Delete a replication relationship in NetApp Workload Factory
Delete a replication relationship in NetApp Workload Factory. When you delete a replication relationship, it removes the replication relationship between the source and target volume. After the replication relationship deletes, both volumes continue to exist independently with the current data they contain.
When you delete a replication relationship, FSx for ONTAP also deletes the common replication snapshots of the source and target volume.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
From the file system overview, select the Replication relationships tab.
In the Replication relationships tab, select the actions menu of the replication relationship to delete.
Select Delete.
In the Delete relationship dialog, select Delete.
