Amazon FSx for NetApp ONTAP
Update snapshot data in a replication relationship
Contributors netapp-rlithman
A replication relationship has a set replication schedule, but you can manually update snapshot data transferred between source and target volumes in NetApp Workload Factory at any time.
Steps
  1. Log in using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select Storage.
  3. From the Storage menu, select FSx for ONTAP.
  4. From FSx for ONTAP, select the actions menu of the file system to update and then select Manage.
  5. From the file system overview, select the Replication relationships tab.
  6. In the Replication relationships tab, select the actions menu of the replication relationship to update.
  7. Select Update now.
  8. In the Update dialog, select Update now.
