Split a cloned volume in NetApp Workload Factory
Split a cloned FlexVol volume from its parent volume to make the clone a normal read/write FlexVol volume in NetApp Workload Factory.
Data is accessible on the clone and the parent during the split. The split process only updates metadata and requires minimal IO. No data blocks are copied.
The clone splitting operation involves the following:
You can't create new snapshot copies of the FlexClone volume during the split operation.
You can't split a FlexClone volume from its parent volume if it belongs to a data protection relationship.
If you take the FlexClone volume offline during the split, the split operation suspends. When you bring the FlexClone volume back online, the split operation resumes.
After the split, both the parent FlexVol volume and the clone require the full space allocation determined by their volume guarantees.
After you split a FlexClone volume from its parent, you can't rejoin them.
Consider the following before you split a cloned volume:
To split a cloned volume, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
The FlexClone volume must be online when the split operation begins.
The parent volume must be online for the split to succeed.
Log in using one of the console experiences.
Select the menu
and then select Storage.-
From the Storage menu, select Volumes explorer.
Select the actions menu of the volume with the cloned volume to split.
Select Data protection actions, then Split cloned volume.
In the Split volume dialog, select Delete.
The volume clone is split and appears in the Volumes tab.
