Credential types for NetApp Workload Factory
NetAppWorkload Factory uses a split-credential model to separate AWS control-plane permissions from direct ONTAP administrative access. The AWS IAM role authenticates Workload Factory to AWS APIs for operations such as file system management, backup management, and resource discovery. ONTAP credentials authenticate direct access to the ONTAP management endpoint with a Lambda link for operations that require administrative configuration or diagnostics. Some workflows require both credential types when they combine AWS API operations with direct ONTAP management tasks.
Credential types
The following table summarizes the two credential types used in Workload Factory and their respective authentication targets.
| Credential type | Authenticates to | Used for |
AWS credentials (AssumeRole) |
AWS APIs |
All operations that go through the AWS FSx service API |
ONTAP credentials (admin password) |
ONTAP management endpoint |
Operations that require direct ONTAP REST API or CLI access |
AWS credential-only operations
These operations interact solely with AWS APIs and require only the IAM role:
File system creation and deletion
File system capacity and throughput changes
Backup creation and management
VPC, subnet, and security group discovery
KMS key enumeration
CloudWatch metrics retrieval
Cost Explorer queries
Tag management using the FSx API
ONTAP credentials-only operations
These operations communicate directly with the ONTAP management endpoint through the Lambda link and require ONTAP admin credentials:
Volume-level QoS policy configuration
Export policy and rule management
storage VM protocol configuration (NFS, CIFS, iSCSI)
igroup and LUN management
SnapMirror (replication) configuration
Snapshot policy management (ONTAP-level)
Performance diagnostics (QoS statistics, latency breakdown)
EMS event retrieval and analysis
Anti-ransomware protection status monitoring
FlexCache management
Network interface (LIF) queries
Operations requiring both AWS and ONTAP credentials
| Workflow | AWS credential used for | ONTAP credential used for |
AI-powered event analysis |
Invoke Bedrock, describe file system |
Retrieve EMS events, run diagnostics using SSH |
File system creation with storage VM setup |
Create file system (AWS API) |
Configure storage VM protocols (ONTAP REST) |
Volume creation with export policy |
Create volume (AWS API) |
Set export policy rules (ONTAP REST) |
Storage capacity management |
Update file system capacity (AWS API) |
Check aggregate utilization (ONTAP SSH) |
