Quick start for VMware Cloud on AWS migration
Get started with the VMware migration advisor to move your current infrastructure to VMware Cloud on AWS using Amazon FSx for ONTAP as external NFS datastores.
Before you get started, you should have an understanding of the permissions for NetApp Workload Factory.
Log in to Workload FactoryYou'll need to set up an account with Workload Factory and log in using one of the console experiences.
Add credentials and permissionsChoose the permission policies to meet your needs.
If you choose not to grant permissions, you can start using Workload Factory for Databases to copy partially completed code samples.
If you choose to grant permissions, you'll need to add credentials to an account manually that includes selecting workload capabilities, such as Databases and AI, and creating the IAM policies for the required permissions.
Upload VM inventory dataYou can use the planning center to upload inventory details about your current VM environment. Use the data collector script, RVTools, or NetApp Data Infrastructure Insights to capture your current VM configuration and upload the data to the planning center.
Create a deployment plan using the VMware migration advisorLaunch the VMware migration advisor and select the VMs that you want to migrate to the new VMware Cloud on AWS infrastructure using an Amazon FSx for ONTAP file system as external NFS datastores. You can make some modifications before you save the plan.
Deploy the recommended FSx for ONTAP file systemDeploy the new FSx for ONTAP file system that will provide the datastores for your VMs in your VMware Cloud on AWS infrastructure.
Connect your FSx for ONTAP file systems to VMware Cloud on AWSYour Software-Defined Data Center (SDDC) offers network options for connecting to the FSx for ONTAP file system by using the VPC Peering capability to extend network connectivity to the external NFS storage volumes.
Migrate data from your old systems to your new FSx for ONTAP file systemsUse an external tool such as VMware HCX (Hybrid Cloud Extension) to move your data from your old virtual machine storage to the FSx for NetApp ONTAP volumes connected to your new virtual machines.
