Upgrade Health Checker
Download and set up Upgrade Health Checker
Contributors netapp-yvonneo netapp-ivanad netapp-barbe netapp-asubhas
You can download Upgrade Health Checker to generate onsite, comprehensive reports before upgrading to a newer version of ONTAP.
About this task
Upgrade Health Checker supports upgrades for on-premises ONTAP versions 9.11.1 and later. If you are using Cloud Volumes ONTAP, refer to Upgrade Cloud Volumes ONTAP for information on upgrading your system.
Before you begin
Set up a virtual machine for Upgrade Health Checker with the following specifications:
Component Specification
VM
m5.large VM or equivalent with 2 vCPUs and 8 GiB RAM
Operating System
Any Linux OS with glibc library version 2.28 or higher (Ubuntu 22.04, RHEL8, or RHEL9)
Disk space
At least 4 GB free (8 GB recommended) in /tmp with execute permissions
Network
HTTPS connectivity to the ONTAP cluster(s) management LIF
ONTAP version
Cluster running ONTAP 9.11.1 or later
Hosting requirements
Place the VM in a location with cluster connectivity and internet access to allow for automatic tool updates. The machine should have access to the following endpoints through HTTPS (443) to conduct automatic updates and to enable NetApp to receive AutoSupport information about your upgrade plans:
https://support.netapp.com/
https://api.uhc.netapp.com
https://gql.aiq.netapp.com
https://api.activeiq.netapp.com
Recommended packages
Install a web server to facilitate access
Note Ensure that the virtual machine can connect to the auto-update and telemetry endpoints (https://support.netapp.com/ and https://api.activeiq.netapp.com) through HTTPS (443) to enable NetApp to receive AutoSupport information about your upgrade plans. If internet access is unavailable, you must manually download the latest version of Upgrade Health Checker.
Steps
  1. Download the Upgrade Health Checker binary by navigating to the NetApp Console Automation Hub and finding the Upgrade Health Checker tile.
  2. Set up the Upgrade Health Checker virtual machine and use SSH to place the binary in the location of your choice.
  3. Verify the digital signature of Upgrade Health Checker.
    Upgrade Health Checker has a public code signing certificate (UHC-Linux-codesigning-certificate-public.pem) and intermediate and root certificates chain (UHC-Linux-chain-certificates-public.pem).
    1. (Optional) Verify the code signing certificate against the chain:
      openssl verify -CAfile UHC-Linux-chain-certificates-public.pem UHC-Linux-codesigning-certificate-public.pem
      An output of OK confirms a valid chain of trust.
    2. Extract the public key from the code signing certificate:
      openssl x509 -in UHC-Linux-codesigning-certificate-public.pem -pubkey -noout -out UHC-Linux-public.pub
    3. Verify the signature file (uhc.sig) against the Upgrade Health Checker binary using the public key:
      openssl dgst -sha256 -verify UHC-Linux-public.pub -signature uhc.sig uhc
      An output of Verified OK confirms the signature is valid.
  4. Configure a service account and role for ONTAP cluster access. For cluster access through Upgrade Health Checker, create the service role as a REST-role.
    Note You can build an Ansible playbook to automate the deployment of the role and user to all ONTAP clusters.
    You must create the service account for the HTTP application. Use the following CLI commands to configure the necessary permissions:
    security login rest-role create -role uhctool -api /api -access readonly -vserver
    security login rest-role create -role uhctool -api /api/support/autosupport -access read_create_modify -vserver
    security login rest-role create -role uhctool -api /api/support/autosupport/messages -access read_create_modify -vserver
    vserver services web access create -name spi -role uhctool -vserver
    security login create -user-or-group-name uhctool -role uhctool -application http -authentication-method password
    security login create -user-or-group-name uhctool -role uhctool -application ssh -authentication-method password
  5. (Optional) Set up credential management to secure access to the application.
    For example, if you have CyberArk and Conjur, you can configure your environment to avoid passing credentials through a yaml file or command line.
    1. Create required CyberArk Safes:
      1. Create a Safe (Main-Conjur-Safe) that holds the application credentials and secrets
      2. Create a Safe (API-Credentials-Safe) that holds the Conjur Host ID and API Key
      3. Create a Safe (Conjur-SSL-Certificate) that holds the necessary certificate
    2. Create the configuration (Conjur.conf) and identity (Conjur.identity) files for this application:
      1. Conjur.conf
        account:
        plugins:[]
        appliance_url: https://FQDN
        cert_file: /etc/conjur.pem
      2. Conjur.identity
        machine https://FQDN/authn
        login host /prodvault/devops/<Main-Conjur-Safe>/host1
        password XXXXXX
    Here is an example of how to use CyberArk and Conjur in an Ansible playbook:
    1. Install Conjur Ansible Collection, which includes the Conjur Ansible Lookup Plugin, on Ansible Host:
      ansible-galaxy collection install cyberark.conjur
    2. Create a task in a yaml file to fetch the username and password from CyberArk:
      conjur_username: "{{ lookup('cyberark.conjur.conjur_variable', 'prodvault/devops/<Main-Conjur-Safe>/<Account name>/username', validate_certs=false) }}"
      conjur_password: "{{ lookup('cyberark.conjur.conjur_variable', 'prodvault/devops/<Main-Conjur-Safe>/<Account name>/password', validate_certs=false) }}"
What's next?
You can use Upgrade Health Checker to help you plan for an ONTAP upgrade by generating an upgrade report.
