Stop a replication relationship in NetApp Workload Factory
Stop a replication relationship in NetApp Workload Factory. When you stop a replication relationship, scheduled replication updates from the source volume to the target volume pause. The target volume transitions from read-only to read/write.
Log in using one of the console experiences.
Select the menu
and then select Storage. -
From the Storage menu, select FSx for ONTAP.
From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
From the file system overview, select the Replication relationships tab.
In the Replication relationships tab, select the actions menu of the replication relationship to stop.
Select Break.
In the Break replication dialog, select Break.
The replication status of the volume changes to Broken. The target volume becomes writable.
