"
imageRegistry
Path to internal registry, of the format
<registry FQDN>[:port][/subpath]
"registry.k8s.io"
kubeletDir
Path to the kubelet directory on the host
"/var/lib/kubelet"
wipeout
A list of resources to delete to perform a complete removal of
Trident
imagePullSecrets
Secrets to pull images from an internal registry
imagePullPolicy
Sets the image pull policy for the the Trident operator. Valid values are:
Always to always pull the image.
IfNotPresent to pull the image only if it does not already exist on the node.
Never to never pull the image.
IfNotPresent
controllerPluginNodeSelector
Additional node selectors for pods. Follows same format as pod.spec.nodeSelector.
No default; optional
controllerPluginTolerations
Overrides Kubernetes tolerations for pods. Follows the same format as pod.spec.Tolerations.
nodePluginNodeSelector
nodePluginTolerations
nodePrep
Enables Trident to prepare the nodes of the Kubernetes cluster to manage volumes using the specified data storage protocol.
Currently, iscsi is the only value supported.
Note Beginning with OpenShift 4.19, the minimum Trident version supported for this feature is 25.06.1.
k8sAPIQPS
The queries per second (QPS) limit used by the controller while communicating with the Kubernetes API server. The Burst value is set automatically based on the QPS value.
100; optional
enableConcurrency
Enables concurrent Trident controller operations for improved throughput. For more information on supported drivers, see the link: Controller Scalability documentation.
enableCOSI
Enables the Trident Container Object Storage Interface (COSI) frontend. Requires enableConcurrency to be set to true. Trident COSI cannot run alongside the community COSI controller. For more information, see Provision object storage with COSI.
false
resources
Sets Kubernetes resource limits and requests for the Trident controller and node pods. You can configure CPU and memory for each container and sidecar to manage resource allocation in Kubernetes.
For more information about configuring resource requests and limits, refer to Resource Management for Pods and Containers.
Warning
  • DO NOT change the names of any containers or fields.
  • DO NOT change the indentation - YAML indentation is critical for proper parsing.
Note
  • No limits are applied by default - only requests have default values and are applied automatically if not specified.
  • Container names are listed as they appear in the pod specifications.
  • Sidecars are listed under each main container.
  • Check the TORC's status.CurrentInstallationParams field to view the values currently applied.
resources:
  controller:
    trident-main:
      requests:
        cpu: 10m
        memory: 80Mi
      limits:
          cpu:
          memory:
    csi-provisioner:
      requests:
        cpu: 2m
        memory: 20Mi
      limits:
        cpu:
        memory:
    csi-attacher:
      requests:
        cpu: 2m
        memory: 20Mi
      limits:
        cpu:
        memory:
    csi-resizer:
      requests:
        cpu: 3m
        memory: 20Mi
      limits:
        cpu:
        memory:
    csi-snapshotter:
      requests:
        cpu: 2m
        memory: 20Mi
      limits:
        cpu:
        memory:
      requests:
        cpu: 1m
        memory: 30Mi
      limits:
        cpu:
        memory:
  node:
    linux:
      trident-main:
        requests:
          cpu: 10m
          memory: 60Mi
        limits:
          cpu:
          memory:
      node-driver-registrar:
        requests:
          cpu: 1m
          memory: 10Mi
        limits:
          cpu:
          memory:
    windows:
      trident-main:
        requests:
          cpu: 6m
          memory: 40Mi
        limits:
          cpu:
          memory:
        requests:
          cpu: 6m
          memory: 40Mi
        limits:
          cpu:
          memory:
      liveness-probe:
        requests:
          cpu: 2m
          memory: 40Mi
        limits:
          cpu:
          memory:
httpsMetrics
Enable HTTPS for Prometheus metrics endpoint.
false
hostNetwork
Note For more information on formatting pod parameters, refer to Assigning Pods to Nodes.
Sample configurations
You can use the attributes in Configuration options when defining TridentOrchestrator to customize your installation.
Basic custom configuration
This example, created after running the cat deploy/crds/tridentorchestrator_cr_imagepullsecrets.yaml command, represents a basic custom installation:
kind: TridentOrchestrator
metadata:
spec:
  debug: true
  namespace: trident
  imagePullSecrets:
  - thisisasecret
Node selectors
This example installs Trident with node selectors.
metadata:
spec:
  debug: true
  namespace: trident
  controllerPluginNodeSelector:
    nodetype: master
  nodePluginNodeSelector:
    storage: netapp
This example, created after running the cat deploy/crds/tridentorchestrator_cr.yaml command, installs Trident on a Windows worker node.
metadata:
spec:
  debug: true
  namespace: trident
  windows: true
Managed identities on an AKS cluster
This example installs Trident to enable managed identities on an AKS cluster.
metadata:
spec:
  debug: true
  namespace: trident
  cloudProvider: "Azure"
Cloud identity on an AKS cluster
This example installs Trident for use with a cloud identity on an AKS cluster.
metadata:
spec:
  debug: true
  namespace: trident
  cloudIdentity: 'azure.workload.identity/client-id: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxx'
Cloud identity on an EKS cluster
metadata:
spec:
  debug: true
  namespace: trident
  cloudProvider: "AWS"
  cloudIdentity: "'eks.amazonaws.com/role-arn: arn:aws:iam::123456:role/trident-role'"
Cloud identity for GKE
This example installs Trident for use with a cloud identity on a GKE cluster.
kind: TridentBackendConfig
metadata:
spec:
  version: 1
  storageDriverName: google-cloud-netapp-volumes
  projectNumber: '012345678901'
  network: gcnv-network
  serviceLevel: Premium
  storagePool: pool-premium1
Kubernetes resource requests and limits configuration for Trident controller and Trident Linux node pods
This example configures Kubernetes resource requests and limits for Trident controller and Trident Linux node pods.
Warning Disclaimer: The request and limit values provided in this example are for demonstration purposes only. Adjust these values based on your environment and workload requirements.
metadata:
spec:
  debug: true
  namespace: trident
  imagePullSecrets:
  - thisisasecret
  resources:
    controller:
      trident-main:
        requests:
          cpu: 10m
          memory: 80Mi
        limits:
          cpu: 200m
          memory: 256Mi
      # sidecars
      csi-provisioner:
        requests:
          cpu: 2m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
      csi-attacher:
        requests:
          cpu: 2m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
      csi-resizer:
        requests:
          cpu: 3m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
      csi-snapshotter:
        requests:
          cpu: 2m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
        requests:
          cpu: 1m
          memory: 30Mi
        limits:
          cpu: 50m
          memory: 128Mi
    node:
      linux:
        trident-main:
          requests:
            cpu: 10m
            memory: 60Mi
          limits:
            cpu: 200m
            memory: 256Mi
        # sidecars
          requests:
            cpu: 1m
            memory: 10Mi
          limits:
            cpu: 50m
            memory: 32Mi
Kubernetes resource requests and limits configuration for Trident controller and Trident Windows and Linux node pods
This example configures Kubernetes resource requests and limits for Trident controller and Trident Windows and Linux node pods.
metadata:
spec:
  debug: true
  namespace: trident
  imagePullSecrets:
  - thisisasecret
  windows: true
  resources:
    controller:
      trident-main:
        requests:
          cpu: 10m
          memory: 80Mi
        limits:
          cpu: 200m
          memory: 256Mi
        # sidecars
      csi-provisioner:
        requests:
          cpu: 2m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
      csi-attacher:
        requests:
          cpu: 2m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
      csi-resizer:
        requests:
          cpu: 3m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
      csi-snapshotter:
        requests:
          cpu: 2m
          memory: 20Mi
        limits:
          cpu: 100m
          memory: 64Mi
        requests:
          cpu: 1m
          memory: 30Mi
        limits:
          cpu: 50m
          memory: 128Mi
    node:
      linux:
        trident-main:
          requests:
            cpu: 10m
            memory: 60Mi
          limits:
            cpu: 200m
            memory: 256Mi
        # sidecars
          requests:
            cpu: 1m
            memory: 10Mi
          limits:
            cpu: 50m
            memory: 32Mi
      windows:
        trident-main:
          requests:
            cpu: 6m
            memory: 40Mi
          limits:
            cpu: 200m
            memory: 128Mi
        # sidecars
          requests:
            cpu: 6m
            memory: 40Mi
          limits:
            cpu: 100m
            memory: 128Mi
        liveness-probe:
          requests:
            cpu: 2m
            memory: 40Mi
          limits:
            cpu: 50m
            memory: 64Mi
