ONTAP execution options for NetApp Workload Factory
Some NetApp Workload Factory workflows require ONTAP-native operations that aren't exposed through AWS APIs. Workload Factory offers two execution options that keep these operations inside your AWS account boundary: a Lambda link that runs ONTAP operations from within your VPC, and a NetApp Console Agent that uses outbound-only connectivity from an EC2 instance. Both options let you perform required ONTAP operations while keeping network, credential, and lifecycle decisions within your security model.
Execution options
- Lambda link (AWS Lambda in your VPC)
Executes ONTAP REST and read-only ONTAP CLI diagnostics from within your VPC, without exposing ONTAP publicly.
- NetApp Console Agent (EC2 in your VPC, outbound-only)
Executes proxied ONTAP operations where the agent initiates outbound connections and Workload Factory never initiates inbound connections to the agent.
Security considerations
Network boundaries: confirm required outbound ports (443/22) and destinations.
Credential boundaries: decide whether ONTAP credentials are stored in Workload Factory (envelope encrypted) or referenced from AWS Secrets Manager.
Auditability: confirm operational records for component activity and failures.
Lifecycle management: confirm how updates and removal occur.
