Enable volume autogrow in NetApp Workload Factory
Enable volume autogrow to let Workload Factory manage volume capacity for you. You can disable it at any time.
Optionally, you can manually increase the volume capacity of a volume at any time using the adjust volume capacity feature.
Volume autogrow isn't supported for iSCSI volumes. |
To enable volume autogrow, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu for the volume you want to modify.
Select Basic actions, then Set volume autogrow.
In the Set autogrow dialog, enable volume autogrow to automatically expand the volume capacity until the volume reaches the maximum size. This feature accommodates increasing data usage, ensuring uninterrupted operations.
Specify the maximum volume growth size and unit. The maximum growth size cannot be smaller than the current volume size.
Select Apply.
