Create a snapshot policy for storage VMs in NetApp Workload Factory
Create a custom snapshot policy for storage VMs in Workload Factory to manage snapshot creation and retention. A snapshot policy defines how the system creates snapshots for a storage VM. You can create a snapshot policy for a storage VM in an FSx for ONTAP file system. You can also share the policy across multiple storage VMs.
You can create a custom snapshot policy that differs from the three built-in snapshot policies for FSx for ONTAP:
default -
default-1weekly -
none
By default, every volume is associated with the file system's default snapshot policy. We recommend using this policy for most workloads.
Customizing a policy lets you specify when to create snapshots, how many copies to retain, and how to name them.
Once a snapshot policy is created, its association with the storage VM(s) cannot be modified, but you can always add or remove the policy from volumes.
Consider the following about snapshot capacity before you use snapshots:
For most datasets, an additional capacity of 20% is enough to keep snapshots for up to four weeks. As data gets older, its use for restorations becomes less likely.
Overwriting all the data in a snapshot consumes significant volume capacity, which factors into provisioning volume capacity.
To create a custom snapshot policy, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After the link associates, return to this operation.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system with the volume and then select Manage.
In the file system overview, select the Storage VMs tab.
From the Storage VMs tab, select the actions menu for the volume to protect with scheduled snapshots, then Advanced actions, and then Manage snapshot policies.
On the Snapshot policy management page, select Create snapshot policy.
In the Snapshot policy name field, enter a name for the snapshot policy.
Optionally, enter a description for the snapshot policy.
Under Policy schedule and copies, select when to create snapshots. For example, every minute or hourly.
You can select more than one frequency.
Under Number of copies, enter the number of copies to retain.
The maximum number of copies is 1,023.
Optional: Under Naming convention, enter a Prefix for the policy.
Retention label is automatically populated.
This label refers to the SnapMirror, or replication label that is used to select only specified snapshots for replication from the source to the target file system.
Optional: Enable Immutable snapshots for any schedules you need, set the Retention period for each schedule, and accept the statement to continue.
Enabling immutable snapshots locks all snapshots in this snapshot policy to prevent the snapshots from being deleted during the retention period.
Share across storage VMs: Enabled by default. When enabled, the snapshot policy is shared across all storage VMs in the file system. Disable to create a snapshot policy for a single storage VM.
Select Create.
