Explore the VMware planning center
Contributors netapp-sineadd netapp-mwallis
The VMware planning center enables you to upload new VM inventory data and create new migration plans, as well as manage the VM inventory data and migration plans that you have already saved with NetApp Workload Factory.
Manage VM inventory data
Use the planning center to create and manage VM inventory data.
Upload VM inventory data
You can upload VM inventory data when you are ready to use Workload Factory to explore migration options to Amazon AWS environments. Refer to Upload VM inventory data for instructions.
Rename a dataset
You can change the name of a saved dataset.
Steps
  1. Log in to Workload Factory using one of the console experiences.
  2. Select the menu The hamburger menu icon is used to navigate to workloads like storage and then select VMware.
    The planning center is displayed.
  3. Select the Actions menu (…​) for the dataset you want to rename, and select Rename.
  4. Enter a new name for the dataset and select Save.
Delete a dataset
When a dataset is no longer needed, you can delete it at any time.
Steps
  3. Select the Actions menu (…​) for the dataset you want to delete, and select Delete.
  4. Select Delete to confirm the action.
Manage migration plans
Use the migration center to create and manage migration plans.
Provision a migration plan
You can select a migration plan and provision it so that the VMs are migrated to the Amazon AWS environment of your choice.
Steps
  3. Select Migration plans.
  4. Select the Actions menu (…​) for the migration plan you want to provision, and select Provision.
  5. Depending on the migration plan, refer to the instructions to deploy the file system:
Edit the comment for a migration plan
If you need to change comment details for a migration plan, edit the comment from within the planning center.
Steps
  4. Select the Actions menu (…​) for the migration plan you want to edit, and select Edit comment.
  5. Enter a comment and select Save.
Create a PDF or CSV report of a migration plan
Create a PDF or CSV report of the details of a migration plan.
Steps
  4. Select the Actions menu (…​) for the migration plan for which to create a PDF or CSV report, and select Download plan (PDF) or Download VM report (CSV).
  5. Enter a name for the report and select Save.
Delete a migration plan
When a migration plan is no longer needed, you can delete it at any time.
Steps
  4. Select the Actions menu (…​) for the migration plan you want to delete, and select Delete.
  5. Confirm the action by selecting Delete.
