Generate an upgrade plan with Upgrade Health Checker
You can use Upgrade Health Checker to generate an upgrade plan for a single or multiple ONTAP clusters.
You can also automate generating upgrade reports to assist with maintaining up-to-date upgrade plans if you have a large, complex environment with multiple clusters.
Upgrade Health Checker supports upgrades for on-premises ONTAP versions 9.11.1 and later. If you are using Cloud Volumes ONTAP, refer to Upgrade Cloud Volumes ONTAP for information on upgrading your system.
To learn more about a specific Upgrade Health Checker parameter and the priority order for how the tool accepts input, refer to Learn about the input parameters for Upgrade Health Checker.
Set the execute permission on the binary before running it the first time:
chmod +x uhcUpgrade Health Checker is a self-contained package and will need to unpack itself before executing. This can take a few seconds. -
Before completing a full run of Upgrade Health Checker, perform a comprehensive check to ensure the tool can connect to the cluster and required endpoints:
--test allThe comprehensive check ensures the virtual machine hosting Upgrade Health Checker has:
Connectivity to the ONTAP cluster IP address through HTTPS
Connectivity to the telemetry endpoint (https://support.netapp.com/ and https://api.activeiq.netapp.com) through HTTPS
Connectivity to the auto-update endpoints (https://api.uhc.netapp.com, https://gql.aiq.netapp.com, and https://api.activeiq.netapp.com) through HTTPS (443)
At least 4 GB of available
/tmpspace
(Optional) If you want to use a configuration file to store parameters, rename the
config.yaml.examplefile located in the same location you downloaded the binary toconfig.yaml.Here is an example config.yaml file:
# Application Configuration APP: RUNS_PATH: "/opt/uhc/runs" # Cluster Credentials CLUSTER: IP: "x.x.x.x" USERNAME: "admin" PASSWORD: "xyz" TARGET_ONTAP_VERSION: "" # Optional: Specify target ONTAP version (e.g., "9.16.1" or "current" to keep existing version). Leave empty to prompt user. ACCEPT_EULA: false # Optional: Set to true to accept EULA through config. If false/empty, user will be prompted interactively.
Run Upgrade Health Checker by entering the ONTAP version you want to upgrade to and accepting the EULA, including additional parameters as needed.
The EULA is a multi-page document. Enter allto see the entire document at once and enteryto accept it.After the AutoSupport log is downloaded for a cluster, processing generally takes one to two minutes depending on the number of cluster nodes. Because different ONTAP software versions handle AutoSupport collection differently, each Upgrade Health Checker run depends on the current load of the cluster and the current ONTAP version.
Familiarize yourself with the available Upgrade Health Checker parameters, input priority order, and default values for certain parameters by referring to Learn about the input parameters for Upgrade Health Checker.
The Input Parameters Guide also provides information for specifying a custom configuration file path and run path to streamline your workflow. The best practice is to create a custom output directory for each cluster to organize your reports and logs effectively.
Run Upgrade Health Checker by accepting the EULA and entering the target ONTAP version and any additional parameters.
./uhc
After Upgrade Health Checker completes its checks, navigate to the
runsfolder to view the upgrade plan and cluster report.Each execution of the program is a "unique run" and will have all the associated data, logs and results in the associated runsfolder. -
List the generated report files:
ls -lrt -
Open the report file (named
uhc_<cluster-name>_<YYYYMMDDHHMMSS>) in a web browser, Microsoft Excel, or JSON viewer to view the report. If you are running it on a remote host, first download the report file to a machine where you can view the report on a web browser, in Excel, or in a JSON viewer.The log path and report path are as follows:
Log Path:
<output-path>/<unique-run-dir>/<cluster-name>/logs -
HTML Report Path:
<output-path>/<unique-run-dir>/<cluster-name>/results/uhc_<cluster-name>_<YYYYMMDDHHMMSS>.html -
Excel Report Path:
<output-path>/<unique-run-dir>/<cluster-name>/results/uhc_<cluster-name>_<YYYYMMDDHHMMSS>.xlsx -
JSON Report Path:
<output-path>/<unique-run-dir>/<cluster-name>/results/uhc_<cluster-name>_<YYYYMMDDHHMMSS>.json
After you've generated your upgrade plan and cluster report, you can view the Upgrade Health Checker dashboard for details of the health status of clusters assessed during the run.
