Quick start for Amazon EC2 migration
Contributors netapp-mwallis netapp-sineadd
Get started with the VMware migration advisor to move your current infrastructure to Amazon EC2 using Amazon FSx for ONTAP as external NFS datastores.
Before you get started, you should have an understanding of the permissions for NetApp Workload Factory.
One Log in to Workload Factory
You'll need to set up an account with Workload Factory and log in using one of the console experiences.
Two Add credentials and permissions
Choose the permission policies to meet your needs.
If you choose not to grant permissions, you can start using Workload Factory for Databases to copy partially completed code samples.
If you choose to grant permissions, you'll need to add credentials to an account manually that includes selecting workload capabilities, such as Databases and AI, and creating the IAM policies for the required permissions.
Three Upload VM inventory data
You can use the planning center to upload inventory details about your current VM environment. Use the data collector script, RVTools, or NetApp Data Infrastructure Insights to capture your current VM configuration and upload the data to the planning center.
Four Create a deployment plan using the VMware migration advisor
Launch the VMware migration advisor and select the VMs that you want to migrate to Amazon EC2 infrastructure using an Amazon FSx for ONTAP file system as external NFS datastores. You can make some modifications before you save the plan.
Five Deploy the recommended FSx for ONTAP file system
Deploy the new FSx for ONTAP file system that will provide the datastores for your VMs in your Amazon EC2 infrastructure.
