Amazon FSx for NetApp ONTAP
Replicate a storage VM to another FSx for ONTAP file system
Contributors netapp-rlithman
Replicating a storage VM to another FSx for ONTAP file system in NetApp Workload Factory provides a protective layer of data access in case of data loss. This operation replicates all volumes in one storage VM to another FSx for ONTAP file system.
Before you begin
To replicate a storage VM to another FSx for ONTAP file system, you must associate a link. Learn how to associate an existing link or to create and associate a new link. After you associate the link, return to this operation.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system with the storage VM to replicate and then select Manage.
  5. In the file system overview under Storage VMs, select Manage.
  6. On the Manage storage VMs screen, select the actions menu of the storage VM to replicate, and then select Advanced actions > Replicate storage VM.
  7. On the Replicate data page, under Replication target, provide the following:
    1. FSx for ONTAP file system: Select credentials, region, and FSx for ONTAP file system name for the target FSx for ONTAP file system.
    2. Storage VM name: Select the storage VM from the dropdown menu.
    3. Volume name: The target volume name is generated automatically in the format {OriginalVolumeName}_copy.
    4. Tiering policy: Select the tiering policy for the data stored in the target volume.
      Auto is the default tiering policy when you create a volume in the Workload Factory console. For more information about volume tiering policies, see Volume storage capacity in the Amazon FSx for NetApp ONTAP documentation.
    5. Max transfer rate: Select Limited and enter the maximum transfer limit in MB/s. Alternatively, select Unlimited.
      Without a limit, network and application performance might decline. However, we recommend an unlimited transfer rate for FSx for ONTAP file systems for critical workloads, for example, those that are used primarily for disaster recovery.
  8. Under Replication settings, provide the following:
    1. Replication interval: Select how often snapshots are transferred from the source volume to the target volume.
    2. Long-term retention: Optionally, enable snapshots for long-term retention.
      If you enable long-term retention, select an existing policy or create a new policy to define the snapshots to replicate and the number to retain.
      1. For Choose an existing policy, select an existing policy from the dropdown menu.
      2. For Create a new policy, provide the following:
        1. Policy name: Enter a policy name.
        2. Snapshot policies: In the table, select the snapshot policy frequency and the number of copies to retain. You can select more than one snapshot policy.
  9. Select Create.
Result
All volumes within the storage VM are replicated to the target file system.
