Replicate data to FSx for ONTAP in NetApp Workload Factory
Replicate data in NetApp Workload Factory to protect against data loss if the region where your data resides experiences a disaster. Data replication is supported between FSx for ONTAP file systems and on-premises ONTAP systems or Cloud Volumes ONTAP. Workload Factory also supports cascading replication to extend data protection to tertiary systems or migrate your data.
When replicating storage VM data and configuration settings, you must first create and initialize the replication relationship and then wait for the data to sync at least once before completing the cutover operation.
Standard replication
Replication protects your data if a disaster affects your region and can also support migration.
Replication includes creating and initializing a replication relationship. To set up replication, create the replication relationship. To transfer the data between the source and target storage systems, initialize the replication relationship. When migrating storage VM data and configuration settings, you must also complete the cutover operation.
Replicated volumes in the target file system are data protection (DP) volumes and follow the naming format: {OriginalVolumeName}_copy.
If you replicate a source volume with immutable files, the target volume and file system remain locked until the source volume's retention period ends. The immutable files feature is available when you create a volume for an FSx for ONTAP file system.
You can replicate one source (read/write) volume or one data protection (DP) volume. Cascading replication is supported, but a third hop isn't. Learn more about cascading replication. |
Migration use cases
For migration, you can choose to replicate storage VM data and configuration settings for one storage VM. If you migrate data and configuration settings together, make sure the last replication for the volume finished within the last 24 hours. You must select all volumes in the same storage VM to use this feature. The tiering policy for all volumes defaults to the tiering policy of the source volume, which is recommended for migration use cases.
Workload Factory supports migration replication for storage VMs between the following storage systems.
On-premises ONTAP systems and FSx for ONTAP file systems
Cloud Volumes ONTAP and FSx for ONTAP file systems
FSx for ONTAP and FSx for ONTAP file systems
First to first generation
Second to second generation
To migrate storage VM data and configuration settings, you must complete three operations.
Step 1: Create the replication relationship, select Migration as the use case and select Replicate storage VM configuration.
Step 2: Initialize the replication relationship to transfer the data from the source to the target storage system.
Step 3: Cut over replication for migration use cases to test migration and then permanently migrate data and configuration settings from the source file system to the target FSx for ONTAP file system.
Replicate data between two FSx for ONTAP file systems, between an on-premises ONTAP system and an FSx for ONTAP file system, or between Cloud Volumes ONTAP and an FSx for ONTAP file system.
Review these requirements before you begin.
Confirm that one FSx for ONTAP file system is available to use for the target in the replication relationship.
Open TCP ports 11104 and 11105 for secure data transfer and management between storage systems. ICMP is optional, but can help with network checks and troubleshooting.
The FSx for ONTAP file system you use for the replication relationship must have an associated link. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
For replication from an on-premises ONTAP system to an FSx for ONTAP file system, make sure you have discovered the on-premises ONTAP system.
Replication isn't supported for volumes in a state other than available, created, or misconfigured, and when the ONTAP version isn't compatible.
For migration use cases, confirm that the last replication for the volume completed in the last 24 hours before you create a replication relationship with storage VM data and configuration settings.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the file system that contains the volume(s) to replicate.
Either replicate all volumes in a file system or replicate select volumes.
To replicate all volumes in a file system: From the file system overview, select Replicate data.
To replicate select volumes: From the file system overview, select the Volumes tab.
In the Volumes table, select one or more volumes and then select Replicate data.
On the Replicate data page, under Replication target, provide the following:
Use case: Select one of the following use cases for the replication. Depending on the selected use case, Workload Factory fills in the form with recommended values in accordance with best practices. You can accept the recommended values or make changes as you complete the form.
Artificial Intelligence (AI) and machine learning (ML): replicate your on-premises ONTAP data to FSx for ONTAP and create S3 access points to support AI and ML training in the cloud
Migration: transfers your data to the target FSx for ONTAP file system
Replicate storage VM configuration: Optionally, select to replicate storage VM data and configuration settings for a single storage VM. When migrating data and settings, all volumes must finish replication in the last 24 hours and then cut over at the same time.
During migration, clients access data from the source ONTAP file system. After cutover, volumes are available through the target FSx for ONTAP file system IP addresses. Update any clients or resources that still use the old IP address.
Hot disaster recovery: ensures high availability and rapid disaster recovery for critical workloads
Cold or archive disaster recovery:
Cold disaster recovery: uses longer recovery time objectives (RTO) and recovery point objectives (RPO) to lower costs
Archive: replicates data for long-term storage and compliance
Other
Additionally, the use case selection determines the replication policy, or SnapMirror policy (ONTAP). The terms used to describe replication policies come from ONTAP 9 documentation.
For migration and other, the replication policy is called MirrorAllSnapshots. MirrorAllSnapshots is an asynchronous policy for mirroring all snapshots and the latest active file system.
For hot, cold, or archive disaster recovery, the replication policy is called MirrorAndVault. MirrorAndVault is an asynchronous and vault policy for mirroring the latest active file system and daily and weekly snapshots.
For all use cases, if you enable snapshots for long-term retention, the default replication policy is MirrorAndVault.
FSx for ONTAP file system: Select credentials, region, and FSx for ONTAP file system name for the target FSx for ONTAP file system.
Storage VM name: Select the storage VM. The storage VM you select is the target for all selected volumes in this replication relationship.
When the source and target storage VM names are identical, we create a file system alias for the target storage VM names to avoid peering conflicts.
Volume name: The target volume name is generated automatically with the following format
{OriginalVolumeName}_copy. You can use the auto-generated volume name or enter another volume name. -
Tiering policy: Select the tiering policy for the data stored in the target volume. The tiering policy defaults to the recommended tiering policy for the use case you selected.
Balanced (Auto) is the default tiering policy when creating a volume using the Workload Factory console. For more information about volume tiering policies, refer to Volume storage capacity in AWS FSx for NetApp ONTAP documentation. Note that Workload Factory uses use-case based names in the Workload Factory console for tiering policies and includes FSx for ONTAP tiering policy names in parentheses.
If you selected the migration use case, Workload Factory automatically selects to copy the tiering policy of source volume to the target volume. You can deselect to copy the tiering policy and select a tiering policy that applies to the volume selected for replication.
Max transfer rate: Select Limited and enter the max transfer limit in MB/s. Alternatively, select Unlimited.
Without a limit, network and application performance might decline. However, we recommend an unlimited transfer rate for FSx for ONTAP file systems for critical workloads, for example, those that are used primarily for disaster recovery.
Under Replication settings, provide the following:
Initialize replication relationship: Choose to initialize the replication relationship immediately after creating the replication relationship or later. Note that initialization can be time-consuming, and you might want to run the baseline transfer in off-peak hours.
To initialize later manually, refer to the instructions in Step 2: Initialize the replication relationship.
Replication interval: Select the frequency that snapshots are transferred from the source volume to the target volume.
Long-term retention: Optionally, enable snapshots for long-term retention. Long-term retention enables business services to continue operating even through a complete site failure, supporting applications to fail over transparently using a secondary copy.
Replications without long-term retention use the MirrorAllSnapshots policy. Enabling long-term retention assigns the MirrorAndVault policy to the replication.
If you enable long-term retention, then select an existing policy or create a new policy to define the snapshots to replicate and the number to retain.
Matching source and target labels are required for long-term retention. If desired, Workload Factory can create missing labels for you. -
Choose an existing policy: select an existing policy.
Create a new policy: enter a policy name.
Immutable snapshots: Optional. Select Enable immutable snapshots to prevent snapshots taken in this policy from being deleted during the retention period.
Set the Retention period in number of hours, days, months, or years.
Snapshot policies: In the table, select the snapshot policy frequency and the number of copies to retain. You can select more than one snapshot policy.
S3 access point: Optionally, attach an S3 access point to access FSx for ONTAP file system data residing on NFS or SMB/CIFS volumes via AWS S3 APIs. Only the file access type is supported. Provide the following details:
S3 access point name: Enter the name of the S3 access point.
User: Select an existing user with access to the volume or create a new user.
User type: Select UNIX or Windows as the user type.
Network configuration: Select Internet or Virtual private cloud (VPC). The type of network you choose determines whether the access point is accessible from the internet or restricted to a specific VPC.
Enable inventory table: When you enable the inventory table on the volume, the system generates metadata for all objects accessible to the S3 access point and incurs AWS S3 request costs. Refer to Amazon S3 pricing documentation for more information.
S3 access point tags: Optionally, you can add up to 50 tags.
Select Create.
The replication relationship appears in the Replication relationships tab in the target FSx for ONTAP file system.
If you created a replication relationship for migration purposes, you must cut over all the volumes and their associated storage VM to complete migration of storage VM data and configuration settings to the target FSx for ONTAP file system.
Initialize a replication relationship between source and target volumes to transfer the snapshot and all data blocks in NetApp Workload Factory.
Initialization performs a baseline transfer: it makes a snapshot of the source volume, then transfers the snapshot and all the data blocks it references to the target volume.
Consider when you choose to complete this operation. Initialization can be time-consuming. You might want to run the baseline transfer in off-peak hours.
Select the menu
From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
From the file system overview, select the Replication relationships tab.
In the Replication relationships tab, select the actions menu of the replication relationship to initialize.
Select Initialize.
In the Initialize relationship dialog, select Initialize.
When the replication status shows Idle, the data transfer is complete.
After creating the replication relationship for a migration use case, you must cut over replication to complete migration of storage VM data and configuration settings to the target FSx for ONTAP file system. Cutover replication permanently migrates data and storage VM configuration settings from the source file system to the target FSx for ONTAP file system. During the cutover, Workload Factory replicates the data one last time. The source storage VM goes offline when the cutover begins.
Plan for the cutover operation
Consider the following before you test and cut over.
Replication version support: Source and target storage systems must have the same major ONTAP version. For example, if the source system is running ONTAP version 9.18.1, then the target system must also run ONTAP version 9.18.1.
Storage VM configuration settings:
The cutover operation doesn't migrate all storage VM configuration settings to the target storage VM. For example, iSCSI, broadcast-domain MTU, and DNS settings do not migrate. Update these settings manually on the target storage VM after cutover.
If your storage VM uses domain-tunnel authentication, set up and enable a domain tunnel on the target file system before you start the migration.
Clones: The cutover operation migrates clones as individual volumes, which consume more space on the target FSx for ONTAP file system. Consider deleting the clones before cutover to avoid increased capacity on the target.
Cache volumes: Source storage VMs that contain cache volumes aren't supported for cutover. Remove the ONTAP FlexCache relationship before cutover to avoid migration failures.
AWS S3 access points: Cutover replication for migration use cases isn't supported for volumes with S3 access points. Delete S3 access points from the source volume to avoid migration failures.
ONTAP S3 configurations: Cutover replication for migration use cases isn't supported for storage VMs with ONTAP S3 configurations. Remove ONTAP S3 configurations including object-store-server, buckets, users, groups, or policies on the storage VM, to avoid migration failures.
LUN serial numbers and iSCSI target IQN: LUN serial numbers and the iSCSI target IQN change during cutover.
Check that the SVM migration status is Enabled | Ready to test cutover in the Replication relationships table from within the file system in Workload Factory.
Stop any client access to your storage VM before you cut over replication.
Confirm that no source volume is serving data before you cut over replication.
Confirm that the data is synced between the source and target volumes before you cut over replication.
The following ports must be open in the security group associated with the FSx for ONTAP file system for link connectivity: port 443 (HTTPS) and port 22 (SSH).
Workload Factory helps you manage the cutover process for replication in migration use cases. First, it tests your environment to confirm that the cutover can proceed without issues. Second, it performs the actual cutover to the target file system.
Before you complete the migration test, make sure you can access all the data on the target storage VM.
Follow the instructions to cut over replication for migration use cases. The user interface guides you through the cutover process step by step.
Select the menu
Select the Replication relationships tab.
In the Replication relationships table, select the replication relationship to cut over and then select Cut over replication.
Complete the steps to test the cutover and then perform the actual cutover.
If you close the dialog during the process, you can check the SVM migration status from the Replication relationships tab and continue the cutover operation when ready.
Review the information in the Cut over replication dialog and then type cut over to complete the process.
Select Cut over.
After initiating cutover, the source storage VM goes offline.
Update configuration settings after cutover
After you cut over replication for migration use cases, update the following storage VM configuration settings on the target storage VM.
For iSCSI:
Recreate the igroup
Update LUN mapping
Log in to each SAN client and update iSCSI/MPIO settings for the new target and remove the old storage VM target IPs
Validate broadcast-domain MTU settings are as expected
Validate DNS settings are as expected
Recreate cache relationships (ONTAP FlexCache relationships) if there were cache volumes in the source storage VM.
If needed, modify the tiering policy for the target volume(s) after cutover.
Cascade replication for data protection volumes
NetApp Workload Factory supports replicating data protection volumes, also called cascade deployments. A cascade deployment consists of a chain of relationships in which a source volume is mirrored to a secondary volume (first hop), and the secondary volume is mirrored to a tertiary volume (second hop). If the secondary volume becomes unavailable, you can synchronize the relationship between the primary and tertiary volumes without performing a new baseline transfer.
This feature is supported for FSx for ONTAP file systems with ONTAP version 9.6 and higher. Refer to ONTAP documentation for compatible ONTAP versions.
Learn more about how cascade deployments work.
Consider the following before you begin:
Volumes that are part of a cascade configuration can take longer to resynchronize.
If the source volume of the relationship is a data protection volume and is a target of another relationship, reversing the replication relationship isn't supported.
One replica of a data protection volume (or a second hop) is supported. Creating a second replica of a data protection volume (or a third hop) isn't a best practice.
Select the menu
From FSx for ONTAP, select the actions menu of the file system that contains the volume(s) to replicate and then select Manage.
In the Volumes table, select one or more data protection volumes (DP/replicated volumes), and then select Replicate data.
Other
Select Create.
The replicated volume or volumes replicate and appear in the Replication relationships tab in the target FSx for ONTAP file system.
Related information
Modify the tiering policy for the target volume(s) after cutover.
