Create an on-demand backup of a volume in NetApp Workload Factory
Create a manual backup of a volume outside regularly scheduled backups in NetApp Workload Factory.
Volume backups are per volume, so each backup contains only the data in a particular volume.
Volume backups are incremental which means that only the data on the volume that has changed after your most recent backup is saved. This minimizes the time required to create the backup and the storage required for the backup, which saves on storage costs by not duplicating data.
To take backups of your volumes, both your volume and your file system must have enough available SSD storage capacity to store the backup snapshot. When taking a backup snapshot, the additional storage capacity consumed by the snapshot cannot cause the volume to exceed 98% SSD storage utilization. If this happens, the backup will fail.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select Volumes explorer.
Select the actions menu for the volume to back up.
Select Data protection actions, Volume backups, and then Manual backup.
In the Manual backup dialog, enter a name for the backup.
Select Back up.
