Amazon FSx for NetApp ONTAP
Manage snapshots of an FSx for ONTAP volume
Contributors netapp-rlithman
Edit snapshot settings, enable directory access, and delete snapshots to manage your snapshots and data protection in Workload Factory.
Edit a snapshot
Edit the name, label, and retention period of a snapshot. If the snapshot isn't already immutable, you can make the snapshot immutable.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select Volumes explorer.
  4. Select the actions menu for the volume with the snapshot to edit.
  5. Select Data protection actions and then Manage snapshots.
  6. From the Manage snapshots page, select the actions menu for the snapshot to edit, and then select Edit.
  7. In the Edit a snapshot dialog, edit the following settings:
    1. Change the name.
    2. Change the label.
    3. Change the retention period.
    4. Optional: Make this snapshot immutable to prevent the snapshot from being deleted during the retention period.
      If the snapshot is already immutable, you can't edit this setting.
      Accept the statement regarding immutable snapshots.
  8. Select Apply.
Access a snapshot
Enable snapshot directory access so users can access snapshots autonomously.
Steps
  4. Select the actions menu for the volume with the snapshot to access.
  6. From the Manage snapshots page, select the actions menu for the snapshot to access, and then select Access.
  7. In the Access snapshot dialog, select Enable snapshot directory access to access this volume snapshot and all snapshots of the volume.
    • For NFS volumes: Select NFS access path to view the NFS path for the snapshot.
    • For SMB/CIFS volumes: Select SMB access path to view the SMB path for the snapshot.
  8. Copy the access path.
  9. Select Apply.
Restore data from a snapshot
You can restore data from a snapshot to an existing volume or to a new volume.
Delete a snapshot
Delete a snapshot to free up space.
You can't delete immutable snapshots until the retention period ends.
Steps
  4. Select the actions menu for the volume with the snapshot to delete.
  6. From the Manage snapshots page, select the actions menu for the snapshot to delete, and then select Delete.
  7. In the Delete snapshot dialog, type "delete".
  8. Select Delete to confirm deletion.
