Amazon FSx for NetApp ONTAP
What's new in Amazon FSx for NetApp ONTAP in NetApp Workload Factory
Contributors netapp-rlithman netapp-sineadd netapp-mwallis RSS
Review new features and enhancements for Amazon FSx for NetApp ONTAP in NetApp Workload Factory, organized by release date.
01 November 2026
Initiator group diagram enhancements
The diagram that displays initiator groups for block devices on the Manage Client Access page now includes more details for hosts. When you hover over a host in the diagram, host details appear, including the host name, instance ID, workload type, region, and iSCSI Qualified Name (IQN).
Email enhancement for well-architected issues
The new email design provides more details and context for configuration issues detected by Workload Factory. The email includes the number of analyzed resources, how many have warning or critical issues, and what those issues are. The email also links to the FSx for ONTAP well-architected dashboard so you can address issues right away.
Well-architected dashboard enhancements
Support for selected configuration checks
You can manually run analysis on selected configurations so that you analyze only the configurations you're interested in and reduce wait time.
New recommendations in the well-architected analysis
Workload Factory now includes the following configurations in the well-architected analysis for FSx for ONTAP file systems:
For storage workloads:
  • Connect host to failover node: checks whether hosts are connected to the failover node in an active-passive FSx for ONTAP file system for reliability.
  • Connect host to preferred node: checks whether hosts are connected to their block devices using the preferred node for performance efficiency.
  • ARP/AI multi-device detection gap: ARP/AI provides full protection coverage when a volume has only one block device attached to it. If a volume has multiple block devices attached, Workload Factory moves the block devices to new volumes so that each volume has only one block device.
  • Clone cleanup: checks whether there are any volume clones older than 30 days that can be deleted to optimize storage usage and reduce costs.
  • Match igroup OS to host: checks whether the operating system of the initiator group (igroup) matches the host's operating system to prevent I/O or performance issues.
For Kubernetes workloads:
  • QoS configuration: checks whether Kubernetes persistent volumes are protected with an ONTAP QoS policy for performance efficiency.
  • Dedicated Kubernetes storage VM: checks whether the file system is using a dedicated storage VM for Kubernetes workloads to improve isolation and simplify storage management.
  • Dedicated Kubernetes export policy: checks whether each Kubernetes persistent volume has a dedicated export policy that only allows access from the cluster's worker nodes.
  • Bidirectional CHAP for Kubernetes iSCSI backends: checks whether Trident iSCSI backends have mutual CHAP authentication enabled for security.
  • Disable showmount on the application storage VM: checks whether showmount is disabled on the application storage VM to prevent clients from listing exports they can't access.
For database workloads:
  • SAP HANA snapshot policy: checks whether the snapshot policy is set to "None" for SAP HANA volumes to lower storage costs and improve performance for active database data.
  • MySQL snapshot policy: checks whether the snapshot policy is set to "None" for MySQL volumes to lower storage costs and improve performance for active database data.
  • PostgreSQL snapshot policy: checks whether the snapshot policy is set to "None" for PostgreSQL volumes to lower storage costs and improve performance for active database data.
You can view the current and recommended values for some unoptimized configurations in the well-architected dashboard. This tells you what the recommended value is before you fix it.
  • Cold data tiering
  • Snapshot policy
  • SSD capacity headroom
Cost improvements
Cost forecasting and insights
You can now forecast costs for your FSx for ONTAP file systems using the cost forecasting feature. This helps you plan your budget and optimize your resources effectively. You can also view insights about your costs and usage patterns to identify opportunities for cost optimization.
AWS Cost and Usage Reports (CUR)
Workload Factory now uses AWS Cost and Usage Reports (CUR) instead of AWS Cost Explorer to provide detailed billing records delivered to customer-owned S3 buckets. CUR offers better cost granularity and serves as the foundation for advanced FinOps, chargeback, and cost allocation use cases.
Storage VM migration improvements
Workload Factory provides enhanced guidance within the user interface for migrating storage VMs. This includes step-by-step instructions and a test run before committing the migration to production.
Replication lag email notification improvement
When a large number of related replication lag events occur, Workload Factory automatically consolidates them into a single email notification so you won't get overwhelmed by notifications.
Automatic capacity management enhancement
You can now turn on automatic capacity management notifications to try out the feature before asking Workload Factory to manage your capacity automatically. You'll be notified when your file system is running low on capacity.
Throughput decision points
You can now see client throughput recommendation and automation decision points. Hover over a decision point to view details, such as the current and recommended SKU or breached metrics in time window (%).
Customer-managed Bedrock support for classification
Workload Factory now lets you use your own Amazon Bedrock setup for workload tagging classification. You can provide your own Bedrock endpoint and credentials so that classification requests run through your own Bedrock configuration.
30 September 2026
Expanded workload tagging discovery for AWS services
Workload Factory now detects more AWS services for workload tagging, expanding support for resources that can be tagged. It can now find Amazon EKS and Amazon WorkSpaces resources and include them in the tagging system so they are available for tagging.
Cost dashboard enhancements
The cost dashboard now includes a cost executive summary section that provides an overview of your organization's spending, helping you quickly understand and manage costs. Ask Me, the AI assistant for Workload Factory, can provide additional insights and recommendations based on your cost data. You can interact with Ask Me to get detailed explanations and suggestions for optimizing your costs.
In addition, you can filter the cost data by one or more file systems and one or more volumes within a file system. When filters are applied, Workload Factory displays:
  • Estimated total cost per month
  • Estimated cost per GiB/month
  • Detailed cost breakdown by service
All cost information comes directly from the AWS Cost Explorer API except for file system and volume-level cost allocation; Workload Factory estimates file system- and volume-level cost allocation.
Well-architected dashboard access
You can access the well-architected dashboard from the main menu in the Workload Factory console and from within a file system. To find the well-architected dashboard from the main menu, select the main menu and then select Well-architected.
Well-architected menu option in the Workload Factory console
  • Volume space management configuration: recommends enabling coordinated volume space management for FSx for ONTAP volumes.
  • FSx integration to AWS MGN: recommends applying the required AWS MGN readiness configuration to selected FSx for ONTAP file systems.
Volumes explorer enhancements
Volumes explorer is a central place in the Workload Factory console where you can view and manage all your volumes across different file systems. It provides detailed information about each volume, including its performance, usage, and protection status. The enhancements for this release include workload selection, volume latency display, and ARP/AI status for volumes.
Volumes explorer supports workload selection
Workload Factory selects a workload by default based on the characteristics of the volume and its usage patterns. Now you can change the workload for one or more volumes from Volumes explorer.
Volumes explorer displays volume latency
Volumes explorer displays volume latency status with the following statuses: not configured, within threshold, and exceeded. These statuses help you find and fix performance bottlenecks at the volume level.
Volumes explorer displays ARP/AI status for volumes across all file systems
The Volumes explorer screen now includes a card with NetApp Autonomous Ransomware Protection with AI (ARP/AI) status for volumes across all your file systems. The card displays the number of protected volumes and indicates whether any volumes are at risk. From the card, you can Analyze attacks to investigate potential ransomware threats and take appropriate actions to secure your data.
Screenshot shows a new card on the Volumes explorer screen displaying ARP/AI status for volumes across all file systems. The card indicates the number of protected volumes and any volumes at risk. Users can select the text Analyze attacks to investigate suspected attacks and take appropriate actions to secure their data.
Email notification for unhealthy replication relationships
When the status of a replication relationship is unhealthy, Workload Factory sends an email notification every 24 hours while the relationship remains unhealthy. Reminder notifications stop when the relationship returns to a healthy state.
Support for restricted ONTAP credentials for AIOps
Workload Factory supports two types of ONTAP credentials for an FSx for ONTAP file system: primary and restricted. By default, a file system uses the primary ONTAP credentials. We use restricted credentials only for AI operations (AIOps) like Rule builder, Custom dashboards, and Ask Me, our AI assistant. Now you can add your own credentials, using either a username and password or a secret ARN, to restrict access for AIOps features.
Workload selection during volume creation
Workload Factory now includes a Workloads field in volume creation so that you can select the workload to associate with the volume. This ensures that the volume is optimized for the intended workload from the moment it is created.
FlexCache write mode improvement
Workload Factory now recognizes the preferred FlexCache write mode for volumes and recommends changing it if necessary to optimize performance.
All link documentation is now covered in the Workload Factory setup and administration documentation. You can still refer to the Learn about NetApp Workload Factory links from the Workload Factory FSx for ONTAP documentation and find links to the relevant pages in the setup and administration documentation.
Cross-region host-to-storage relationship discovery
Workload Factory now supports finding connections between hosts and storage across multiple AWS regions as part of the workload tagging service. It can identify and link hosts and storage resources across regions, including mapping IP addresses between regions, so host-to-storage relationships are tagged and classified correctly.
Improved workload and host identification accuracy
Workload Factory now more accurately identifies and classifies workloads and hosts in the workload tagging service. Updated detection methods reduce misclassification and provide more accurate tagging and classification results.
Improved file system visibility in the interface
Workload Factory now gives you a clearer view of your file systems in the interface. You can view SSD capacity and throughput usage trends, workload summaries, and detailed configuration information directly from the file system overview. Workload Factory now more accurately identifies and classifies workloads and hosts in the workload tagging service. Updated detection methods reduce misclassification and provide more accurate tagging and classification results.
30 September 2026
1 November 2026
  • Cold data tiering
  • Snapshot policy
Cost improvements
30 September 2026
30 September 2026
30 August 2026
You can now create links directly from the Links page in the Administration menu, in addition to the FSx for ONTAP inventory page and the file system overview page.
Workload identification
  • Workload Factory now identifies workloads for hosts connected to FSx for ONTAP storage deployed in a different region.
  • Improved workload detection logic now discovers additional workload types and improves findings accuracy.
11 August 2026
Volume actions available in Volumes explorer
All volume actions are directly available from Volumes explorer for one or more volumes. This makes it quicker to perform volume-level operations. Volume actions include modifying volume settings, managing snapshots, and doing other volume tasks without leaving Volumes explorer. You can also access these actions from the Volumes tab in the FSx for ONTAP file system overview.
02 August 2026
New well-architected dashboard available for all FSx for ONTAP systems
The well-architected analysis is now available for FSx for ONTAP file systems from the new well-architected dashboard in NetApp Workload Factory. The new dashboard provides a centralized view of all your file systems across accounts and regions and their configurations in one place. A popup notification appears when you visit the Well-architected tab from a file system. Access the new dashboard by selecting Well-architected from the left navigation menu in Workload Factory.
You can still access the well-architected analysis for a specific file system and from the Well-architected menu option in Storage.
New widgets added to the Storage dashboard
The Storage dashboard now includes two new widgets to help you understand how you use storage and find ways to optimize it.
  • Top discovered workloads Shows workload data found by the tagging service across your environment. View workloads with a confidence score above 80% that include associated FSx resources, such as volumes and block devices. Each workload shows its name, number of resources, provisioned capacity, and used capacity. Sort by resource count (default), provisioned capacity, or used capacity to quickly identify your largest workloads and understand storage usage patterns.
  • AI-powered insights and observations Shows AI-generated insights for your managed assets. The widget reviews your estate data within the selected scope and highlights the top three findings in key areas, including capacity, performance, data protection, replication, cost savings, and storage trends.
Each insight includes a summary, detailed findings, and recommended actions. Expand an insight to see more details and prioritize issues based on severity, performance improvements, and cost-saving opportunities.
Workload tagging
AWS Systems Manager integration for workload tagging
The workload tagging service now works with AWS Systems Manager to add more details to host inventory data. Workload Factory can now collect and process SSM inventory information to better identify and classify workloads. AWS SSM attributes are also included in the tagging process to improve workload discovery accuracy.
Every volume-related configuration in the well-architected dashboard now includes the Workload column in the resource table. This column shows the workload that Workload Factory associates with each volume.
Workload tagging and AI features
Workloads are not tagged when an administrator disables AI features. If AI features are turned off in your Workload Factory account settings, the tagging service will not identify or classify workloads on your storage resources.
Explore savings snapshot calculation improvement
Explore savings now uses a consistent snapshot-capacity calculation, so FSx for ONTAP savings estimates correctly account for the additional snapshot capacity pool requirement.
Export replication delay data to CSV
You can now export replication delay data to a CSV file to analyze the data in a spreadsheet and share it with others.
S3 access point events
You can now send S3 access point events to the SNS topic on a set schedule. Each update includes all events that have occurred since the last update.
To set up notifications for S3 events, edit S3 access points and select Send S3 events by SNS under the Journal table section.
ONTAP features displayed in Volumes explorer
Volumes explorer now includes ONTAP features in the volumes table. These features provide more detailed insights into the configuration and status of your volumes, like protection coverage, Autonomous Ransomware Protection (ARP/AI) status, storage efficiency, tiering policy, and volume autogrow.
05 July 2026
Volumes explorer
Volumes explorer gives you a simple, searchable view of all your volumes in NetApp Workload Factory. Quickly see which volumes serve block or file workloads. View each volume's logical size, physical used capacity, and whether it uses storage efficiency features (compression, deduplication, and compaction). Filter and sort by name, status (available/failed), latency, size, used capacity, and protection features.
Enhanced email notifications for replication delays
Email notifications for replication delays now include more details about the affected relationship. The notification helps you quickly identify the affected relationship and look into it in the Workload Factory console.
Block device creation enhancement
Workload Factory supports block device creation from a volume snapshot.
Workload tagging for volumes and block devices
Workload Factory now identifies and tags volumes and block devices by their primary workload or application. You can assign predefined workload tags such as Microsoft SQL Server or Oracle Database, or create custom tags for your applications. Tags can be applied to individual resources or inherited by connected storage resources. This helps you align storage configurations with workload requirements, understand incident impact, and troubleshoot more effectively.
31 May 2026
Support for AWS GovCloud (US) in NetApp Workload Factory
NetApp Workload Factory supports AWS GovCloud (US) accounts. Using a GovCloud account, you can deploy and manage storage workloads in the AWS GovCloud (US) regions.
Set volume latency thresholds in NetApp Workload Factory
You can configure latency thresholds on a per-volume basis to monitor performance and receive alerts when latency values exceed your defined limits. Workload Factory monitors both read and write latency and generates alerts when either threshold is exceeded.
Track replication delays in NetApp Workload Factory
With NetApp Workload Factory, you can track replication delays for your FSx for ONTAP file systems that are configured with remote replication. Replication delays indicate the time delay between when data is written to the source file system and when it is replicated to the destination file system. Tracking replication delays helps you monitor the health of your replication setup and identify potential issues that could impact data consistency and recovery point objectives (RPOs).
Host identification and workload definitions in NetApp Workload Factory
Workload Factory identifies the hosts that consume storage and the types of workloads that are associated with host activity. Workload definitions are AI-generated based on AWS tags and metadata. You can view host details and workload definitions from the file system, volume, and block device resource screens in Workload Factory.
LIF details available in NetApp Workload Factory
We display all file system and storage VM endpoints directly in the Overview tab for a file system. Direct endpoint visibility within the Workload Factory console makes it easier to monitor network access, endpoints, and failover status without using the CLI or CloudShell. To display LIF details including roles, endpoints, nodes, IP addresses, and status, you'll need to associate a link with the file system.
Cost enhancements
New optional page-level filters are available to improve the results for cost analysis for your resources across all AWS accounts. You can select multiple regions and use file system allocation tag key and key values to filter the cost analysis results and get resource-specific cost details for your FSx for ONTAP file systems and volumes.
Replication initialization scheduling available in NetApp Workload Factory
During data replication setup, you can now schedule replication initialization for your FSx for ONTAP file systems. The options are to initialize the replication relationship immediately or at a specified time. Replication initialization is the process of creating a baseline for replication by copying data from the source file system to the destination file system. Scheduling replication initialization allows you to automate this process and ensure that your replication setup is up to date without manual intervention.
Excel report of the well-architected status of FSx for ONTAP file systems
After analysis, you can download an Excel report of the well-architected status of your FSx for ONTAP file systems for your records or to share with your teams.
View and analyze latency events
Workload Factory now supports viewing and analyzing latency events for FSx for ONTAP volumes. You can view latency events without a link connection, making it easier to monitor performance issues. To analyze latency events and receive AI-powered insights and recommendations, you must connect to the file system using a link. Analysis provides current latency values, thresholds, QoS response analysis, and remediation guidance.
You can now configure latency thresholds on a per-volume basis to monitor performance and receive alerts when read or write latency exceeds your defined limits. Latency monitoring helps you proactively identify performance issues before they impact your workloads.
03 May 2026
Block device clones
Workload Factory offers clones for your block devices so that you can provision writable and efficient copies of your data quickly while controlling capacity, access, and lifecycle.
EC2 tags on block devices
The block device table now includes a column that shows tags of the EC2 hosts which are consuming each block device. This helps you identify which host uses each block device during troubleshooting or audits.
To create tags on each block device, deploy an EC2 instance using our provided user script.
Learn about SSD capacity trends directly from the overview for your FSx for ONTAP file systems. The new card for capacity management shows usage trends from the previous month. This analysis compares actual and allocated capacity, making it easy to assess resource use.
PDF report of the well-architected status of FSx for ONTAP file systems
After analysis, you can download a PDF report of the well-architected status of your FSx for ONTAP file systems for your records or to share with your teams.
06 April 2026
Well-architected analysis updates
Workload Factory analyzes your FSx for ONTAP file systems for inactive NAS volumes. The configuration analysis identifies NAS volumes that are not actively used and recommends actions to optimize storage utilization and reduce costs.
Journal table feature for S3 access points
The Journal table feature provides a way to manage FSx ONTAP S3 object storage at scale, allowing you to easily audit user access events and operations on objects in your buckets. With Workload Factory, you can set up automatic scans of your buckets and S3 tables to keep a record of events, showing all objects, their details, and user actions.
Support for managing existing igroups
Workload Factory supports managing existing igroups. You can add or remove block devices and host initiators to deliver your deployed workload on time.
Support for specifying the aggregate for FlexVol volumes
Workload Factory supports creating FlexVol volumes on a chosen aggregate. This allows you to split the capacity and performance load across all the file system resources.
Last access time for block devices
Workload Factory reports the last access time for block devices. The time is based on when you last accessed the igroup in Workload Factory. Knowing when each block device was last used allows you to optimize your resources.
01 March 2026
Workload Factory analyzes your FSx for ONTAP file systems for the following configurations:
  • Underutilized SSD capacity: checks whether the SSD capacity tier is underutilized and recommends decreasing SSD capacity to optimize costs.
  • Schedule volume backups: Workload Factory improves the configuration recommendation and adds options to turn on FSx for ONTAP backup or AWS Backup. FSx for ONTAP backup applies a default policy to all volumes in a file system, creating daily backups kept for up to 90 days. AWS Backup lets you choose different retention periods for each volume in the backup plan.
Workload Factory supports AI & ML use case for replication
Workload Factory supports replicating on-premises ONTAP data to FSx for ONTAP and creating S3 access points for AWS Artificial Intelligence (AI) and machine learning (ML) services to accelerate AI/ML workflows.
Editing existing S3 access points
You can change the user and user type for an existing S3 access point attached to a volume. You can also enable or disable metadata for the access point.
Added block storage diagram
If you're using block storage, you can view the block storage diagram to visualize how block devices connect to nodes and igroups. The diagram helps you understand and manage your block storage.
Update to automatic capacity management feature
This update separates the feature into two distinct features: automatic capacity management and capacity notifications.
Automatic capacity management automatically adds or removes file system capacity to maintain optimal performance. New options include incremental and adaptive modes. In incremental mode, the system increases capacity by a fixed amount at thresholds; in adaptive mode, it uses historical data to predict and adjust capacity.
Capacity notifications alert you whenever a capacity adjustment occurs and when file systems reach set limits, so you can manage storage before issues arise.
New Ask Me bookmark available in Workload Factory
We added a new Ask Me bookmark on every screen in Workload Factory console. This improvement makes it easier and faster for you to access Ask Me whenever you need help. Ask Me is our AI assistant. You can ask questions about your workload environments, get personalized insights, and review previous conversations.
You can open Ask Me from any page by clicking the new bookmark. It launches Ask Me in a side panel without interrupting your current work and offers quick explanations and recommendations related to what you're currently doing.
16 February 2026
Support for storage VM migration
NetApp Workload Factory now supports migration for storage VMs. This feature allows migration of ONTAP storage system data and configurations from on-premises ONTAP systems or first-generation FSx for ONTAP file systems to second-generation FSx for ONTAP file systems. You can replicate storage VM data and configuration settings to move to the new file system with minimal downtime and disruption to users and applications.
To use this feature, create a replication relationship and select Migration as the use case. To complete the migration process, you must cut over the storage VM and its replicated volumes immediately to permanently migrate data and storage VM configuration settings to the target FSx for ONTAP file system.
01 February 2026
Home page includes well-architected issues and EMS events for Storage
The NetApp Workload Factory home page includes a Focus tile where well-architected issues and FSx for ONTAP Emergency Management System (EMS) events appear for your workloads. From there, you can navigate to the Storage workload to view the well-architected status or the events of all FSx for ONTAP file systems in your storage environment.
Support for on-premises data replication using an S3 access point
Workload Factory supports replicating on-premises ONTAP data to the cloud for integration with AWS GenAI, ML, and analytics. You can replicate your on-premises data to an NFS or SMB/CIFS volume using an S3 access point.
S3 access point enhancements in Storage
Several enhancements have been made to the S3 access point management capabilities in the Storage workload for NetApp Workload Factory. You can input network configuration details for your S3 access points and add S3 access point tags. Additional enhancements include the ability to view S3 bucket details and perform more actions for managing S3 access points.
S3 bucket details available in Storage
The new Inventory table automatically scans your AWS S3 buckets and populates S3 tables to give you a clear snapshot of all objects, their metadata, attributes, and tags. Access to these details helps you maintain control, visibility, and trust in the data you're responsible for, while reducing operational overhead. You can turn on the feature when creating and attaching S3 access points or when editing existing access points.
Additional management operations for S3 access points
NetApp Workload Factory provides additional management operations for S3 access points. You can view access point details, modify existing S3 access points, and add or remove S3 access point tags from the NetApp Workload Factory interface, streamlining your object storage management tasks.
  • Optimize cache volume size: checks whether volume autosize and scrubbing are enabled on cache volumes to maintain optimal size and focus the cache on hot data for peak efficiency.
  • Inactive block devices: recommends archiving block device data or deleting a block device if it hasn't been used for seven consecutive days.
  • Storage VM logical reporting: checks whether the default reporting setting for a storage VM is set to logical which provides better visibility into storage usage at the volume level.
Additional cards for block devices
Three new cards have been added to the Block devices tab in the Storage workload to provide quick insights into block device usage and protection status:
  • Storage efficiencies: displays used and available storage capacity; used capacity is broken down by SSD and capacity pool storage tiers.
  • Protected devices: displays the percentage of block devices with snapshots, remote replication, NetApp Autonomous Ransomware Protection (ARP/AI), and backups.
  • Inactive block devices: displays if any block devices haven't been used for seven consecutive days, helping you identify and manage unused resources effectively. From here, you can reclaim space for unused block devices.
Support for initiator group creation and management
NetApp Workload Factory supports creating and managing initiator groups (igroups) for block storage in FSx for ONTAP file systems. Initiator groups connect block devices (LUNs) to the compute resources that are allowed to access them, providing a permission layer for block storage in SAN environments.
04 January 2026
  • NetApp Autonomous Ransomware Protection (ARP/AI) disabled includes block devices: checks whether ARP/AI is disabled on block device volumes
  • Cache relationship write mode: checks whether the write mode is optimal for the cache volume workload
  • Unnecessary backup deletion: checks whether backups are outdated or unnecessary that can be deleted to reduce costs
Ask me AI assistant home page integration
The Workload Factory console home page embeds the Ask me AI assistant, enabling you to ask questions about your own storage estate, get personalized insights directly from your environment, and refer to previous conversations. You can interact with Ask me to understand your workloads, troubleshoot issues, and learn more about Workload Factory — all without leaving the console.
Lambda links that are used to connect between your Workload Factory account and one or more FSx for ONTAP file systems to perform advanced ONTAP operations, now use the IAM user principal for resource-based policy permissions. This change provides better alignment with industry best practices for AWS resource access.
Analysis screen added for the AI analyzer for EMS events
A new Analysis screen has been added to the Storage menu. From this screen, you can use the AI analyzer for FSx for ONTAP EMS events feature.
Block device enhancements in NetApp Workload Factory
The following enhancements have been made for block devices.
NetApp Workload Factory supports creating block devices using the iSCSI protocol on FSx for ONTAP file systems so that you can better support your line of business (LOB) applications from the Workload Factory console.
Block device management enhancements
NetApp Workload Factory includes the following enhancements for managing block devices. You can now perform the following tasks from the Workload Factory console:
  • Manage client access
  • Archive block device data
  • Delete a block device
Support for ARP/AI on FlexVol volumes containing block devices
You can enable NetApp Autonomous Ransomware Protection with AI (ARP/AI) on FlexVol volumes that contain block devices. Enabling ARP/AI detects ransomware attacks using AI and aids in data recovery.
04 December 2025
Support for AWS S3 access points for FSx for ONTAP
NetApp Workload Factory supports AWS S3 access points for your FSx for ONTAP file systems. You can create volumes using S3 access points, assign S3 access points to an existing volume, and manage S3 access points from the Workload Factory console. Using an S3 access point, you can access file data residing on SMB/CIFS or NFS volumes via the AWS S3 APIs. This allows you to integrate your existing data with GenAI, ML, and analytics from AWS services that support S3 access points.
27 November 2025
Block device support in NetApp Workload Factory
Manage your block devices more effectively with the newly introduced block device support in NetApp Workload Factory. This feature allows you to view details and increase capacity for iSCSI LUNs, providing enhanced flexibility for your storage needs.
Workload factory analyzes your FSx for ONTAP file systems for the following configurations:
  • Unnecessary snapshot deletion: checks whether volumes have outdated and unnecessary snapshots that can be deleted to reduce costs.
  • FlexGroup volumes rebalance: checks whether FlexGroup volumes are evenly balanced across their member volumes to ensure optimal performance.
AI analyzer for EMS events in NetApp Workload Factory
NetApp Workload Factory introduces an AI-powered analyzer for ONTAP Event Management System (EMS) events. This feature helps you quickly identify and troubleshoot issues by providing insights and recommendations based on the analysis of EMS event data.
You can monitor cost and usage trends for your FSx for ONTAP file systems directly from the NetApp Workload Factory console. This feature provides storage consumption and cost metrics as well as itemized costs, helping you optimize your resource allocation and budget planning.
Manage FSx tags for a file system in NetApp Workload Factory
Easily manage your FSx tags for a file system directly from the NetApp Workload Factory console. This feature allows you to add, edit, or remove tags, enabling better organization and categorization of your FSx for ONTAP file systems.
Adjust cache capacity for FSx for ONTAP file systems
You can increase and decrease capacity for cache volumes from the Workload Factory console.
02 November 2025
Cache volume management
You can perform the following cache volume management operations from within the Workload Factory console:
  • Edit the cache name
  • Increase the capacity of a cache volume
  • Edit the mount path or export policy for a cache volume
  • Change the caching method, or mode, for a cache volume
  • Prepopulate a cache volume
  • Delete a cache volume
Automatic inode management available
You can enable automatic inode management without the need to enable automatic capacity management.
Threshold warning setting for capacity and inode usage
Threshold warnings are available for both capacity and inode usage. You can set these thresholds to when enabling automatic capacity or inode management. To use this setting, you'll need to configure notifications using the NetApp Workload Factory notification service.
Volume size decrease available
You can decrease the size of NFS and SMB/CIFS volumes in NetApp Workload Factory. This feature allows for better management of storage resources by enabling you to reduce the size of volumes that are no longer needed at their current capacity.
Enhanced FSx for ONTAP resource state
Workload Factory has enhanced the "misconfigured" resource state to include an explanation of the actual issue for the resource.
  • Volume utilization nearing full: checks whether any volumes are using 80% or more of their file capacity. This helps you identify volumes that may need additional capacity.
  • Unauthorized access to volumes: checks whether an iSCSI volume is accessible using an NFS or SMB/CIFS mount path and allows you to remove unauthorized access to the volume to avoid security risks.
Permissions changes for Workload Factory for Storage
Workload Factory provides more clarity about the permissions it requires for specific actions and granularity for selecting only the permissions you need. When you add credentials, you'll have three permissions options to choose from instead of the previous permissions model which was read-only and read/write. The new permissions model breaks up the permission policies as follows:
  • View, planning, and analysis: View FSx for ONTAP file systems, learn about system health, get the well-architected analysis for your systems, and explore savings.
  • Operations and remediation: Perform operational tasks like adjust file system capacity and fix issues for your file system configurations.
  • File system creation and deletion: Create and delete FSx for ONTAP file systems and storage VMs.
When adding credentials, you can select one or more of these permission policies based on the level of access you want to provide to Workload Factory.
FSx for ONTAP cyber vault support
You can create a cyber vault using FSx for ONTAP as a source or target in the cyber vault architecture. Cyber vaults provide a secure and isolated environment for storing critical data, protecting it from ransomware and other cyber threats.
06 October 2025
BlueXP workload factory now NetApp Workload Factory
BlueXP has been renamed and redesigned to better reflect the role it has in managing your data infrastructure. As a result, BlueXP workload factory has been renamed to NetApp Workload Factory.
05 October 2025
Optimize savings in the Storage calculator for Amazon Elastic Block Store (EBS)
Workload Factory can analyze your EBS performance usage and then suggest the best and most cost-efficient FSx for ONTAP configuration so that you can save more by switching to FSx for ONTAP.
Quick access to resource screen from file system inventory
You can quickly navigate to an FSx for ONTAP file system resource screen by selecting the file system name, now a hyperlink, from the FSx for ONTAP inventory.
Discover cache relationships in the Workload Factory console
If you have cache relationships between FSx for ONTAP file system and another type of ONTAP storage (on-premises system, Cloud Volumes ONTAP, and FSx for ONTAP), you can discover and view them from the Workload Factory console. This allows you to better understand data flows, optimize cache utilization, and improve efficiency across distributed environments.
Workload factory now analyzes your FSx for ONTAP file systems for the following configuration:
Volume file capacity utilization threshold: checks whether the file capacity thresholds are set to 80% or lower. This helps you avoid running out of space on your file systems.
Improvements to actions for configuration issues
From the Well-architected analysis tab in the dashboard for an FSx for ONTAP file system, instead of dismissing an entire configuration for a file system, you can also select one or more volumes within a file system to fix, dismiss, or reactivate.
Additional notification for Storage
The NetApp Workload Factory notification service includes the notification for well-architected configuration issues on a weekly basis.
Immutable files support privileged delete
With this feature, you can configure privileged delete access for immutable files in your FSx for ONTAP file systems. This allows you to protect critical data from accidental or malicious deletion while still enabling authorized users to override the lock and delete these files as needed. Enabling privileged delete is available during volume creation or for existing volumes.
09 September 2025
Storage inventory report enhancements
Workload factory has enhanced the data reported for your FSx for ONTAP file systems. The downloadable report from the FSx for ONTAP inventory page includes the following new columns:
  • SSD used: shows the value of SSD capacity used
  • SSD utilization: shows the percentage of SSD capacity in use
  • Throughput utilization: shows average and peak utilization for the last 30 days
  • IO utilization: shows average and peak IO utilization for the last 30 days
  • CPU utilization: shows average and peak CPU utilization for the last 30 days
Snapshot management enhancements
Workload factory has made several enhancements to view volume snapshot details and manage volume snapshots. These enhancements make it easier for you to understand the status of your snapshots and protect your data.
Screenshot that shows FSx for ONTAP volume menu with basic actions and then view volume details.
Additional items appear in Volume details under the Protection tab:
  • Snapshot policy name
  • Snapshot space reservation
  • Snapshot space reservation capacity
Screenshot that shows FSx for ONTAP volume details with protection tab open.
The new snapshot management screen is accessible from a volume; it provides information about the snapshot policy for the volume and includes a table with all volume snapshots. The table displays the following snapshot details: creation time, size, expiry time, immutable snapshot protection, and labels. From the management screen, you can change the snapshot policy for the volume, create a snapshot manually, and edit, access, restore, and delete snapshots.
Screenshot that shows the manage snapshots screen.
SSD storage capacity decrease available
Workload factory supports decreasing the solid-state drive (SSD) capacity of your second-generation file systems. With elastic file system capacity, you can dynamically adjust the capacity of your file systems to match the needs of your workloads.
New notification for Storage
The workload factory notification service includes success and failure notifications for automatic capacity management for Storage.
03 August 2025
Enhancements to Replication relationships tab
We've added several new columns to the replication relationships table to give you more information about your replication relationships in the Replication relationships tab. The table now includes the following columns:
  • SnapMirror policy
  • Source file system
  • Target file system
  • State of the relationship
  • Last transfer time
Enhancements to NetApp Autonomous Ransomware Protection with AI (ARP/AI)
This release introduces the updated term "NetApp Autonomous Ransomware Protection with AI (ARP/AI)" to better reflect the integration of artificial intelligence in our ransomware protection capabilities.
In addition, the following enhancements have been made to ARP/AI:
  • Volume-level ARP/AI: You can now enable ARP/AI at the volume level, allowing you to protect specific volumes within your FSx for ONTAP file systems.
  • Automatic snapshot creation: You can set the ARP/AI policy to take automatic snapshots and define how often snapshots are taken for volumes with ARP/AI enabled, enhancing your data protection strategy.
  • Immutable snapshots: ARP/AI now supports immutable snapshots, which cannot be deleted or modified, providing an additional layer of security against ransomware attacks.
  • Detection: includes various detection methods such as high entropy data rate at volume level, file create rate, file rename rate, file delete rate, and behavioral analysis, and never seen before file extension that help to detect anomalies and potential ransomware attacks.
Workload factory now analyzes your FSx for ONTAP file systems for the following configurations:
  • Long-term retention data reliability: checks whether labels assigned to the snapshot policy of the source volume are identical to the labels assigned to the long-term retention policy. When labels are identical, data replication is reliable between source and target volumes.
  • NetApp Autonomous Ransomware Protection with AI (ARP/AI): checks whether ARP/AI is enabled on your file systems. This feature helps you detect and recover from ransomware attacks.
Dismiss a configuration from the well-architected analysis
You can now dismiss one or more configurations from the well-architected analysis. This allows you to ignore specific configurations that you don't want to address at the moment.
You can now use Terraform from the Codebox to create a link for association with an FSx for ONTAP file system. This functionality is for users who create links manually.
New region support for exploring savings in Storage
The following new regions are now supported for exploring savings for Amazon Elastic Block Store (EBS), FSx for Windows File Server, and Elastic File Systems (EFS):
  • Mexico
  • Thailand
Enhancements to SMB/CIFS shares creation and management
You can now create SMB/CIFS shares which point to directories within a volume. Within the volume, you'll be able to see which shares exist, where the shares are the pointing to, and the permissions granted to specific users and groups.
For data protection volumes, the flow of creating an SMB/CIFS share now includes the creation of a junction path to the volume for mounting purposes.
29 June 2025
BlueXP workload factory notification service support
The BlueXP workload factory notification service enables workload factory to send notifications to the BlueXP alerts service or to an Amazon SNS topic. Notifications sent to BlueXP alerts appear in the BlueXP alerts panel. When workload factory publishes notifications to an Amazon SNS topic, subscribers to the topic (such as people or other applications) receive the notifications at the endpoints configured for the topic (such as email or SMS messages).
Storage dashboard enhancements
The Storage dashboard in the Workload Factory console includes new cards for savings opportunities. The card at the top of the dashboard displays the number of savings opportunities for storage environments running on Amazon Elastic Block Store (EBS), Amazon FSx for Windows File Server, and Amazon Elastic File Systems (EFS). At the bottom of the dashboard, three new cards display savings opportunities by Amazon storage service - EBS, FSx for Windows File Server, and EFS. From all cards, you can explore the savings opportunities in more detail.
From the FSx for ONTAP protection coverage card and replication relationship health card, you can investigate if there are any partially protected volumes in your FSx for ONTAP file systems as well as investigate issues with replication relationships. In both cases, you can take action to resolve the issues.
Volume tab enhancements
The Volumes tab in the Workload Factory console has been enhanced to provide a more comprehensive view of your FSx for ONTAP file systems. The enhancements include new cards for SSD capacity, Capacity pool, and NetApp Autonomous Ransomware Protection with AI (ARP/AI). These cards summarize capacity utilization and ARP/AI protection for all volumes in the file system.
Support for second-generation Amazon FSx for NetApp ONTAP file systems
Workload factory now supports second-generation Amazon FSx for NetApp ONTAP file systems. You can create, manage, and monitor second-generation file systems in the Workload Factory console. All new commercial regions are supported.
FlexVol volume support for rebalancing volume capacity
FlexVol volumes are discoverable within the Workload Factory console. You can check the balance of your FlexVol volumes and rebalance FlexVol volumes to redistribute the capacity when imbalances develop over time due to the addition of new files and file growth.
Terminology update
The term "Autonomous Ransomware Protection" (ARP) has been updated to "NetApp Autonomous Ransomware Protection with AI" (ARP/AI) in the Workload Factory console.
ARP/AI enabled by default for new volumes
When you create a new volume in the Workload Factory console, NetApp Autonomous Ransomware Protection with AI (ARP/AI) is enabled by default if the file system has an ARP/AI policy. This means that the volume is automatically protected against ransomware attacks using AI-driven detection and response capabilities.
Replication support for immutable files
Workload factory supports replicating immutable volumes from one FSx for ONTAP system to another FSx for ONTAP file system to protect critical data from accidental deletion or malicious attacks like ransomware. The target volume and its host file system will be immutable, or locked, and any data in the target file system can't be modified or removed until the retention period ends.
Now you can manage the IAM execution role and its attached permission policy when you create a link in the Workload Factory console. A link establishes connectivity between your Workload Factory account and one or more FSx for ONTAP file systems. You have two options for assigning the IAM execution role and link permissions - automatically or user-provided. Managing the execution role and its attached permissions policy in Workload Factory means that you don't need to use third party code any longer.
08 June 2025
New well-architected analysis and support for fixing issues
Automatic capacity management for FSx for ONTAP file systems is now included as a configuration analysis in the well-architected status dashboard.
Additionally, Workload Factory now supports fixing the following configuration issues:
  • SSD capacity threshold
  • Data tiering
  • Scheduled local snapshots
  • FSx for ONTAP backups
  • Remote data replication
  • Automatic capacity management
03 June 2025
Volume autogrow enhancement
Now you can set the autogrow size of your volumes so that volume size can grow beyond the provisioned size for business needs and application requirements.
Workload factory now analyzes your FSx for ONTAP file systems to check whether storage efficiencies including data compaction, compression, and deduplication are being utilized. Storage efficiencies measure how effectively the file systems use available space.
Starting today, when you open the Storage workload from the Workload Factory console, you'll view the Dashboard. The newly designed dashboard provides a holistic view of your FSx for ONTAP systems including the number of file systems, the total SSD capacity, the well-architected status overview, the data protection overview, and replication relationship health.
Volumes tab enhancements
The Storage workload made enhancements to the Volumes tab within an FSx for ONTAP file system in the Workload Factory console. The enhancements include:
  • New cards: SSD capacity, Capacity pool, and Autonomous Ransomware Protection (ARP)
  • New columns: Capacity distribution, Used SSD capacity, Used capacity pool, and SSD efficiency
Storage efficiencies update for volume creation
When creating a new volume, storage efficiencies including data compaction, compression, and deduplication are enabled by default.
04 May 2025
Autonomous Ransomware Protection for FSx for ONTAP file systems
Protect your data with Autonomous Ransomware Protection (ARP), a feature that uses workload analysis in NAS (NFS/SMB) environments to detect and warn about abnormal activity that might be a ransomware attack. When an attack is suspected, ARP also creates new, immutable snapshots from which you can restore your data.
FlexGroup volume rebalance enhancement
BlueXP workload factory introduces the FlexGroup volume rebalance wizard with several layout options for rebalancing the data in a FlexGroup volume. Rebalancing redistributes data evenly to FlexGroup member volumes.
Implement best practices for an FSx for ONTAP file system
BlueXP workload factory provides a dashboard where you can review the well-architected status of your file system configurations. You can leverage this analysis to implement best practices for your FSx for ONTAP file systems. File system configuration analysis includes the following configurations: SSD capacity threshold, scheduled local snapshots, scheduled FSx for ONTAP backups, data tiering, and remote data replication.
Dual-protocol volume security style options
You have the option to choose either NTFS or UNIX as the security style for a volume to determine the method that users and permissions access a volume.
Replication enhancements
Reverse replication supported from FSx for ONTAP to on-premises
Reverse replication is now available from an FSx for ONTAP file system to an on-premises ONTAP cluster from within the Workload Factory console.
Data protection volume replication
You can now replicate data protection volumes.
Multiple volume selection
Multiple volume selection is available so you can select exactly the volumes you want to replicate.
Long-term retention policy labels
When you enable long-term retention for a replication relationship, source and target volumes labels must match exactly. Now BlueXP workload factory can automatically create missing source volume labels for you.
FSx for ONTAP file name visible in volume creation
We've improved the visibility of FSx for ONTAP file systems during volume creation. You'll see the FSx for ONTAP file system when you create a volume, so you'll know exactly where the volume is being created.
AWS account visible across the Storage workload
We've improved account visibility across the Storage workload. You'll see the AWS account when navigating to the Volumes, Storage VMs, and Replication tabs.
  • You can quickly associate a link from an FSx for ONTAP file system in the Inventory tab.
  • BlueXP workload factory now supports the use of alternative ONTAP user credentials for link association.
You now have the option to use secrets from AWS Secrets Manager to authenticate links so that you don't have to use credentials stored in BlueXP workload factory.
Tracker response support
Tracker now provides API responses so that you can see the REST API output related to the task.
Capacity validation when restoring a volume from a backup
When restoring a volume from a backup, BlueXP workload factory determines if you have enough capacity for the restore and can automatically add SSD storage tier capacity if you don't.
Support for alternative ONTAP user credentials
Workload factory now supports alternative sets of ONTAP credentials for creating file systems to minimize security risks. Instead of using only the fsxadmin user, you can select a different set of ONTAP credentials or choose not to provide a password for fsxadmin and vsaadmin users.
Updated permissions terminology
The Workload Factory user interface and documentation now use "read-only" to refer to read permissions and "read/write" to refer to automate permissions.
30 March 2025
Automatic capacity management for scale-out systems
Workload factory now scans for available inodes in volumes and increases their count according to the configured automatic capacity management thresholds. This feature supports automatic capacity management for scale-out systems. You can enable inodes management as part of automatic capacity management.
FlexGroup rebalance API
BlueXP workload factory releases the FlexGroup rebalance API that allows you to execute a plan to rebalance the data in a FlexGroup. Rebalancing redistributes data evenly to the member volumes.
Replicate data form includes use cases
The replicate data form now includes use cases to make it easier for you to complete the form. You'll select one of the following use cases for data replication: migration, hot disaster recovery, cold disaster recovery, archive, or other. After you select a use case, Workload factory recommends values in accordance with best practices. You can accept the preselected values or customize the values in the form.
Data tiering policy terminology changes
Now when you select a tiering policy during volume creation, data replication, or updates to existing tiering policies, you'll find new terms to describe the tiering policies.
  • Balanced (Auto)
  • Cost-optimized (All)
  • Performance optimized (Snapshots only)
Security group details for file system creation
A security group is created as part of the FSx for ONTAP file system creation process. Security group details including protocols, ports, and roles are now available.
02 March 2025
Automatic capacity management improvements
When automatic capacity management is enabled, BlueXP workload factory now checks if a file system reached its capacity threshold every 30 minutes instead of every 2 hours.
The provisioned IOPS setting is no longer affected when capacity threshold is reached.
Immutable snapshots
Now you can lock snapshots, making them immutable, for a specific retention period. Locking prevents the unauthorized access and malicious deletions of snapshots. You can enable immutable snapshots during snapshot policy creation, when creating manual snapshots, and after snapshot creation.
Immutable files update
You can now make the following changes to your immutable files configuration: retention policy, retention period, autocommit period, and volume append mode.
Data replication enhancements
  • Cross-account replication: Replication between two AWS accounts is supported in the BlueXP workload factory console as well as replication management.
  • Pause and resume replication: You can pause (quiesce) scheduled replication updates from the source volume to the destination volume and then resume the replication schedule when you're ready. During the pause, source and destination volumes become independent, and the destination volume transitions from read-only to read/write.
CloudShell events in Tracker
Now you can track CloudShell events in Tracker.
02 February 2025
CloudShell in BlueXP workload factory console
CloudShell is an embedded CLI capability available within BlueXP workload factory for Storage. You can use CloudShell to create, share, and execute ONTAP or AWS CLI commands from multiple sessions in a shell-like environment from within the Workload Factory console.
Inventory data download
You can now download FSx for ONTAP inventory data into an Microsoft Excel or CSV file from Storage in BlueXP workload factory.
A screenshot of Storage in BlueXP workload factory showing the new download button to download FSx for ONTAP file system inventory data.
FSx for ONTAP file system additional menu options
We've made it simpler to do the following for an FSx for ONTAP file system from the FSx for ONTAP tab in Storage.
  • Create a storage VM
  • Create a volume
  • Replicate volume data
A screenshot of the FSx for ONTAP tab in Storage showing the new menu options create storage VM
Terraform support for creating volumes
You can now use Terraform from the Codebox to create volumes.
File locking with the immutable files feature
You can now lock files using the immutable files feature when you create a volume for an FSx for ONTAP file system. File locking helps you and others prevent accidental or intentional file deletion for a specified period.
Tracker available for monitoring and tracking operations
Tracker, a new monitoring capability is available in Storage. You can use Tracker to monitor and track the progress and status of credentials, storage, and link operations, review details for operation tasks and subtasks, diagnose any issues or failures, edit parameters for failed operations, and retry failed operations.
You can now use Amazon FSx for NetApp ONTAP second-generation file systems in NetApp Workload Factory. FSx for ONTAP second-generation Single-AZ file systems are powered by up to 12 HA pairs which can deliver up to 72 GBps of throughput capacity and 2,400,000 SSD IOPS. FSx for ONTAP second-generation Multi-AZ file systems are powered by one HA pair and deliver 6 GBps of throughput capacity and 200,000 SSD IOPS.
05 January 2025
Volume CIFS share enhancements
The following enhancements are available for managing CIFS share for volumes in an Amazon FSx for ONTAP file system in BlueXP workload factory:
  • Support for multiple CIFS shares on a volume
  • The option to update users and groups at any time
  • The option to update permissions for users and groups at any time
  • CIFS share deletion
1 December 2024
Block storage for scale-out FSx for ONTAP file systems
You can now provision block storage over FSx for ONTAP when using a scale-out file system deployment with up to 6 HA pairs.
Mount command available
Mount commands are now available for NFS and CIFS access to a volume. You can get the mount point for a volume within an FSx for ONTAP file system by selecting Basic actions then View mount command.
Screenshot that shows to view the mount command by going into an fsx for ontap file system, selecting the volume menu, selecting basic actions, and then selecting view mount command. The mount command dialog appears and displays the mount command for CIFS or NFS access.
Update storage efficiency after volume creation
You can now enable or disable storage efficiency for FlexVol volumes after volume creation. Storage efficiency includes deduplication, data compression, and data compaction. Enabling storage efficiency helps you achieve optimal space savings on a FlexVol volume.
On-premises ONTAP cluster discovery and replication
Discover and replicate on-premises ONTAP cluster data to an FSx for ONTAP file system so that it can be used to enrich AI knowledge bases. All on-premises discovery and replication workflows are possible from the new On-Premises ONTAP tab in the Storage inventory.
AWS credentials improve savings calculator analysis
You now have the option to add AWS credentials from the savings calculator. Adding credentials improves the accuracy of the savings calculator analysis of your Amazon Elastic Block Store, Elastic File Systems, and FSx for Windows File Server storage environments when compared with FSx for ONTAP.
3 November 2024
Tab views in storage inventory
Storage inventory has been updated to a two-tab view:
  • FSx for ONTAP tab: displays the FSx for ONTAP file systems you currently have.
  • Explore savings tab: displays Elastic Block Store, FSx for Windows File Server, and Elastic File Systems storage systems. From there, you can explore savings for these systems by comparing them with FSx for ONTAP.
29 September 2024
  • Codebox viewer: Codebox is now integrated in the link creation process. You can view and copy the CloudFormation template from Codebox in Workload Factory before redirecting to AWS to execute the operation.
  • Required permissions: The permissions required to execute the link creation in AWS CloudFormation are now available to view and copy from the Create Link wizard in Workload Factory.
  • Support for manual link creation: This feature allows standalone creation in AWS CloudFormation with manual registration of the link ARN. It's useful when a Security or DevOps team assists in the link creation process.
1 September 2024
Read mode support for storage management
Read mode is available for storage management in Workload Factory. Read mode enhances the experience of basic mode by adding read-only permissions so that the Infrastructure-as-Code templates are filled with your specific variables. The Infrastructure-as-Code templates can be executed directly from your AWS account without providing any modify permissions to Workload Factory.
Backup before volume deletion support
You can now back up a volume before deleting it. The backup will remain in the file system until deleted.
4 August 2024
Terraform support
You can now use Terraform from the Codebox to deploy file systems and storage VMs.
Throughput and IOPS recommendations in the storage calculator
The storage calculator makes FSx for ONTAP file system configuration recommendations for throughput and IOPS based on AWS best practices, which provides you with optimal guidance for your selections.
7 July 2024
Initial release of Workload Factory for Amazon FSx for NetApp ONTAP
Amazon FSx for NetApp ONTAP is now generally available in BlueXP workload factory.
