Check and rebalance volume capacity in NetApp Workload Factory
Check the balance of FlexVol or FlexGroup volume capacity and rebalance volume capacity to spread files evenly across all FlexVol volumes in a node or across all constituents so that all nodes participate in the workload of a single FlexGroup volume.
About this task
Rebalancing volume capacity is supported for FlexVol volumes and FlexGroup volumes. Rebalancing a volume redistributes the capacity when imbalances develop over time due to the addition of new files and file growth. After you manually start the rebalance operation, we select the files and move them automatically and non-disruptively. Volume transfer operations consume file system resources.
Each volume type and rebalancing operations differ as follows.
FlexVol volumes are logical containers that offer flexibility in managing data, allowing for expansion, contraction, movement, and efficient copying. They can be used with NAS and SAN environments.
A FlexVol volume can be balanced in relation to other FlexVol volumes within one node in an FSx for ONTAP file system. If the file system has only a single FlexVol volume, then rebalancing isn't possible. When the file system has more then one FlexVol volume per node and a single FlexVol volume is selected, the FlexVol volume is balanced in the context of all FlexVols but only the selected volume is allowed to move.
FlexGroup volumes, on the other hand, are scalable NAS containers designed for high performance and automatic load distribution. They consist of multiple member volumes (constituents) that share traffic transparently. FlexGroup volumes provide massive capacity, exceeding FlexVol limits, with up to 60PB capacity and 400 billion files. They simplify management by offering a single namespace container.
Capacity is spread across a number of constituents in a scale-out FSx for ONTAP file system with two or more high availability (HA) pairs. Each constituent is a container that dictates the maximum single file size. FSx for ONTAP spreads files across all constituents in an even way so all nodes participate in the workload of a single FlexGroup volume.
When the constituents aren't distributed evenly across all nodes, FlexGroup volume performance decreases.
Checking the balance of FlexGroup volume capacity includes assessing the current layout of constituents. When you rebalance the volume's capacity, NetApp Workload Factory designs a new constituent layout with an even number of constituents to spread the data evenly across all HA pairs. The service executes the rebalance plan which in turn improves read and write operations.
Rebalancing isn't supported for SAN volumes like iSCSI and NVMe. |
Check the balance of your volumes
Check the balance of FlexVol or FlexGroup volumes in an FSx for ONTAP file system.
FlexGroup volume balance is available only for FSx for ONTAP file systems using a scale-out deployment with at least two HA pairs.
To check the balance of a volume, you must associate a link. If you don't have an existing link, create a link. To associate a link in the file system, select Associate link under Account name. After the link associates, return to this operation.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system that contains volumes to rebalance and then select Manage.
From the file system overview, select the Volumes tab.
From the Volumes tab, select Check volume balance at the top of the table.
In the Volume balance window, review the balance status of:
FlexGroup volumes
FlexVol volumes
When a volume is unbalanced, consider rebalancing it.
Rebalance volume capacity
Rebalance one or more unbalanced volumes.
A Workload Factory admin can stop rebalancing during the operation. |
Check the balance of a volume before rebalancing volumes.
To rebalance a volume, you must associate a link. If you don't have an existing link, create a link. To associate a link in the file system, select Associate link under Account name. After the link associates, return to this operation.
Note that existing snapshots on volumes you rebalance become partial and cannot be used to restore volume data, but new snapshots taken after rebalancing can be used to restore volume data.
FlexVol volumes are best rebalanced altogether to balance all volume resources evenly. Deselected volumes don't actively participate in the balancing procedure.
A FlexVol volume can be balanced in relation to other FlexVol volumes within one node in an FSx for ONTAP file system. When the file system has more then one FlexVol volume per node and a single FlexVol volume is selected, then the FlexVol volume is balanced in the context of all FlexVols but only the selected volume is allowed to move.
Select the menu
From FSx for ONTAP, select the actions menu of the file system that contains the volume to rebalance and then select Manage.
In the Volumes balance window, optionally select Data distribution in the FlexVol balance summary to view used capacity per aggregate.
Select Rebalance to rebalance one or more unbalanced volumes.
In the Rebalance wizard, follow the steps.
Max transfer rate: Optional. Disabled by default. Enable throttling to limit the bandwidth of a volume move on your file system and to slow outgoing volume replication traffic.
Enter the throttle value in MB/s.
Select Next.
Review the current and proposed layouts of all FlexVol volumes, and then select Next.
Carefully review what will happen and the note before beginning the rebalance operation.
Select Rebalance.
The FlexVol volume is rebalanced. When the operation completes, the file system will be throttled back to the original value.
Data redistributes across member volumes to rebalance the FlexGroup volume. Based on your chosen layout, the rebalance operation might add FlexGroup member volumes and increase the size of provisioned volumes.
In Storage, select Go to Storage
From the Volumes tab, select Check FlexGroup balance at the top of the table.
In the FlexGroup balance window, select Rebalance to rebalance one or more unbalanced volumes.
In the Rebalance wizard, select the data distribution layout that you prefer.
Performance-optimized (recommended): increases the number of FlexGroup member volumes and the provisioned size of the volume. Follows NetApp best practice.
Restricted: supports volumes in a replication relationship. The number of FlexGroup member volumes and the size of provisioned volumes remains the same. Selected by default if all selected volumes participate in a replication relationship.
Manual: Select the desired number of FlexGroup member volumes per HA pair. Depending on your selection, the number of FlexGroup member volumes and the provisioned size of the volume might increase.
Throttling: Optional. Disabled by default. Enable throttling to limit the bandwidth of a volume move on your file system and to slow outgoing volume replication traffic.
Select a layout comparison view and then select Next.
Volume layout comparison
FSx for ONTAP layout comparison
Optionally, download a list of volume moves before rebalancing.
Select Rebalance.
FlexGroup member volumes are moved one at a time during rebalancing. When the operation completes, the file system will be throttled back to the original value.
Stop a volume rebalance operation
Stop a rebalance operation at any time; it isn't disruptive. Stopping the operation aborts active volume moves.
You can start another rebalance operation later.
After you begin the rebalance operation, from the Volume balance page, select Stop rebalancing.
In the Stop rebalancing dialog, select Stop.
The volume rebalance operation stops and active volume moves abort.
