Deploy FSx for ONTAP for Amazon EC2
Contributors netapp-mwallis netapp-sineadd
After you verify that the recommended FSx for ONTAP file system (or multiple file systems in some cases) meets your exact requirements, you can use Workload Factory to deploy the system in your AWS environment.
Follow the instructions in Create an FSx for ONTAP file system in NetApp Workload Factory to deploy the FSx for ONTAP file system according to the configuration recommended by Workload Factory. You can use the Advanced create steps in the instructions to fully customize the file system.
