Amazon FSx for NetApp ONTAP
Delete a volume in NetApp Workload Factory
Contributors netapp-rlithman netapp-sineadd
Delete a volume you no longer need from an FSx for ONTAP file system to free up space. This operation is irreversible.
Before you begin
Consider the following before deleting a volume:
  • Replication relationships: You must delete all existing replication relationships for this volume before deleting the volume so that no broken relationships remain.
  • Local snapshots: All snapshots associated with this FSx for ONTAP file system will be permanently deleted.
  • Volume backups: Volume backup copies will remain and you can still use them.
  • Immutable files and snapshots: Volumes containing immutable files and snapshots cannot be deleted until the retention period ends.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select Volumes explorer.
  4. Select the actions menu of the volume to delete.
  5. Select Basic actions then Delete volume.
  6. In the Delete volume dialog, do the following:
    1. Optionally, select Back up the volume to back up the volume before deletion.
      The backup will remain in the file system until you manually delete it.
    2. Select Continue.
    3. Type “delete” to delete the volume.
    4. Select Delete to confirm.
