Manage the SMB/CIFS share for a volume in NetApp Workload Factory
Create, change, or delete an SMB/CIFS share for a volume in Workload Factory. Control which users and groups can access the share and the level of permissions they have.
Before you begin, do the following:
To manage SMB/CIFS shares, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Determine the users or groups to give access to and the level of permissions to give them.
Create an SMB/CIFS share for a volume
Create an SMB/CIFS share for a volume.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu of the volume to change the SMB share for.
Select Advanced actions, then Manage SMB/CIFS shares.
On the Manage SMB/CIFS shares page, select Create SMB/CIFS share.
In the Create SMB/CIFS share dialog, provide the following:
Name: Enter the name of the SMB/CIFS share.
Path: Define the path using the default volume name, or provide a share to an internal directory.
Valid path inputs for volume name, for example "avocado", are as follows:
/avocado
/avocado/folder
/avocado/folder/subfolder
/avocado/file-name
Valid path inputs for share name, for example "Server", are as follows:
\\Server
\\Server\Projects
\\Server\Projects\Shared resources
Permissions: Select Full control, Read/Write, Read, or No access, and then enter the users or groups separated by a semicolon ( ; ). Users or groups are case sensitive and the user's domain must be included using the format "domain\username".
Select Create.
Change an SMB/CIFS share for a volume
Change the SMB/CIFS share settings for a volume.
Select the menu
In the FSx for ONTAP tab, select the actions menu of the file system with the volume to update and then select Manage.
From the file system overview, select the Volumes tab.
From the Volumes tab, select the actions menu of the volume to change the SMB share for.
On the Manage SMB/CIFS shares page, select View and edit.
Change the SMB/CIFS access permissions, or the users or groups to give permissions to.
Changes might cause current users or groups to lose access to the SMB/CIFS share.
Select Apply to save the changes.
Delete an SMB/CIFS share for a volume
Follow the steps to delete an SMB/CIFS share for a volume.
Select the menu
On the Manage SMB/CIFS shares page, select the actions menu of the SMB/CIFS share and then select Delete.
Deleting the SMB/CIFS share makes it unavailable and inaccessible to any users who want to mount it.
In the Delete SMB/CIFS share dialog, select Delete to confirm deletion.
