Create a storage VM for an FSx for ONTAP file system
Create a storage VM (SVM) for an FSx for ONTAP file system to access storage and data services virtually for your workloads in NetApp Workload Factory.
Storage VMs are isolated file servers that you can use to access the data from each workload in Workload Factory Storage. Each SVM has its own administrative credentials and endpoints for administering and accessing data.
Clients and workstations access data in FSx for ONTAP by mounting a volume, CIFS/SMB share, or iSCSI LUN hosted by an SVM through the SVM endpoint (IP address).
Verify the supported number of storage VMs per file system. Refer to Managing FSx for ONTAP storage virtual machines in AWS documentation for the maximum number of SVMs per file system.
Create a storage VM
You can create a storage VM from the Workload Factory console. You can also use the following tools available in the Codebox: REST API, CloudFormation, and Terraform. Learn how to use Codebox for automation.
When using Terraform from Codebox, the code you copy or download hides fsxadmin and vsadmin passwords. You'll need to re-enter the passwords when you run the code.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system and then select Manage.
In the file system overview under Storage VMs, select Create storage VM.
On the Create storage VM page, under Storage VM configuration, provide the following:
Name: Enter a name for the storage VM.
Storage VM credentials: Provide a password for this storage VM's
vsadminuser or use the file system'sfsxadminuser credentials. -
Root volume security style: Select the root volume security style depending on the type of clients that access your data - UNIX (Linux clients), NTFS (Windows clients), or Mixed.
Tags: Optionally, you can add up to 50 tags.
Select Create.
