Capture VM configurations for Amazon EC2
You can use the Migration advisor VM data collector script, RVTools, or NetApp Data Infrastructure Insights to capture your current VM configurations. We recommend that you use the Migration advisor VM collector script or Data Infrastructure Insights because these options gather both VM configuration and performance data for the most accurate plan.
RVTools is a Windows application that interacts with VCenter and ESX server (5.x to 8.0) to capture information about your VMware virtual environments. It gathers information about VMs, CPU, memory, disks, clusters, ESX hosts, datastores, and more. You can export this information to an xlsx file to use with the migration advisor.
Download and install RVTools 4.4.2 or greater from RVTools website
Launch RVTools and log in to the target VCenter Server.
This will capture information about that VCenter Server.
Export your VMware information to an xlsx or xls file.
See the chapter on "commandline parameters" in the RVTools documentation for details.
The xlsx or xls file that contains your results is saved to your working directory.
The NetApp Migration advisor VM collector script gathers VM configuration information from your vCenter similar to what RVTools collects, however, it captures current VM performance data to provide actual read and write IOPS and throughput statistics. You can use the script in one of two modes:
Hourly data collection
Daily data collection
You need to start the Migration advisor to copy the Migration advisor VM collector script from the Codebox window.
The system where you'll be running the collector script must meet the following requirements:
Microsoft PowerShell 7.0 or greater must be installed. See the Microsoft PowerShell documentation if you need to install PowerShell.
VMware PowerCLI must be installed. See the VMware PowerCLI documentation if you need to install PowerCLI.
SSL certificate checking must be disabled.
PowerShell must allow running unsigned scripts.
Note that if you plan to capture long-term statistics from your VMs (daily statistics), you must have activated statistics level 3 or above in the vSphere management console (VMware management environment).
Log in to Workload Factory using one of the console experiences.
Select the menu
and then select VMware.The planning center is displayed. From the planning center, you can upload your VM inventory data, see previous inventory data uploads, and plan a migration using any of the VM inventory datasets. and then select Migration to AWS native compute. The VMware migration advisor splash screen is displayed.
Review the information to learn about the benefits of the migration advisor.
When ready, select Let's start.
Select the Detailed planning tile, and select Next.
The Codebox window appears on the right side of the page.
In the Codebox window, select either
to save the Migration advisor data collector script (named "list-vms.ps1") to the target system, or select
to copy the script so you can paste it on the appropriate system. -
Follow these steps to capture the configurations of your current VMs:
Log in to the system where you downloaded the data collector, on which PowerShell and PowerCLI are installed.
Connect to your VMware vCenter server by running the following command:
Connect-VIServer -server <server_IP>Replace <server_IP> with the IP address or hostname of your VMware server.
Run the data collector script you downloaded and specify the data collection option for "hourly" or "daily" VM statistics.
./list-vms.ps1 -PerformanceStatisticsTimePeriod <LastHour | LastDay>where:
LastHour collects IOPS and throughput data for the past 1 hour with 20-second intervals.
LastDay collects IOPS and throughput data for the past 24 hours with 5-minute intervals.
Optionally, you can run the data collector script without specifying any options; this enables you to select the data collection period from the interactive menu.
The script outputs a compressed file with a timestamp in the name in the current working directory. The .zip file contains a list of all VMs and their properties, along with their IOPS and throughput data.
NetApp Data Infrastructure Insights is a cloud infrastructure monitoring tool that gives you visibility into your complete infrastructure. You need to enable enable temporary API communication between the migration advisor and Data Infrastructure Insights so that the migration advisor can gather information about your VMware infrastructure.
Log in to your Data Infrastructure Insights account.
In the side navigation menu, select Admin.
In the resulting menu, select API Access.
In the API Access Tokens tab, select + API Access Token.
The Create an API Access Token dialog appears.
Provide a name and description for the API token.
Under What type of APIs will this token be used to call select one of the following:
Acquisition Unit
Assets
Data Collection
Under Permissions select Read Only.
Under Token expires in, choose the length of time that you need the API token to be valid.
Uncheck Automatically rotate tokens for Kubernetes.
Select Save.
Select Copy API Access Token.
Save this token in preparation to use with the Workload Factory migration advisor.
