Create a Builders workspace
A workspace in NetApp Workload Factory for Builders is a Perforce representation of a project at a specific moment in time. Workspaces are created using a project snapshot as a basis. You can create new workspaces within a Builders project. You can create workspaces from the Perforce UI.
Ensure you have integrated Builders with the Perforce Helix Visual Client. See Integrate Builders with Perforce for more information.
Log in to Perforce.
In the Perforce menu, select View > WF.
The Workload Factory login screen appears within the Perforce UI.
Log in to Workload Factory using one of the console experiences.
In the Builders workloads tile, select Create project.
Select Create workspace.
On the Create a workspace project page, provide the following:
Select a snapshot to use as a basis for the workspace.
Enter a name for the workspace.
Optionally, enter a user identifier to claim the workspace. This identifier should match the Perforce user ID of the developer that will use this workspace.
Select Create.
The workspace is created, and appears in the list of workspaces on the Workspaces page.
